How to Change a CV Axle on an 01-04 ADD Tacoma
Discussion in 'Technical Chat' started by JimBeam, Dec 15, 2008.
  1. May 4, 2014 at 10:04 AM
    #61
    jmmanahan
    jmmanahan New Member
    2001 Tacoma SR5 4X4 V6
    None except aftermarket seats.
    Thanks for this great step by step process. I changed out my CV axle yesterday with no problems. Popped out of the diff just fine and snapped back in with one hammer blow. All good and no more ugly scraping noises from the front end.
    04Burk likes this.
  2. Sep 3, 2014 at 1:08 PM
    #62
    jgb8743
    jgb8743 Member
    Georgia
    07 TRD Off Road SR5 4X4 Manual
    If one were to damage that thin metal lip that meets up to the oil seal in the process of prying out the shaft, is there a place or part number to replace it? I managed to mangle mine, and now the seal won't stop leaking no matter what. The only way I've found to replace it is to get a whole new shaft.
    TacoMatt253 likes this.
  3. Mar 20, 2016 at 8:42 AM
    #63
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Sub'd, looking to do this soon. Nice write up!
  4. Aug 13, 2016 at 6:18 PM
    #64
    c_mcnally
    c_mcnally New Member
    2001 White Tacoma 3.4 V6 4x4
    Great write up. I have a few "dumb" questions as I'm kind of a newb. I have everything taken apart and the new axels for both driver and passenger side.
    Is there a difference between the axels? I can't see one, but I don't want to make a mistake.
    When putting the axels back in, is there a proper position (top vs bottom) when putting them back in? My factory ones were round and the new ones are more of a triangle. I'm guessing no diff on this, but wanted to ask.
    Should I put some axel grease on both ends of the axels when putting them back, or just the differential side?
    My seals look good, but I feel like I should replace them just to be safe. There is a seal on the differential and on the wheel side right? Does anyone have the part numbers or suggestions on what to buy?
    If I'm taking the seals out should I just replace the bearings too?
    I follow directions well, I just don't have a ton experience to know what's right. Thanks for the help.
  5. Aug 23, 2016 at 5:48 PM
    #65
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I wonder if this is whats wrong with my truck? So in reference to the 4 bolts that hold the hub piece to the lower control arm. I should be able to take that apart without messing with the struts?
  6. Oct 12, 2016 at 9:58 AM
    #66
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  7. Jan 19, 2017 at 10:35 PM
    #67
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    This write up is much appreciated. Just swapped the passenger side with a friend.
    Not sure why but the 12mm socket for the screws under the spindle were 14mm for my truck. Same with the 36mm for the cotter pin nut was a 35mm.
    04Burk likes this.
  8. Jan 21, 2017 at 9:51 AM
    #68
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    yeah mine are 14mm. . doing a cv shaft today.
    anybody notice that none of the aftermarket cv axles (autzone duralast and napa) have wheel bearing dust shields (abs ring)? Is the only way to get a proper replacement by paying for toyota OEM parts? ($173 vs 55)
    as it turns out the napa new part has the shield, the remanufactured part does not. :mad:
  9. Feb 10, 2017 at 11:47 AM
    #69
    hortona
    hortona Well-Known Member
    99 tacoma SR5 w/ 3rz-fe
    Nice write up first of all how did you guys put in the new axle seal,I got a seal installing kit but it didn't seem like it worked for that type of seal..Second after replacing my CV axle I realized when rotating the tire there's a sticky spot where the tire seems to be harder to turn could this be due to my 3 inch lift.. thanks
  10. Jun 18, 2017 at 4:30 PM
    #70
    BThorson
    BThorson Well-Known Member
    Oregon
    2003 red Tacoma TRD 5speed
    3" toyotec coils, wheelers progressive leaf, bilstien 5100, pro comp wheels, 285/75r16 cooper st maxx, grey wire, weather tech, floor mats, bug deflector and rain guards, old man bed shell, tint
    Nice write up just did this today very easy to do following this.
  11. Aug 18, 2017 at 9:46 PM
    #71
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    those who've had the issue of the swaybar not allowing you room to remove the axle: was it as easy as removing the sway bar? my sway bar mount on the LCA looks like it'd get in the way, even with the bar gone.
    saw a youtube video of a fella doing this on a manual hub 98; he ended up unbolting the shock to get his out. is this necessary?
  12. Aug 22, 2017 at 11:31 PM
    #72
    BThorson
    Oregon
    I got the swaybar disconnected on the driver side but the passenger side the link would not loosen the nut was froze onto it. I ended up keeping it on when I changed it. It was a tight fit but doable
  13. Feb 6, 2018 at 3:28 PM
    #73
    04Burk
    04Burk Well-Known Member
    Glen
    Hinesville, GA
    04 4x4 V6 Xcab 217k miles
    Excellent write up. Will be changing mine on my 04 4x4 next month. Will come back and post results.
  14. Jun 17, 2018 at 9:32 AM
    #74
    Cid
    Cid ╭∩╮(◣ _ ◢)╭∩╮
    Keith
    Waterbury CT
    2004 Taco 5spd SR5 TRD / 2018 HD FXBB
    ADS Coilover Front, OME Dakars with Nitro's Rear, Relentless Skids, BAMF Sliders, FN Five Star rims, 285/75r16 Falken Wildpeak, Aero Turbine 2525
    A few years late but thanks for the write up. Blown CV boot so I'm just gonna replace the axle then maybe throw a new boot on the old one for a backup.
    TacoSauce04 likes this.
  15. Aug 5, 2018 at 9:46 PM
    #75
    MAX TACO
    MAX TACO Member
    2011 4x4 4 door silver
    k&k intake banks stainless ex. and muffler
    GOT MINE OE 345.00 EACH......... TOYOTA
  16. Oct 2, 2019 at 8:40 PM
    #76
    Tacoman100
    Tacoman100 Active Member
    Sorry to wake up an old thread, but are there any pieces that I’ll need to re-use for the new assembly? I’m only buying the barebones CVs with no extra accessories.
    Also anyone recommend any good branded CV axles and where to buy ’em?
    2001 Tacoma
    Trowbocop likes this.
  17. Oct 3, 2019 at 7:32 AM
    #77
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    Every part goes back where it came from on re-install, except the cv axle itself- you re-use everything.
    I replaced mine with Toyota remanufactured cvs 4 years ago & have done plenty of wheeling since then, & they've held up great. They'll give you $ for your blown cvs so they can rebuild and sell them afterward.
    Good luck!
  18. Oct 3, 2019 at 7:41 AM
    #78
    Tacoman100
    what’s a good place to pick up these reman CVs? Would they give me money for CVs that are not OEMs?
    Thinking of grabbing the autozone versions
    Trowbocop[QUOTED] likes this.
  19. Oct 3, 2019 at 8:29 AM
    #79
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    Any Toyota dealership should have them, but call around, as prices differ. Mine were original on the truck, so, I'm not sure about non-toyota parts :notsure:
  20. Jul 22, 2020 at 10:15 PM
    #80
    SemperInMotu
    SemperInMotu New Member
    Mayhem
    2003 Tacoma Xcab 4X4
    None yet, but working on it
    Great writeup- mine are popping every time I turn the corner, so that's on the list of stuff to fix.
