How Often Do You All Clean The MAF?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sprig, Feb 12, 2024.
  1. Feb 12, 2024 at 4:16 PM
    Sprig
    Sprig [OP] Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I’ve got 111,000 miles on my truck and have cleaned the MAF 3 times. The last time was today. Each time it looked clean but I cleaned it anyway. I’ve been told some people clean them every time they replace the air filter. Based on how mine looked each time I’d say every 20,000 to 30,000 is fine. What say you?
  2. Feb 12, 2024 at 4:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I would say it "shouldn't" need cleaning if your air filter is doing it's job.
    The throttle body should be cleaned though IMO, I do mine every 30k when I change the plugs.
    Sprig[OP] likes this.
  3. Feb 12, 2024 at 4:28 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Every 25-30K miles. Essentially when I do a spark plug and fluids maintenance.
    Sprig[OP] and hdn4space like this.
  4. Feb 13, 2024 at 7:10 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My truck is 17 years old with 244,000 miles. I don't even know if my truck has one and if it does don't know where it is. I know there is one on my newer F150, but I've never cleaned it in 10 years and 142,000 miles. Both trucks still run like new.
  5. Feb 13, 2024 at 7:13 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Never. I figure it’s more likely to get damaged if I keep trying to clean it.
    TireFire, camaro322hp and Sprig[OP] like this.
  6. Feb 13, 2024 at 7:30 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    I do my once a year as a yearly maintenance item......air filter once every two. It will depend on environmental conditions (dusty dry) will all be factors. Sometime it will show up as bad gas mileage - takes only a few minutes to clean.
    Stay Safe Everyone and drive smart!
    Go Team Tacoma World - you guys Rock!
  7. Feb 14, 2024 at 7:39 AM
    TacoTuesday1
    FL
    I wonder what the easiest way to clean the TB is. And without damaging it, as a full soak might do given the electronic components it involves.
    last time probably just got brakleen on a shop rag and wiped it a bunch of times until carbon stopped showing up on the rag, tilting the butterfly plate open with my other hand, then key reset adaption after if possible
  8. Feb 14, 2024 at 7:39 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    About once every 3 years ish
  9. Feb 14, 2024 at 8:18 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    never cleaned mine
    did air cleaner and plugs at 200k
  10. Feb 14, 2024 at 8:50 AM
    IL Capo
    Sidney BC Canada
