How to adjust projector lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Claudiomartinof, Oct 29, 2016.
  1. Oct 29, 2016 at 6:39 AM
    Claudiomartinof
    Claudiomartinof [OP] Well-Known Member
    2019 TRD OFF ROAD 6MT
    Hey guys sorry if this has already been discussed but I realized that my passenger side low beam light is lower than my drivers side and it should be the opposite or leveled..
    Do you know how to adjust them?
    Thanks!!!
  2. Oct 29, 2016 at 6:48 AM
    13mgm4X4
    13mgm4X4 Well-Known Member
    Not sure how to adjust them but my driver side is higher than the passenger side as well. I always thought it was supposed to be the other way around but it's a new truck so I figured it was normal.
  3. Oct 29, 2016 at 10:04 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    There is a diagram on here some where, but i will try to explain it. On top of each headlight is a hole for a screwdriver to turn a philips screw, that screw when turned cc/ccw will adjust headlights up or down, if i have a sec i will add pic
    0210 and Claudiomartinof[OP] like this.
  4. Oct 29, 2016 at 10:11 AM
    Claudiomartinof
    Thanks! I'll check this afternoon!
  5. Oct 29, 2016 at 10:19 AM
    Broccoli
    Airdrie Alberta
    I may have goofed,just had a wuick look and didnt see anything. there should be lots of info in the 3rd gen trs moimoto hid thread. May have to dig thru the bullshit a bit
  6. Oct 29, 2016 at 10:35 AM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I think I used an 8mm(?) socket to turn the knob on the back instead of using the screw driver option. it was faster and easier for me.
  7. Oct 29, 2016 at 10:51 AM
    InSight Retrofits
    InSight Retrofits Closed
    The adjuster is right below the middle of the high and low beam bulb.
    8mm wrench/socket or a philips screw driver. IMG_3878.jpg
    You want your cutoffs at the same height like this
  8. Oct 29, 2016 at 11:53 AM
    Claudiomartinof
    Thanks guys!!
  9. Nov 4, 2016 at 4:58 PM
    easyrider88
    easyrider88 Well-Known Member
    2017 Quicksand Tacoma DCSB OR 4X4
    Interesting
  10. Nov 5, 2016 at 6:38 AM
    Claudiomartinof
    Another question guys, do the hi beams are adjustable?
  11. Nov 5, 2016 at 6:42 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    really?o_O
  12. Nov 5, 2016 at 6:43 AM
    Claudiomartinof
    Hahahaha I'm just asking... maybe yes maybe not! I thought that after looking al the shit that the headlights have on the back..
  13. Nov 5, 2016 at 7:10 AM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Can confirm, it's that little knob on the bottom there in between the two bulbs. Worth noting the one on the passenger side can only be reached with a wrench or a screw driver. The driver side a socket works well on. I just adjusted mine the other week after putting 5100's up front. That small change to a more level ride height ended up putting my lights in the mirrors of smaller cars (civics or whatever), so I would say any time the ride height is adjusted (even a 1" lift in the front) you'll probably want to readjust to make sure you aren't blinding your fellow drivers out on the road.
    kfergie0097 likes this.
  14. Nov 5, 2016 at 11:01 AM
    InSight Retrofits
    When you adjust the lights it moved both the high and low beam
    nakedwaterskier and peavey02 like this.
  15. Nov 5, 2016 at 11:31 AM
    Claudiomartinof
    That's interesting!!! I didn't know that.. thanks!!
  16. Mar 6, 2018 at 8:17 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    how the hell do you get to the passenger side adjustment knob?....do you have to take the windshield tank out? :confused:
  17. Mar 6, 2018 at 10:47 PM
    Invid
    2016 Tacoma Limited
    No, a short socket should do it just fine. I've adjusted mine this way.
  18. Mar 6, 2018 at 10:49 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    thanks a bunch...ill look tomorrow morning
  19. Mar 8, 2018 at 1:24 PM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    No offense but that is NOT at the same height! The passenger side is higher.
  20. Mar 8, 2018 at 1:30 PM
    InSight Retrofits
    Not sure what you're looking at? Those lights are perfectly level. Each light creates a step pattern, both steps are at the same height.
