How reliable is IFS long travel?
Discussion in 'Long Travel Suspension' started by JoshuaBrah, Aug 28, 2018.
  1. Oct 15, 2018 at 10:25 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    this previous post is in no way doing a comparison between companies, simply the way the spindle is bolting to the UCA is all i'm asking about.
  2. Oct 15, 2018 at 11:04 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    If your considering orientation based off the bolt orientation not the uniball itself then horizontal would have more available up and down movement
    Dalandser likes this.
  3. Oct 16, 2018 at 7:52 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Yeah, the naming convention is perhaps a bit unintuitive. Vertical uniball is when the bolt is horizontal. It makes sense if you think about it from the range of motion perspective. I.e. a vertical uniball configuration has more geometric freedom in the vertical plane and is limited in the horizontal plane.
    Masshole_And_His_Taco likes this.
