How to change front wheel bearing on 2wd?
Discussion in '5 Lug' started by dman66, Mar 6, 2023.
  1. Mar 6, 2023 at 2:39 PM
    dman66
    dman66 [OP] Active Member
    2009 Tacoma 2wd
    2009 2wd drive how to replace front wheel bearing? Not pre-runner
    HondaGM likes this.
  2. Mar 7, 2023 at 11:38 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    bump for any knowledgeable folks
    HondaGM likes this.
  3. Mar 22, 2023 at 1:01 PM
    trucktruckgo
    trucktruckgo New Member
    2005 Tacoma
    I have a 2005 base model five lug tacoma. This is the only video I was able to find on the internet. It's not the best, but it gives you an idea of what is involved. I just did it on my truck. You do have to press out the old bearings and press in the new ones. You'll need to take it somewhere or do it yourself. I bought a 20 ton press at Harbor Freight and it worked well. I also had to buy quite a few other tools, so I didn't save much over having someone else do the job.
    https://www.youtube.com/watch?v=F1OEHb0sCJE&ab_channel=HughHeifer'sHomestead
    sean.hwy likes this.
  4. Mar 22, 2023 at 1:04 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Gosh almighty...thems some rough boys
  5. Mar 22, 2023 at 1:10 PM
    trucktruckgo
    2005 Tacoma
    nmflyguy and HondaGM like this.
  6. Mar 22, 2023 at 1:29 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    EdgemanVA likes this.
  7. May 23, 2023 at 6:42 PM
    19975lugger
    19975lugger Hand-me-down
    Southern California
    1997 5 lug LX
    Fabtech 3" spindle lift kit with add-a-leaf and shocks. Borla exhaust. K&N cold air intake. American racing wheels.
  8. Jul 16, 2023 at 3:01 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Wonder how long that lasted considering the inner race wasn't supported when pounding the hub back in.
  9. Jul 16, 2023 at 3:16 PM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    Them boys are some god damn geniuses.
  10. Jul 16, 2023 at 3:34 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Said they used a shop to press bearings in so why not hub also?
    Reminds me of my younger days as a gorilla.
    Bivouac likes this.
  11. Aug 23, 2023 at 8:17 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I’m doing 5 lug wheel bearings(inner/outer) this weekend
    Will take some pix
    Only supposed to be 102 degrees here…ugh
    -Got torch
    -Bearing races in the freezer
    -PB’d all hub bolts
    -$45 HF race driver set
    wish me luck
  12. Aug 24, 2023 at 6:23 AM
    tak1313
    2013 Base 2WD
    What year is your Taco? 2wds (as far as I know) use sealed bearings - not separate bearing/race assemblies. Press hub out, press old sealed bearing out, press new sealed bearing in, press hub back in.
    But mine is a 2013, so maybe earlier had separate bearing/races?
  13. Aug 24, 2023 at 6:30 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The early 2wd 5 lug trucks have the old style tapered wheel bearings .
    Not real sure just when they changed might be in 2005 when the models changed.
  14. Aug 24, 2023 at 2:57 PM
    ControlCar
    Steven
    Sugar Land TX
  15. Aug 25, 2023 at 5:48 PM
    ControlCar
    Steven
    Sugar Land TX
  16. Aug 25, 2023 at 5:56 PM
    ControlCar
    Steven
    Sugar Land TX
    Well as always
    Job was going much easier than expected
    -didn’t have to separate hub/rotor
    -after heat both races came out NP
    -both races seated NP
    assembled/ greased inner bearing
    Tapped in new inner seal
    Brake cleaned rotor
    Went to mount on spindle, and the inner bearing gets stuck on spindle (won’t seat….can’t even thread axle nut(2 threads only)
    Prt#’s on bearing is the same
    Old bearing slides on
    New bearing will take some persuasion
    trying to ‘force’ on hub assembly I bent the seal too
    AAAAHHHH
    taking a break
    Bearing in freezer now
    advice?
  17. Aug 25, 2023 at 6:11 PM
    ControlCar
    Steven
    Sugar Land TX
    I swear I see a flat spot on old outer
  18. Aug 25, 2023 at 7:27 PM
    ControlCar
    Steven
    Sugar Land TX
    Call into my race friend with a 67 Camaro
    Figured it out
    Appears well worn inner bearing made a 1000’ths of inch lip on spindle
    400grit on spindle surface
    Bearing in toaster over at 200
    Bent the inner seal as flat as possible (rubber seal wasn’t dmgd)
    Hub assembly slid on like a champ!
    cruxofthebisquit likes this.
  19. Aug 25, 2023 at 11:01 PM
    ControlCar
    Steven
    Sugar Land TX
    I’m going to take shower and go to bed
    R side tomorrow
    Taco y mas likes this.
  20. Nov 1, 2024 at 12:29 PM
    Rola2010
    Rola2010 Well-Known Member
    Honolulu, HI
    2010 Tacoma 2wd base RC
    Reviving a semi old thread; need some help from anyone who has changed wheel bearings on a 2nd gen. Pics are on a donor set of knuckles I plan to use after swapping the new bearings in.
    I know the bearing needs to be pressed out, but the outer edge of the bearing (red arrow) is covered by what appears to be a part of the knuckle (highlighted red in 2nd pic).
    Is that highlighted portion a separate piece that also gets pressed out, or is there a special tool required to catch the outer edge of the bearing? From the earlier video, pressing from the spindle will remove most of the bearing but not the outer ring.
    Any input would be helpful. Thanks!
