How much power will I gain with the 4.0 supercharger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yotakips, Apr 19, 2016.
  1. Apr 19, 2016 at 10:26 AM
    yotakips
    yotakips [OP] Member
    2008 Tacoma TRD off road
    Lift, flomaster exhaust
    I'm really considering installing a supercharger on my 2008 4.0 Tacoma. I live in the mountains of Colorado above 7,000 ft and am constantly driving up steep grades. I always find my myself wishing for more power so my question is how much more horse power and torque can I expect to get with the supercharger?
  2. Apr 19, 2016 at 10:39 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    It would give you the potential to make +300HP, but when the unit is now ~$6k and you'll want to add some more to it like fuel pump, smaller puller, intake, headers, heavy clutch its getting hefty. I can not justify the expense, and have not seen anyone install the new magnussen branded supercharger so I think others feel the same.
    I say boycott till its <$4K!
    If money flows freely go for it, plenty love having it.
    ChadsPride likes this.
  3. Apr 19, 2016 at 10:40 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW! It is rated at +69hp and +69ft/lbs. Puts the truck at 305hp. You can easily add more by adding the smaller URD 2.85 pulley to spin it faster for higher boost.
  4. Apr 19, 2016 at 10:43 AM
    airkewled
    airkewled Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
  5. Apr 19, 2016 at 10:44 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Yeah its crazy how the 2nd gen Tacoma s/c is twice the price of the first gen. I love mine, but it came with my truck....I honestly don't know if I'd drop that kind of cash on getting it for myself though. Like mentioned above, it's not just the supercharger you need to worry about getting. You'll need to upgrade your fuel system at least. Headers aren't necessary but they do sound awesome ;)
    edit: Just read through a post that @airkewled linked to up above, apparently the 4.0l stock fuel system can handle the s/c without any upgrades, so that's a plus.
  6. Apr 19, 2016 at 10:48 AM
    Pigpen
    Northwest Montana
    Regear
  7. Apr 19, 2016 at 10:52 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I did some rough calculations that should be right but anyone feel free to correct me.
    At 7000 feet above sea level, the air is thinner and generally speaking you're only getting around 77% of the power you'd get if you were at sea level. The Toyota SC will give you approximately a 30% boost over stock so you'd be getting the equivalent of stock performance at high altitude. (before you mess around with the boost)
    I don't think the money would be worth it since you're not really gaining much in the big picture...
    yotakips[OP] likes this.
  8. Apr 19, 2016 at 10:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    At a roughly calculated $85/hp, it's not a bargain! ($6,000/70hp)
    Losing 700#s of weight would be about the HP equivalent. Not that that is practical or doable, but it does create perspective.
    Torspd likes this.
  9. Apr 19, 2016 at 10:58 AM
    findingthingsout
    midwest
    So at some point "they" have to realize we are not going to pay the $6K, right? Has anyone one installed the magnuson yet? The URD is now the more "practical" unit.
  10. Apr 19, 2016 at 11:05 AM
    eon_blue
    Azusa, CA
    Just curious, was the black TRD supercharger for first gens always the same price ($3k)? Or did it start out more expensive and go down over time?
  11. Apr 19, 2016 at 12:08 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is because the 2nd gens is a fully integrated system, far more sophisticated than the 1st gen. It runs more boost, utilizes a liquid to air intercooler and replaces all the injectors with proper high flow units rather than using a 7th injector to attempt to make up the deficiency of the stock system. It also does not suffer from the pinging issues like the 1st gen units. So it isn't surprising it costs significantly more.
    Edit: I should add the 2nd gen SC used to be cheaper when it was under TRD.
    Kolter45, PNW15, Torspd and 1 other person like this.
  12. Apr 19, 2016 at 12:17 PM
    eon_blue
    Azusa, CA
    I learned something new today, thank you sir
    crashnburn80[QUOTED] likes this.
  13. Apr 19, 2016 at 12:43 PM
    SoCalSteve
    SoCalSteve Sunshine Tax
    San Diego
    2017 F150 XLT
    This gets my vote as well.
    Like another poster said, the supercharger would only bring back the power that elevation has taken away. Lower gearing is also more cost effective to a blower.... ~ $3000 from what I have seen.
  14. Apr 19, 2016 at 12:47 PM
    Pigpen
    Northwest Montana
    Go find a wrecked 2.7 4x4. It'll have the 4.10 gears you want. Just buy the clamshell and 3rd member. Easy swap and the power you want for maybe $1k if you have a mechanic do the work.
  15. Apr 19, 2016 at 3:47 PM
    Springs719
    Springs719 Well-Known Member
    Brett
    08trdoffroad
    I have the URD stage 2 supercharger and live in Colorado Springs elevation is 6,035 and it halls ass in town. But I also go up the pass to fish lakes in the mountains or visit in laws in Divide and they sit at 9,165. The power is still great at the higher elevations.
  16. Apr 19, 2016 at 3:51 PM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    I also vote regear.
    Cheaper route for hills.
    RJM
  17. Apr 26, 2016 at 3:37 AM
    yotakips
    Thanks everyone it really doesn't seem like it would be worth it for six grand and everything else I would have to do.
  18. Apr 26, 2016 at 6:32 AM
    K.Ray
    K.Ray Well-Known Member
    East TN
    2016 Toyota Tacoma TRD Off-Road, 6sp Manual, Quicksand
    None
    I bought my truck with the supercharger accessory factory badge under the hood. Sadly, no supercharger to be found. :( I bet it would be nice to have with the added weight of expo gear and changing elevation over the course of a trip.
  19. Aug 7, 2021 at 8:13 AM
    jacpa
    jacpa Well-Known Member
    Jim
    2021 4Runner TRD ORP
    I am between supercharging my Tacoma (currently at 97k miles) and selling it while the market is hot and buying a newer tundra later this year with the 5.7L
    For those of you with superchargers- how noticeable is the power gain? Do you have to run premium now?
  20. Aug 7, 2021 at 8:18 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    how many total miles on engine
    Ur truck will run better a direct result Ur wallet is lighter
    if U hae access to a good mechanic......a very good tune ( they dont always take )......& a dyno
    chk engine b4 SC................then of course along the way to optimize the tune
    then after all is said/done
    after a few thousand spent.....................hopefully results & expectations reside in same zip code
