How to Change Engine Oil on a 2024 Toyota Tacoma 2.4L Turbo 4 Cylinder T24A-FTS
Discussion in '4th Gen. Tacomas (2024+)' started by rat107, Oct 20, 2024.
  1. Oct 20, 2024 at 7:20 PM
    rat107
    rat107 [OP] Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    https://youtu.be/ANvstSqG7VQ?si=umePqFvaXTEUohP2
    Literally 15 minutes
    How to change oil on a 2024 Toyota Tacoma with the 2.4L turbocharged 4 cylinder motor. If it's a 4x4 you don't have to raise the truck off the ground.
    • -OEM Toyota oil filter: 90915-YZZN1
    • -OEM Toyota drain plug gasket
    • -Drain plug torque spec: 30 ft.-bs. (I just go by feel)
    • -Engine oil: Mobil1 full synthetic Ow-20 (6.5 quarts)
    Tools:
    • -14mm 3/8" drive socket
    • -3/8" drive ratchet
    • -12mm 3/8" drive socket
    • -Claw style oil filter wrench
    • -Oil drain pan
    • -Brakleen
    • - Rags
    • -Nitrile gloves
    • - Shop light
    • -Funnel
    • -Creeper
    • -Optional: Milwaukee 3/8" Impact driver
  2. Oct 20, 2024 at 7:22 PM
    Bishop84
    Bishop84 Well-Known Member
    It's so much easier than the stupid 3rd gen. Tundra was a big improvement as well for service simplicity.
    Stevie17 and rat107[OP] like this.
  3. Oct 20, 2024 at 7:50 PM
    rat107
    Kauai, HI
    So easy!
    Stevie17 likes this.
  4. Oct 20, 2024 at 8:07 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Thanks for the video!
  5. Oct 20, 2024 at 8:15 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Why 6.5q when the manual says 5.9?
  6. Oct 20, 2024 at 9:13 PM
    rat107
    Kauai, HI
    That’s how much my truck took and it put the oil right at the full mark.
  7. Oct 20, 2024 at 10:24 PM
    dalton92
    dalton92 Active Member
    is this for a SR auto?
  8. Oct 21, 2024 at 6:52 AM
    miqie
    miqie Well-Known Member
    I've got a set of ramps. Bring the truck half way up. Makes it so much easier.
    rat107[OP] and Stevie17 like this.
