How to change caliper??? Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nikolav1990, May 11, 2018.
  1. May 11, 2018 at 7:41 AM
    Nikolav1990
    Nikolav1990 [OP] Well-Known Member
    Niko
    Magog, QC, Canada
    2018 toyota tacoma sr5 access cab automatic 2.7
    Hey guys i was wondering, one of my calipers is stuck bad and i got a new drivers side caliper, does anybody have a trick on how to change it without bleeding brakes, or can i just change it and bleed just that caliper. Howbdo i bleed it i need help please fast!
  2. May 11, 2018 at 7:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    BassAckwards likes this.
  3. May 11, 2018 at 7:45 AM
    Nikolav1990
    Niko
    Magog, QC, Canada
    Can i pinch the front rubber brake line to avoid air getting up the line?
  4. May 11, 2018 at 7:47 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can, just be careful not to damage it. I'd also recommend using a flare wrench on the fittings. The metal toyota uses is very soft and it's easy to round off one of the hard brake lines trying to loosen them.
  5. May 11, 2018 at 7:47 AM
    ProfHobbit
    ProfHobbit Well-Known Member
    North Shore, MA
    2007 Tacoma 4WD, 5 SPD, 2.7L, Access Cab, Base
    Minor Stuff
    Salut, Niko. Vous allez trouvez toute l'aide duquelle vous avez besoin ici!
    If you do a search on brakes for the second Gen Tacos, you'll find a lot of resources.
    This thread will get you started on safe ways to get the truck in the air, and getting access to those components: https://www.tacomaworld.com/threads/how-to-change-front-brakes-pads-and-rotors.353082/
    Here are some good videos I have found - vehicle models and techniques may be a bit different from yours:
    https://www.youtube.com/watch?v=KzKYrbnAMkE
    https://www.youtube.com/watch?v=Gzgh_LVAIDE
    https://www.youtube.com/watch?v=UcL1mCD1jKw
    This is also a good thread here on the forums:
    https://www.tacomaworld.com/threads/brake-upgrade-stoptech-rotors-trd-performance-pads.523829/
    Do a search on "Brake bleed screws" here as well. They are a product your local parts store will likely have, and could save you some time.
    The big thing I would say is that it sounds like you're in a hurry. I don't mean to condescend, but I've been in that state before doing work on stuff - it always ends unhappily. Take some deep breaths, understand that it may take longer than you think, make other arrangements if you can, and walk through each step carefully. You've got this!
    Gunshot-6A and EatSleepTacos like this.
  6. May 11, 2018 at 7:49 AM
    ProfHobbit
    North Shore, MA
    Minor Stuff
    Great advice - I'm adding that to the walkthrough I'm building for myself on this.
    EatSleepTacos[QUOTED] likes this.
  7. May 11, 2018 at 7:49 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    pinch line close to caliper, remove, add new caliper, open bleeder, have person press brake and release clamp and then close bleeder and put clamp back on. repeat bleeding with clamp until most air is out and you should be good
  8. May 11, 2018 at 7:50 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Soak all the fittings with PB balster or liquid wrench, or something similar for a couple days leading up to doing the work. It helps a lot! Even with all the precautions I managed to round off one hard line. Sometimes it's unavoidable.
  9. May 11, 2018 at 7:51 AM
    ProfHobbit
    North Shore, MA
    Minor Stuff
    I'm doing mine later this year. Thankfully, they had it all apart when they did the frame job, and gave me new lines. As long as they don't seize up before late summer or so, I'm good.
    EatSleepTacos likes this.
  10. May 11, 2018 at 8:48 AM
    81shark
    81shark Well-Known Member
    just prefill the caliper. it'll be fine.
    *note. not responsible for any crash that results from your laziness.
    brakes are brakes. bleed... bleed em all. it takes a little time... but... that's the job. unless you want to half ass it. carry on
    SocalTaco15, Grey 2015 and Bebop like this.
  11. May 11, 2018 at 8:51 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  12. May 11, 2018 at 10:11 AM
    Nikolav1990
    Niko
    Magog, QC, Canada
    Thanks guys!! Just finished changing the caliper, i clamoed the line with a towel and i vicegrip, then put the new caliper on and bled only that side, everything went well now it brakes like new with new pads on both sides and a caliper, cost me 160$ to do it myself.
  13. May 11, 2018 at 10:14 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Good luck with the replacement caliper. Mine are napa remans and only few years old. One side is sticking bad already. Going to rebuild them with oem parts soon.
  14. May 11, 2018 at 10:17 AM
    Nikolav1990
    Niko
    Magog, QC, Canada
    Yes i also got the napa calipers with premium quality pads, ile be happy they last a caouple years
  15. May 11, 2018 at 10:19 AM
    Nikolav1990
    Niko
    Magog, QC, Canada
    By the way my truck has 90,000 miles and they were the stock pads and calipers and the rear drums are at about 50% used still on stock , im impressed by the reliability of my truck its 11 years old never really had a problem other then recalls
  16. May 11, 2018 at 10:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Good job! Congrats on being able to do it yourself.
    Tacotj likes this.
  17. May 11, 2018 at 10:24 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Should’ve gone with the Napa eclipse calipers.
  18. May 11, 2018 at 10:26 AM
    ProfHobbit
    North Shore, MA
    Minor Stuff
    Félicitations, et bonne chance!
  19. May 11, 2018 at 1:13 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Just a tip - Always buy some new slide pins and clips. Only $8-$9 from a dealer. The ones currently in the caliper are probably stuck and corroded. Get a good pin punch set and ballpene hammer to punch them out.
