how much play should cv axle have
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steelfed, May 2, 2017.
  1. May 2, 2017 at 10:05 AM
    steelfed
    steelfed [OP] Member
    2006 Tacoma Base 4x4 2.7
    im trying to find source of a pretty bad vibration and noise. wheel bearings seem ok, driveshaft isnt sloppy, but the CV axle on the driver's side has a quarter to half inch of lateral movement. Is this normal or sign CV axle needs replacing?
  2. May 2, 2017 at 10:08 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Are you stock or lifted???
  3. May 2, 2017 at 10:10 AM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    What year tacoma? And what do you mean by lateral movement?
  4. May 2, 2017 at 10:12 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hartford likes this.
  5. May 2, 2017 at 10:13 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I am also curious of this. My passenger side CV has much less play than the drivers side. My truck is a completely stock '13. It makes a loud metal on metal noise when going over bumps traveling around 25-35 mph. Also makes the noise when braking hard. Im pretty sure its the play in my driver's side cv axle near the front diff. Any thoughts?
    Edited to add: I don't have the vibration or groaning noise that is often associated with the needle bearing and it makes this metal on metal noise in 2wd & 4wd. Could this still be the needle bearing?
  6. May 2, 2017 at 10:19 AM
    Boneretreiver
    Tom
    Eastern WA.
    If you have a significant amount of up and down play right where the cv axle goes into the differential, then you would be best to replace the needle bearing in the diff that supports the cv axle. If you select 4wheel drive and that noise you are having goes away or is reduced significantly, then for sure that's your problem. Eatsleeptacos, 2posts up, has the link. I did this ecgs bushing fix over a year ago and zero issues since. If you work on your own truck, you should be able to do this fairly easily. Just review the link and watch the video a few times. And there are, I 'm sure still plenty of tools available from folks here. My 2cents.
  7. May 2, 2017 at 10:20 AM
    steelfed
    its an 06. if you grab it with your hand you can move it side to side
  8. May 2, 2017 at 10:22 AM
    Boneretreiver
    Tom
    Eastern WA.
    Side to side, bad needle bearing. In and out, something else all together.
  9. May 2, 2017 at 10:24 AM
    steelfed
    bone stock
  10. May 2, 2017 at 10:25 AM
    steelfed
    driver side is side to side, passenger side is a tiny amount of in and out
  11. May 2, 2017 at 10:30 AM
    Boneretreiver
    Tom
    Eastern WA.
    Click on eatsleeptacos link. Read it. In the first write up, there is a link to east coast gear and supply. They have designed a bushing to replace the needle bearing. Many folks have done it and it works! Read more on the link if you want, you will deff know if this is your problem or not. Good luck.
    EatSleepTacos likes this.
  12. May 2, 2017 at 10:33 AM
    steelfed
    thank you!
  13. May 2, 2017 at 10:37 AM
    Boneretreiver
    Tom
    Eastern WA.
    In my experience, the noise almost always goes away in 4wd. So, I believe you have somethingelse going on. Not for certain. Maybe you can secure a phone under there and video it while duplicating the noise. Many have done that here and it is very helpful. If you upload it, most assured someone will get you on the fix. Good luck.
    BassAckwards[QUOTED] likes this.
  14. May 2, 2017 at 11:06 AM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Op sounds like he has the bad needle bearing.
    Yours sounds like worn out LCA bushing. The bushings where the lower control arm mounts to the frame.
  15. May 2, 2017 at 11:18 AM
    BassAckwards
    Is this possible on a truck with 24k miles? Seems like it should last quite a bit longer than this
  16. May 2, 2017 at 12:31 PM
    Hartford
    Maine
    2011 Acc Cab 5spd
    Maybe, maybe not. I think mine started doing it around then. Would happen a lot of I was in reverse with the wheels turned all the way. Hitting bumps at slower speeds. The bolts might not be torqued to spec, 100 ftlbs. Could be something else but if it's a metal on metal clunk I'll bet it isn't the CV. They should last way longer than the bushings in the LCA.
  17. May 2, 2017 at 12:57 PM
    BassAckwards
    Thanks for the input, ill try reversing later while turning to see if I can replicate the noise. Its strange though because I live on a rock road and I never hear the noise. its only when i'm on pavement and I hit a bump going 20-30 or when i'm going at least 30-40 and then start braking hard.
