How serious is a p0420 code?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyoTaco02, Sep 16, 2012.
  1. Sep 16, 2012 at 7:36 PM
    ToyoTaco02
    ToyoTaco02 [OP] Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    The famous p0420 code popped up on me a couple of days ago. I took it to the dealer and they said I need new cats and also a new rear o2 sensor. Total price to fix would be just under $2600!!!! They cleared my code for me and it hasn't came back since. How bad would it be to leave the cats, get a new rear sensor and a new air/fuel sensor? If the code comes back can I just get the urd o2 simulator and be ok? By the way I live in IL and we have no emissions testing.
  2. Sep 16, 2012 at 7:38 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  3. Sep 16, 2012 at 7:46 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    The code isn't really that serious. All it means is that your catalytic converter isn't doing its job at reducing the amount of pollution your truck produces.
    But if you have to get new tags/plates and have to pass emissions testing to do so you may need to get it fixed.
    My truck popped a p0430 (bank 2) code last week. And according to the scan tool data I read both of my cats are bad. So I'm just gonna wait until emissions time to worry. I cleared the code on last Monday and still hasn't come back.
  4. Sep 17, 2012 at 7:27 AM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I replaced both sensors and the code hasn't come back yet.
  5. Sep 17, 2012 at 7:29 AM
    Steve33fish
    Steve33fish Well-Known Member
    Yorba Linda
    13 Tacoma 4x4 LB
    This might sound funny but had a buddy with same code and he tried using lacquer thinner in the tank, add 20% off thinner and fill up tank and just drive normally. The thinner will flush out the imperfection in the cats. Please try at own risk!!! You can YouTube it and find more intro into it.
  6. Sep 17, 2012 at 7:38 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I would try this before adding that to your tank(I wouldn't put that ).
    http://m.youtube.com/watch?v=5icTmYItwiE&desktop_uri=/watch?v=5icTmYItwiE
  7. Sep 17, 2012 at 7:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    That code doesn't always mean the CAT(s) are bad. It could be a simple exhaust leak.
  8. Sep 17, 2012 at 7:41 AM
    Steve33fish
    Yorba Linda
    13 Tacoma 4x4 LB
  9. Sep 17, 2012 at 7:44 AM
    98tacoma27
    Ben
    Not Beech Creek
  10. Sep 17, 2012 at 7:55 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Exhaust is a Great place to start! MUCH CHEAPER TOO lol.
    I did a bit of reading on this a while ago as I had the code pop up on ours. Unconfirmed as actual issue cause, but saw a few people post about quality of fuel issues potentially causing the code to pop up especially if you short shift (shift 2000 or so rpm) trying to get into 5th as soon a possible and stay there. Especially at lower speeds.
    Issue with the fuel was a thought towards "poorer quality" fuels or "high mix" fuels not working well in the system and could potentially pop the 420 code. When reading these accounts I found it particularly interesting as we typically fill up at the same Phillips 66 and had no issues. We were across town and ended up filling up at a Sam's as we were out of fuel. Half way through the tank the code popped up when we were driving in just the same conditions (short shift etc.).
    Cleared the code, put some Fuel System Restore in. Been driving for months okay and use the truck quite a bit.
  11. Sep 17, 2012 at 8:09 AM
    2012 Tacoma
    2012 Tacoma Well-Known Member
    Todd
    Illinois/Arizona
    2012 SR5
    Undercover Classic, TRD Skidplate, Wet Okoles
    Scott I live about 2 hours north of you in Frankfort, Il and we've been doing emmisions tests for 20 years I bet...You are lucky!!
  12. Sep 17, 2012 at 8:16 AM
    Ecnerwal
    Ecnerwal Well-Known Member
    NW Mass
    '02 4x4 2.7 A/T Ext Cab
    gradually replacing the bumper with hairy bondo ;-)
    I'd replace both front and rear sensors with Densos ($150, not at dealer, Rockauto, you install) before I even thought about buying new cats. Clean the MAF too.
    420 is a bad reading on the rear sensor, which monitors the cat performance. That can be due to the rear sensor being bad, the front sensor not doing it's job well enough but managing not to throw a code, a dirty MAF screwing up the ratios, or the cats being bad. As already mentioned, an exhaust leak can also cause it. Cats, being very expensive, are only worth suspecting if you are selling the things or you've eliminated all other causes.
    I'd save the bubba approach to "cleaning" your cats until after you have tried everything else short of cat replacement, too...
  13. Sep 17, 2012 at 8:46 AM
    n0ms
    Angel
    San Diego
  14. Sep 17, 2012 at 10:48 AM
    BamaToy1997
    Bill
    Navarre, FL
    I guess I need to go ahead and do my P0420 write up that I have been working on. It is a bit long and extensive. As mentioned at least once, a P0420 does not necessarily mean the catalytic conv is bad. What it means is that the post-cat O2 sensor is not reading the correct values for what it SHOULD be reading. This code can be a result of an exhaust leak in the area of the cat, poor fuel quality, computer issues (though rare), or a bad sensor. While the idea behind cleaning out your own cat is reasonable, I would NEVER EVER EVER recommend putting lacquer thinner into a customer's car. The car is not designed to run off of it, and while I won't say it WILL cause problems, but there is a risk in burning something other than unleaded gasoline, and I am not willing to take that risk, or recommend it to a customer. I think my P0420 thread is coming long overdue.
  15. Sep 17, 2012 at 6:10 PM
    ToyoTaco02
    Scott
    Decatur,IL
    I was unaware that they did emissions testing anywhere in Illinois. By the way thanks to everyone for their responses. I think I am going to replace both sensors and go from there. Just trying to figure it out as we leave for Gatlinburg, TN on Saturday.
