How tight are the clamp bolts on the camper shell suppose to be
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kotah, Dec 21, 2017.
  1. Dec 21, 2017 at 3:27 PM
    Kotah
    Kotah [OP] Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    I was trying to figure out what was the correct tightness on the leer camper bolts that go through the fiberglass and into the clamp in the track, dont want the fibreglass to crack, i choked up on a 3/8 ratchet and tightened it with my fingers till it was tight but still seems like it was putting alot of pressure on the fibre glass, how did you all do yours.
  2. Dec 21, 2017 at 3:28 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Until the aluminum clamps start to bend I have found is a good indicator.
    Both my taco with metal bed side caps, and superduty with plastic bedside caps have had the shell move despite the clamps being tight as shit. Drilled and used bolts on the taco, quit wheeling the superduty.
  3. Dec 21, 2017 at 3:45 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I think I have a similar style to yours. It's a SnugTop with no big C-clamps, just portions of the fiberglass that a bolt goes through and into 6 little clips that hook onto the factory bed rails. The bolts are not tight at all, per Campways who installed my shell. Basically once I see that fiberglass moving I go a little bit more and stop. I forget the torque spec they gave me but it was surprisingly low. I even think mine are tighter than they specify.
  4. Dec 21, 2017 at 3:47 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't use a torque wrench, but pretty darn tight. It is a good idea to check them every month or so either. They will vibrate loose.
    JaxJim and Alfred like this.
  5. Dec 21, 2017 at 3:48 PM
    andrew61987
    Guys I think you're talking about a different style shell than OP has. What both of you are describing will crack the fiberglass on these kinds of shells.
  6. Dec 21, 2017 at 3:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    Can you make a 'washer' of sorts to distribute the load on the fiberglass? Like a 4-6" piece of metal the width of the lip? That should allow tighter clamping with less risk of cracking.
    As far as vibrating loose of the threaded portion, Locktite blue will fix that.
  7. Dec 21, 2017 at 3:57 PM
    andrew61987
    The portion of the fiberglass that the bolt force acts on is cantilevered toward the bed, and over-tightening the bolt puts the cantilevered portion in bending, it's not necessarily a failure at the bolt hole and there's no actual "crushing" force put on the fiberglass so I don't think spreading the load will do much.
    OP my bolts are 10-15 ft*lbs max and I wheel the snot out of my truck and it's never budged.
  8. Dec 21, 2017 at 4:23 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    My shell has been on since 2014 and I haven’t touched it.
    canopycarl likes this.
  9. Dec 21, 2017 at 4:39 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I have to re tighten my leer cap bolts every few months, my truck sees off road use for work most every day though. I tighten until I feel like it's tight without risking cracking the cap. Mine did shift ahead this fall aftera stretch of not re tightening the bolts and almost dug into the paint where the box side meets the head board
    Bruce988jl likes this.
  10. Dec 21, 2017 at 5:08 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You're so right. A bigger washer just makes the "wing" snap off easier vs stripping through the fibreglass. I just checked mine. I think "just snug enough that the bolt doesn't rattle" is good.
  11. Dec 21, 2017 at 5:08 PM
    Kotah
    TN
    I appreciate all the help, im only use to the c clamp style where you dont have to really worry about it, like andrew said the fiberglass is cantalevered over the bed so your actually bowing that section of fiberglass where your tightening the bolts, that part where the bolt goes is a good deal thicker, i did notice after i pulled all the bolts and clamps to try and get my factory tie down knobs on that the used seal on it had the cap stuck pretty good i put a little force on the shell and it did not want to lift, so when i figured out factory tie down knobs that tighten the tie downs to the track wasnt going to work i put them back in and tightened with the head of the ratchet insteads of the handle. My bolts had 1" diameter washers against the fiberglass.
  12. Dec 21, 2017 at 5:09 PM
    Kotah
    TN
    Dam mine are way tighter than that.
  13. Dec 21, 2017 at 5:14 PM
    Kotah
    TN
    Im going to go check the torque and thinking about installing nylock nuts on the bottom side of the clamps where the bolt goes through, i would hate to screw up my topper lol thats why im asking for advice, nothing like experience from you guys.
  14. Dec 21, 2017 at 5:15 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Holy shit I've never checked mine, maybe I should. You guys are stesssing me out
    b_r_o likes this.
  15. Dec 21, 2017 at 5:18 PM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
  16. Dec 21, 2017 at 5:30 PM
    Kotah
    TN
    Ha ha sorry
    b_r_o likes this.
  17. Dec 21, 2017 at 6:25 PM
    Kotah
    TN
    I dont think you can use the torque wrench method, after i got them pretty tight by choking the ratchet head i set my torque wrench on 10' lbs and the fiberglass is deflecting as you check the torque, its not like your torqueing a bolt and nut through a piece of metal where it pulls up solid, i think the fiberglass will crack before it shows 10' lbs, i chickened out after a couple of rounds with the torque wrench and backed it back off and choked the ratchet head again and retightened then measured between the top of the clamp and fiberglass and got the measurements equal all the way around.usually the torque is set by the bolt size not the material your torqueing,
    b_r_o likes this.
  18. Dec 21, 2017 at 7:01 PM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    this is the style I'm running and I have them as TIGHT as the clamps will allow me to get them.
  19. Dec 21, 2017 at 8:23 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    2 grunts before a strip...
  20. Dec 21, 2017 at 8:44 PM
    Pigpen
    Northwest Montana
    I like the nylock nut idea. Mine are loose every time I check them. Usually once a year, if that.
    Mongoose likes this.
