How much voltage does TACO alternator puts out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by egres, Feb 15, 2014.
  1. Feb 15, 2014 at 12:50 PM
    egres
    egres [OP] Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    I have 2.7L 5 lug.
    How much amps does truck consumers idling?
    Does alternator produces constant power or accessory belt spins faster when driving and alternator produces more power. Thank you.
  2. Feb 15, 2014 at 3:17 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Well for the first question it depends on what you have turned on. For the second question you usually get about 50 to 60% of the rated output at idle. Here is a link that explains all this and even has a chart with rpm and amperage break down.
    http://www.venselenterprises.com/techtipsfromdick_files/alternators.pdf
  3. Feb 15, 2014 at 4:59 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    14.3 or so just like every other car out there. If you meant to ask about amps it depends if you have the towing package or not.
  4. Feb 15, 2014 at 5:25 PM
    gearcruncher
    Canadain bumper technician
  5. Feb 15, 2014 at 5:28 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Voltage should be around 14.4. Not sure on amperage.
  6. Feb 15, 2014 at 6:22 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    On my 2012 Off-Road w/towing package it has a 130 amp alternator. It also has the 400w inverter for the 110v outlet in the bed.
  7. Feb 17, 2014 at 1:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Those that are saying that 14.XX volts may want to recheck. I have looked at many and have never seen one that is charging greater than 14 VDC and they are usually reading about 13.7X VDC. This is normal.
  8. Feb 17, 2014 at 5:48 AM
    vstrom
    vstrom Well-Known Member
    It's a 14v system. Almost all cars/trucks in North America are a 14v.. although I think big rigs use a 26v system.
    Batteries are 12 volts so the vehicles system will be 14v so it can charge the battery.
    If you're reading 13.7.. you're probably reading off the battery while the truck is running.. and that will fluctuate a bit with lights/ fans/ ac etc.
    Read it right off your alternator will give you the truest voltage.
    And I think the amperage for the alternator is 130.. But Im not sure about that.
  9. Feb 17, 2014 at 6:19 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The amps change on demand the amp output is controlled by the field voltage. This is the reason alt. systems use a voltage gauge and not an amp gauge if the voltage is there so are the amps. When you start to load the system down more voltage is applied to the field so the output voltage remains pretty much the same but the amp output increases.The max amp output is by design so the output is for the application.
  10. Feb 17, 2014 at 7:05 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    2007 here and my voltage is 14.7/.6 V as well. (Denso Tow package 130 Amp alternator. My "other" Toyota has 180 Amp Alternator but only gets 13.4 V at idle. I was going to rebuild alternator to see if I can bring to 14.0 V.
    I think what is happening this is another case when Toyota way overbuild alternator for the truck. We dont have as much electronics as other Toyotas so 130 Amp alternator with 27F battery is large. That Alternator at idle has nothing to do.
