How negative can a offset go before it effects performance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrWortWort, Mar 18, 2023.
  1. Mar 18, 2023 at 11:41 AM
    MrWortWort
    MrWortWort [OP] Well-Known Member
    2021 SR Access Cab Tacoma
    I want to add negative offset rims
    I wondering how far they can go before it cause negative effects to performance like steering and cause more wear and tear to parts
  2. Mar 18, 2023 at 11:49 AM
    MrWortWort
    I'm thinking going -18 rims
  3. Mar 18, 2023 at 11:59 AM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    You'll be totally fine.
    People go as far as putting 1.25" spacers on 0 offset wheels which is basically like running a -32 offset wheel and they don't seem to change much in terms of wear and tear.
    JFriday1 likes this.
  4. Mar 18, 2023 at 2:59 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    I’m running 0 offset and I have about an inch of poke which is plenty in my opinion. Lots of people run negative offset just be ready to deal with it depending on your tire size.
    Rusty66 likes this.
  5. Mar 18, 2023 at 5:36 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    that is one busy wheel
    MAVEN4, jmneill, drizzoh and 6 others like this.
  6. Mar 18, 2023 at 6:43 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    And -offset means the wheel sticks out further, correct?
    El Tano and Ballz like this.
  7. Mar 18, 2023 at 6:57 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I run -10 and I noticed improved handling until I put taller and more aggressive tires. The offset felt more stable but the taller tires give it a little twitch comparatively
    tonered likes this.
  8. Mar 18, 2023 at 7:18 PM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    So look at it this way. 23’ taco pro stock is ET25, 0 offset is 25 mm outwards, -10 is 35 mm outwards. I’ve seen some at 18 which would be -7 mm outwards from the start of 25. Get it now?!?
  9. Mar 18, 2023 at 9:19 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Check this out, it helped me decide what offset and it worked out perfect. Zero offset is when the mounting surface is the actual centerline of the wheel.
  10. Mar 19, 2023 at 7:26 AM
    burgershot
    burgershot Well-Known Member
    :puke:
  11. Mar 19, 2023 at 7:38 AM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    0 offset on mine..1" poke..ended up putting mud flaps on because it throws water,mud and debris all over the sides.
    It does may the truck look better though.
  12. Mar 19, 2023 at 7:53 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    You will very rarely see anything outside of a positive offset on anything rolling out of the factory. I like a 0 or negative offset wheel, but I don't think any vehicles performance is going to be positively effected by a negative offset. You might find some increased stability, or need the clearance for shocks or brakes or whatever with a negative offset or spacer. The stance also looks better IMO with a negative offset wheel, but I don't think an OEM or OEM+ truck is going perform as good as it would with the positive offset that came from the factory. I wouldn't let that stop you from going with a negative offset if that's what you want or need.
  13. Mar 19, 2023 at 8:12 AM
    Rusty66
    Rhode Island
    There’s geometry in scrub radius that changes when you change offset. The truck is engineered with a specific scub radius. Personally I don’t think a small change will be noticeable but if you are going from +30 to -30 you may be messing with steering characteristics and (allegedly) affecting the loading if the wheel bearing which (allegedly) may affect bearing life. I have no personal proof of these claims but this info is out there. On my truck I used 0 offset and I think the truck is LESS sensitive to road crown, but that could be the tire not offset affecting this.
    DeuceDeuceBravo and BC Hunter like this.
  14. Mar 19, 2023 at 12:01 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Beauty is in the eye of the beholder.
    BC Hunter and petethemeat like this.
  15. Mar 19, 2023 at 1:05 PM
    Unit59
    Unit59 Keystone State
    Craig
    East Central PA
    2023 Tacoma TRD OR
    One thing to consider is your local laws and getting your truck inspected. Some states don't allow tires sticking out past the wheel well. Most law enforcement might look the other way but it could become an issue if you get stopped for another reason. I'm just saying it's something to consider.
    Vmax540 and BC Hunter like this.
  16. Mar 19, 2023 at 6:56 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    At a -18 you will be in range of a cab chop or at the least a crafty alignment if your on stock tires and only running on street. I ran a +1 for 2 years before jumping to a -25 and honestly it has to be the best overall fitment. Not rubbing issues upto a 285 with a good alignment. It's agressive enough to look good but not so far that your flinging rocks down the side of the truck
    luked643, BC Hunter and kas2828 like this.
  17. Mar 19, 2023 at 9:19 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Besides the issues identified by others concerning the effects of moving your wheels outboard by nearly two inches, you might consider that those wheels have a larger bore diameter. (112.1 mm versus the OEM 106.1)
    You will lose the stability of the hub-centric support, and will be relying solely on the nuts to support and centre your wheels.
    If you aren’t getting a lot of impact forces on the wheels (mainly on-road driving) then perhaps that’s OK. I’d be curious if other people have gone with oversized bores and can comment?
  18. Mar 19, 2023 at 9:28 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Negative offset wears out your bearings quicker, but nothing that can’t be dealt with if you check wheel play from time to time.
    MrWortWort[OP] likes this.
  19. Mar 20, 2023 at 12:57 AM
    Ballz
    Bfe SF Bay
    That’s’ where hubcentric rings come into play for the new wheels from 112 to 106.1
    But I do agree on going to far out or negative offset as it will play havoc to wheel bearings.
    BC Hunter[QUOTED] likes this.
  20. Mar 20, 2023 at 4:37 AM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    I initially went with -10 offset wheels but when I switched to 0 offset the truck handled much better.
    BC Hunter and MrWortWort[OP] like this.
