How to adjust speedometer for larger tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Killer, May 31, 2010.
  1. May 31, 2010 at 5:03 PM
    Killer
    Killer [OP] Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    How can I adjust the speedometer for larger tires? Can I do it myself, tire store or do I have to take it to a dealership?
    Thanks,
    Killer
  2. May 31, 2010 at 5:04 PM
    jandrews
    '09 FourDubDee TRD OR
    Mental math is the easiest method...calibrate next to a GPS or something.
  3. May 31, 2010 at 5:05 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    I don't think you can. Or at least I have never heard of anyone doing it. Get a scanguage and adjust it to you tire size.
  4. May 31, 2010 at 5:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This:
    Or this:
  5. May 31, 2010 at 5:18 PM
    Chief10Taco
    Chief10Taco Well-Known Member
    Rob
    Tampa, FL
    2010 TRD Off-Road 4X4
    weathertech floor liners, weathertech bug deflector and side window deflector, and wet okole front seats
    ^^^^^nice^^^^^
    need to get me one of those
    Austintm04 likes this.
  6. May 31, 2010 at 5:23 PM
    Killer
    Mobile, Al.
    I need both of them!
    My tires right now are : 32 x 11.5 R 15 LT Steel Radial Mud King XT
    How much bigger are they than stock? How much do you think that the speedometer will be off?
  7. May 31, 2010 at 5:26 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    barely any
  8. May 31, 2010 at 5:26 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    What was your stock tire size?
  9. May 31, 2010 at 5:28 PM
    Killer
    Mobile, Al.
    I don't know what the stock size was. I have owned the truck for about 24 hours and it did not have any paperwork.
  10. May 31, 2010 at 6:14 PM
    mlittle
    mlittle T O Y O T A
    Michael
    Fort Sill, OK
    2014 Toyota Tundra Crew Max 4x4
    Look at the label on the side of the door or jam. It will list the stock tire size for your truck.
  11. May 31, 2010 at 6:16 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Sand Shark likes this.
  12. May 31, 2010 at 6:47 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    It'll probably be closer to true speed now than it was before.
  13. May 31, 2010 at 6:53 PM
    Killer
    Mobile, Al.
    Factory Tires (according to door sticker) = P225/75/R15
    I know the 15 is referring to the rim size but, I need to research the other numbers.
  14. May 31, 2010 at 6:55 PM
    Jason'sLawnCare
    225 mm wide and 75% of the width in side wall so 169ish mm side wall height.
  15. May 31, 2010 at 7:15 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    anyway,
  16. Jun 1, 2010 at 6:15 AM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    thats what my sticker says too, but it came with 265/75/15's.
  17. Jun 1, 2010 at 9:31 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    if your truck is like mine, it will be dead-on with 32" tires.
  18. Jun 1, 2010 at 1:08 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Tire caculator says my speedo should be way out...Hooked up my GPS...It's reads 53 kph when my speedos at 50 kph...So I guessing my Taco must be calibrated already to accodate for my larger tires :D
    50 mph 57.81 mph
  19. Jun 1, 2010 at 1:56 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    Its actually calibrated to never show you're going faster (from the dealer) than the speedo shows, as per U.N. Regualtion No 39 and US Motor Vehicle Regulation No 25. The US Regulation allows a 5% margin, which the manufacturers take full advantage of due to heavy fines if the speedo shows you're not speeding when you are actually are.
    Speedo's are never calibrated for true speed, but for true speed minus a margin (2-3% would be my guess).
    So, when you put on larger tires, you're actually getting closer to true speed, until you go over the margin. 32-33's should end up being pretty close to true speed for most of us.
  20. Jun 1, 2010 at 2:01 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
