How the heck do you get to these zerks??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonah, Apr 27, 2025 at 11:16 AM.
  1. Apr 27, 2025 at 11:16 AM
    Jonah
    Jonah [OP] Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    I failed at lubing the drive shaft today. Both the front and middle zerks on the main shaft are blocked so the gun won't lock on to the fittings. The front one has a bolt in the way and the middle is behind the u-joint yoke. I tried 2 different grease guns and the Lock N Lube tip. What am I missing?
  2. Apr 27, 2025 at 11:39 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I have to use a mini grease gun with those 3 oz cartridges. They also have a thinner coupler that fits in there.
    ridefreak likes this.
  3. Apr 27, 2025 at 11:58 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    A grease injector needle will do the trick.
    reallifedog and herecomesace like this.
  4. Apr 27, 2025 at 12:53 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Someone replaced the ujoints and didn't pay attention to the location of the grease fittings.
    Actually the stock ones have the fitting on one of the caps instead of on the cross.
  5. Apr 27, 2025 at 2:01 PM
    Jonah
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    I thought that was the case. All the videos I watched made it look easy.
  6. Apr 27, 2025 at 2:30 PM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
  7. Apr 27, 2025 at 4:16 PM
    gm1ll
    gm1ll Member
    12 SR5 Debadged MGM 4X4
    Mine has the stock u-joints and the grease fittings are on the cross. I haven't had problems greasing them though.
    TartanEagle and ridefreak like this.
  8. Apr 27, 2025 at 4:57 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    I use a regular size grease gun without any issues. I just rotate the driveshafts as needed since the truck is lifted and in neutral.
    SomeGuy_GRM likes this.
  9. Apr 27, 2025 at 5:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting, are you sure they are original?
    My 14 has them on the caps on the rear driveshaft and the crosses on the front.
  10. Apr 27, 2025 at 6:06 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    That's how my 09 is.
  11. Apr 28, 2025 at 9:20 AM
    gm1ll
    gm1ll Member
    Bought the truck new. I’ll probably be doing the rear carrier bearing here soon, so will probably do th joints at the same time.
    wilcam47 likes this.
  12. Apr 28, 2025 at 9:50 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    My original '17 zerks are on the cross. No issue getting to them with a proper nozzle.
    Zerks come in 0 degree, 45 degree, and 90 degree angle versions as well. Unscrew your current ones and swap with ones that work for you.
    Peter603Taco likes this.
  13. Apr 28, 2025 at 12:53 PM
    Jonah
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    I considered swapping them, but I don't see how I could get a wrench in there to tighten a 45 fitting.
  14. Apr 28, 2025 at 12:54 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this. I gave up and took it to my mechanic and he laughed at me and slid under the truck with this...
    478DblSport[QUOTED] likes this.
  15. Apr 28, 2025 at 3:57 PM
    s.e.charles
    s.e.charles Well-Known Member
    do we know the thread size for these fittings?
    thanks
  16. Apr 28, 2025 at 4:06 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Yes. You Joints with grease zerks on the cross the zerk needs to point to the center of the shaft. In this case he may just need to unbolt the flange and position as needed to lube then reinstall.
  17. Apr 28, 2025 at 4:49 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    The zerk is suppose to point towards the shaft, that seems to be your problem.
  18. Apr 28, 2025 at 6:16 PM
    Waasheem
    Waasheem
    2007 xrunner
    Lock n lube tip is a big ol honkin thing. One of the grease guns I bought came with it. I can’t say I’ve used more than 3 times. I’ve had good luck with Lincoln & Dewalt tips.
    I’ve never had luck using a needle on a standard zerk.
    If there’s room, you could unscrew the existing zerk & put in an angled one. Keep in mind there’s several different sizes. Diameter thread pitch metric sae.
    https://www.amazon.com/Lincoln-Elec...9150&sprefix=Lincoln+grease+c,aps,228&sr=8-11
    https://www.amazon.com/dp/B00HG3B97W
    The one time I pulled out my grease gun to lube mine, discovered my 5 lug has no zerks on the driveshaft and ujoints.
