How Often Do You Rotate Your Tires??
Discussion in 'Wheels & Tires' started by JRod4928, Oct 15, 2012.
Poll closed Dec 14, 2012.
  1. 3000 Miles
    25 vote(s)
    9.1%
  2. 5000 Miles
    178 vote(s)
    65.0%
  3. 7500 Miles
    26 vote(s)
    9.5%
  4. 10000 Miles
    30 vote(s)
    10.9%
  5. Never
    15 vote(s)
    5.5%
  1. Oct 15, 2012 at 5:06 AM
    JRod4928
    JRod4928 [OP] Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    Note if you've had any issues with cupping/uneven tire wear and how many miles your tires have on them. :D
  2. Oct 15, 2012 at 5:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I rotate my tires every 5,000 miles, no sooner. I do notice cupping and I can't figure out what's causing it but it's not severe. I also only noticed cupping with both sets of my Cooper A/Ts, my summer highway tires don't seem to be having the same problem. The Cooper tires I have are the AT3's and I had the ATR's before them. My summer tires are Bridgestone Dueler H/T's.
  3. Oct 15, 2012 at 5:21 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Take a look at your alignment numbers and post them if you can, Pugga. I bet you have positive camber and toe. maybe a little toward the upper range of the factory allowable but still in spec.
  4. Oct 15, 2012 at 5:27 AM
    Pugga
    Massachusetts
    Nope, I've got good numbers. My caster was in the 1.6 - 1.7ish, toe and camber were very very close to 0. I'm not lifted very high so alignment really isn't an issue for me. The cupping is actually more noticable on the rear tires. The outter edge of the fronts gets chewed up but that's just from cornering harder than I should with a lifted truck on A/T's :eek:
  5. Oct 15, 2012 at 5:48 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Interesting. the guy who aligned my truck purposefully gave me some pos camber and toe for drivability but warned me that I'd have to rotate often to prevent cupping. Hopefully every 3000-5000 is enough? Based on your experience and having near 0 toe and camber, I might have worse cupping issues than you, Pugga. (Right most numbers are the final alignment numbers - basically in the middle of the recommended range)[​IMG]
  6. Oct 15, 2012 at 6:09 AM
    Pugga
    Massachusetts
    Those numbers don't look too bad in my opinion. Just keep an eye on the outside edge of the front tires, especially if you drive aggressively in corners. I wouldn't rotate them any sooner than 3,000 miles.
    The cupping I'm fighting is in the rear and I think it's caused by the drum being out of balance. The weights that are on the drum from the factory fell off and I think that's causing some cupping over time. My fronts will start to wear a little more on the outter edge (yours probably will also) but overall isn't bad.
    I don't think you'll have any real issues with your tires based on your alignment numbers.
  7. Oct 15, 2012 at 6:14 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    I have my tires rotated at each 5,000 mile servicing or 6 months.
  8. Oct 15, 2012 at 6:19 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    That's good to hear - i love the look and price of those tires. Glad i researched so much. Actually read a few of your threads before buying them, haha.
    Yeah i'd get the drum looked at - 100 bucks now might save you a few hundred later. Sometimes with unbalanced tires, or in your case a drum, you will get spotty and uneven wear, not necessairly cupping. So who knows if that is your issue or not...
    We may just have a high maintenance tire that requires frequent rotation. I've read a lot of posts inside and outside of TW that says cupping is a common problem. Oh well, it's a good habit to get into anyway. Looks like I'm going every oil change.
  9. Oct 15, 2012 at 6:20 AM
    Pugga
    Massachusetts
    I will admit, they are a nice looking tire! I'll put mine back on at the end of the month and store the highway tires. The truck just looks soo much meaner with the A/T's :D
  10. Oct 15, 2012 at 6:23 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Agreed :thumbsup:
  11. Oct 15, 2012 at 9:26 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Every time I go off road.
    I run 1 set of tires & wheels for commuting & one set for off road so every time I change out my tires they get rotated. No cupping or uneven wear on ether the Dungflops or the BFG KM2s.
    tacomarich likes this.
  12. Oct 15, 2012 at 10:00 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    How often do you off-road?
    I just sold my Dungflops haha
  13. Oct 15, 2012 at 10:43 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I never rotate my tires unless I see a wear problem, then I have the alignment checked. Usually any problem is from off road hitting stuff.
  14. Oct 15, 2012 at 11:04 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Ditto. Never rotate unless see uneven wear. Offroading usually tears them up first ha.
  15. Oct 15, 2012 at 2:24 PM
    4Wheelin4Banger
    Randy
    Not as often as I'd like to.
    Been too busy lately.
  16. Oct 15, 2012 at 7:36 PM
    hpvds
    hpvds Well-Known Member
    Manie
    Seattle, WA
    Barcelona Red 2010 4x4 Doublecab
    Ironman 4x4 FCP lift, ARB bumper, NL Dual bats, Skids and sliders
    I have a very similar problem. The tires that are on the rear are cupping (same model tire, cooper AT3's) and if I rotate them to the front, I get an awful driveline vibe that makes the truck unpleasant to drive. That said, I no longer rotate them because I can't stand the vibrations. They've only been on the truck for about 15,000 miles and the vibrations showed up for the first time after they were rotated (with the oil change). It went away after the next rotation, and came back the next time again so, the most recent time, I just un-rotated them and left it be.
    Is it possible that at least one of those tires may have a defect from the factory?
  17. Oct 15, 2012 at 7:45 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    I rotate mine every other oil change..i do alot of turns, so i try and keep them so they evenly wear
    jonnytacoo likes this.
  18. Oct 15, 2012 at 7:50 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Every oil change. Had cupping problems with the factory alignment. Lifted it, corrected the alignment, no problems since.
  19. Oct 15, 2012 at 8:53 PM
    Cactus Mike
    Cactus Mike Member
    Scottsdale, Arizona
    TRD Sport, 4X4, Green
    weather tech mats, rubber bed & tailgate mats, seat covers and bed cover in route.
    I rotate every 5,000 miles. At 42500, I picked up a 2" bolt thru the right rear. I believe I could have gotten 50,000 miles but I decided to put on the high end Michelins' with the 80,000 mile tread wear guarantee.
    Now, no more tire talk for three or four years.
  20. Oct 15, 2012 at 10:30 PM
    Bassetdad
    Bassetdad What if God Smoked Cannabis
    Harrison, Ohio
    2001 De-Badged SR5 Access Cab 2.7 / 5m
    Access Tononu Cover AFE Pro-Dry S Drop-in Filter American Mag Wheels Bilstein 5100's Black Billet Grill Clear Taillights Perma-Tech sprayed Kennesaw Mountain Rear Bumper Michelin Tires PIAA Driving Lights PIAA Headlights Piaa Tail Light Bulbs Tinted Windows – 50% Toytech AAL URD Short Shifter Tranny - Mobil 1 Engine - Mobil 1 Custom Three Bike In Bed Rack New Toyota Undercoated Frame Clear LED 3rd Brake Light
    I have my tires rotated every 5,000 miles
