How to carry a 10 ft pole?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoManTaco, Jun 6, 2020.
  1. Jun 6, 2020 at 9:39 AM
    TacoManTaco
    TacoManTaco [OP] Well-Known Member
    Hey guys, i have a 10 ft EMT conduit tube that I need to carry a hundred miles on the turnpike in my short bed.
    Not sure how to tie it down.
    Doesn't really seem safe to leave it hanging over the tailgate, but what do I know. Not looking to buy any expensive add-ons to help carry it.
  2. Jun 6, 2020 at 9:44 AM
    Graham5david
    Graham5david Active Member
    David
    2020 TRD off road
    Just lay it over the tailgate with the tailgate closed and strap it down. You can put it from corner to corner if it doesn't stick out to far from the side.
    Grindstone likes this.
  3. Jun 6, 2020 at 9:46 AM
    Clearwater Bill
    Billy
    Largo Florida
    1) Buy the conduit you need where you are going
    2) Open your back window and put one end on the dash in a towel. Since you have a short bed, I'm assuming double cab, which has some distance from window to dash.
    3) Cut it in half and both pieces will lie in bed. Use coupling to rejoin.
  4. Jun 6, 2020 at 9:47 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This, then use a red shirt or flag of some kind near the end of the item
    Pyrotech likes this.
  5. Jun 6, 2020 at 9:57 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Cut it in half...join the two pieces back together with a coupling.
    jon_elc likes this.
  6. Jun 6, 2020 at 10:03 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Tailgate up or down, it doesn't matter. Place tube in truck, strap down, tie red flag on the end and drive. A ten footer is as long as I'd carry, but I've carried 10' lumber, pipe and kayaks in my truck for years with no issues. I'd prefer tailgate up since this will get the end extending past the truck up high enough that most cars would be under tube if they were to get too close at a traffic light etc.
  7. Jun 6, 2020 at 10:08 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Buy a cap, then a full prinsu. Should only set you back about 4G. Easy.
    Otherwise, cut and shut with a coupling, About $3. Your choice.
    TacoManOne, synaps3, jon_elc and 8 others like this.
  8. Jun 6, 2020 at 10:09 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I carry a 15’ mast for a little sailboat I transport in the bed frequently. I rest the forward end, very lightweight, on the arm of the passenger side mirror and secure with a bungee. The aft end gets suspended after being wrapped a couple wraps along bedside with a bungee. I use the tie downs in the bed for this. Worked like this for many years with no problem. I also brought home a bunch of 1/4 round wood mounding from HD like this.
  9. Jun 6, 2020 at 10:11 AM
    TurdGenTuRDOffRoad
    TurdGenTuRDOffRoad Well-Known Member
    2017 TRD Off Road 4x4
    step 1: buy 10 ft pole
    step 2: buy 2nd gen
    step 3: hold pole and when it touches truck, start backing up
    enjoy the "looks" of your 2nd gen
    maybe talk trash on the 3rd gen forum if its not working
    pew pew, shots fired
    Malvolio likes this.
  10. Jun 6, 2020 at 10:15 AM
    RPVTaco
    RPVTaco Well-Known Member
    Randy
    2019 TRD PRO
    Cut in half but if you can’t for some reason then through the back window and rest it on the dash with a towel. I’ve carried crown moulding this way.
    Xx_Evilvirus_xX and In&out like this.
  11. Jun 6, 2020 at 10:24 AM
    mikeaesq
    mikeaesq Well-Known Member
    TRD Off-road 4x4
    I just tuck my 10’ pole down my pant leg.
    Can’t believe nobody took it there earlier. disappointed in this form.
  12. Jun 6, 2020 at 10:28 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    If you are worried about having 5 ft hanging out of the bed and it bending, buy a 10' 2x4 and duct tape it to the board. Then you can load it in the bed with the tailgate up and use one of the anchor points in the bed to strap it down.
    Don't forget a red flag so the cops don't stop you.
  13. Jun 6, 2020 at 10:30 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So.... have you thought about mounting it under your truck? there should be at least 10 feet of open space without suspension that it could be strapped to. As long as your not rock crawling with this pipe you should be fine.
    Duct tape and zip tied will keep it up and from sliding back and forth.
    HeyWannaTaco, #4TOY4ME, Chako and 2 others like this.
  14. Jun 6, 2020 at 10:32 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    These bed extenders that fit in the hitch are awesome for long items, I had 10 foot sections of gutters here.
  15. Jun 6, 2020 at 10:33 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I wonder if u could go side mirror, then diagonal through the back window. An emt isn't likely to damage anything.
  16. Jun 6, 2020 at 10:37 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  17. Jun 6, 2020 at 10:47 AM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    U could tie it down using the clove hitch
    Tie some flagging tape in the end and your good to go
  18. Jun 6, 2020 at 11:05 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I wouldn't touch it...
  19. Jun 6, 2020 at 11:05 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
  20. Jun 6, 2020 at 11:40 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Roll down both back windows. Stick it thru, roll up both back windows. Roll out.
    HeyWannaTaco and COTacoTime like this.
