How much oil should come out? Anybody measure?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcayce, Dec 28, 2011.
  1. Dec 28, 2011 at 1:11 PM
    jcayce
    jcayce [OP] Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    I'm waiting at the mall for my wife and was wondering how much oil should I be taking out during an oil change. We went to Austin yesterday and I left the truck draining from 11:00 am to 11:00 pm. When I dumped the old oil back into the new oil's leftover jug it filled it completely to the top with no room to spare. When you buy the oil, the jug is not filled to the top, there is actually quite a bit of room leftover.
    So the question is, if we don't ever take out 5.5 but put 5.5 back in, isn't there really more than 5.5? Especially if we do not let it drain for 12 hours?
    I've actually noticed this for years on several different vehicles but never put any serious thought to it.
  2. Dec 28, 2011 at 1:15 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Do not know the exact amount, but it will not hurt the engine to put in 6 quarts. I have never let a vehicle drain for 12 hours, so it is likely, a little more then 5.5 quarts, drained out of your truck.
  3. Dec 28, 2011 at 1:15 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    unless your truck uses oil.....the same amount should come back out.i always use 5qts and that fills the jug back up
  4. Dec 28, 2011 at 1:19 PM
    Aw9d
    Aw9d That one guy
    are you draining your oil filter as well? Is the oil filter off for 12 hours?
  5. Dec 28, 2011 at 1:32 PM
    Sunner
    Sunner Well-Known Member
    Do you drain for 12 hours everytime? You probably got more out this time, I usually only drain for 30mins at the most, should I be letting it sit longer?
  6. Dec 28, 2011 at 1:39 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    no
    this
  7. Dec 28, 2011 at 1:44 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    The filter usually holds some oil too.
  8. Dec 28, 2011 at 7:28 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    This includes the oil filter. Oil filter was off the last 30 minutes draining into the used oil pan. The filter seems to drain better if you leave it upside down, turn it right side up, repeat.
    I was actually expecting more oil than I got. Although the 5qt jugs are not completely full to the top when I buy them, chances are that there is room for 1/2 a quart which would make sense why it filled completely to the top this time.
    I typically only let the oil drain for 30 minutes max. When I do this, the 5 qt jug only fills back up to about where the new 5qts were. The other 1/2 a quart must be in the block, I was just wondering if anyone else noticed this and did not add the .5 of the 5.5 as a consideration.
    I really put too much though into this.
  9. Dec 28, 2011 at 7:33 PM
    jandrews
    '09 FourDubDee TRD OR
    Did you drain warm oil out of the vehicle? Thermal expansion.
    Roughly. A recently run engine (I warm mine to temp before oil changes) will have some of its oil fill coating engine parts and you won't get every last drop out. But it's a small enough difference to not matter.
    This. Jesus, 12 hours? I don't have that kind of patience.
    I typically underfill by about 1/4 of a qt. because it's better to be slightly low than overfilled. Really though, ToMoCo has built enough of a tolerance in that it shouldn't be an issue.
    I would agree ;)
  10. Dec 28, 2011 at 7:36 PM
    unccpathfinder
    unccpathfinder Member
    Sparkle City, SC
    08 SR5, Double Cab, v6, 6 sp MT
    Out of my 4.0 today I got ~5 plus whatever was in the filter and put 5.5 back in...I was also about 1000 miles overdue
  11. Dec 28, 2011 at 7:44 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Yyyyeah. Probably. :D
  12. Dec 30, 2011 at 6:56 PM
    seanmccarthy1
    seanmccarthy1 Member
    massachusetts
    05 sr5
    12 hours ???? Relax just an oil change.....
  13. Dec 31, 2011 at 3:25 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    The truck was just sitting in the garage all day anyways, I had nothing to lose and was not inconvenienced in anyway.
    And yeah, it's just an oil change. The one thing we do not want the grease jockeys at quick oil change places touching, not even the dealer. Many of us didn't even bother to take Toyota up on their free maintenance offer because we did not trust their lack of attention to any detail at all.
  14. Dec 31, 2011 at 3:38 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    i usually drain take off the filter after its drained. and then clean my tools up cause i already have oil on them lol (15mins or so) then take some fresh oil pour some in till it comes out of the drain hole. plug the hole, put on new filter. add oil. start her up check for leaks check oil level. if its all good pack it up
  15. Dec 31, 2011 at 3:57 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I've noticed this with mine... I put 5.5 qts in and only get the 5 gal jug full out.
    There's a thread around here where toyota says it's normal to use oil. Can't find the thread right now...
  16. Dec 31, 2011 at 4:30 PM
    ImpulseRed008
    Susan
    SC
    I thought he was putting 5.5 qts in and getting less out :confused:
  17. Dec 31, 2011 at 4:33 PM
    ImpulseRed008
    Susan
    SC
    I saw that... but "assumed" he was also adding the other .5 qt like the truck needs :notsure:
  18. Dec 31, 2011 at 8:14 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    I got a completely full 5 quart Mobil 1 Syn jug worth out this time. Right up to the top of the jug. I normally only get right up to where the 5 qt mark is on the side of the jug which is quite a bit less than all the way up to the top.
    I always refill with one 5 quart jug and 1/2 of a quart bottle.
    Sorry for the confusion. And the pointless thread. Truthfully most of my threads are pointless. I will just revert back to lurking.
  19. Dec 31, 2011 at 9:05 PM
    GotLift37
    North East AL
    07 4Runner 4WD
    that is my procedure also with the mobil1 synthetic. your normal procedure is the same as mine. i guess its sludge building up on the inside of my engine or the oil goes into my drain pan and gets stuck in there somewhere with all the other build up and gunk in the drain pan/oil holder. by the way this is all on an 07 4runner v6.. same engine as the v6 tacomas
    and i will go back onto my lurking lol
  20. Jan 1, 2012 at 8:27 AM
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    i WOULD RATHER BE A LITTLE LOW THEN OVERFILLED TOO MUCH OIL IS A REALLY BAD THING IN AN ENGINE MY 4.0 ALWAYS TAKES 5 QUARTS OR A HAIR MORE PUTS IT RIGHT ON FULL I WOULD NOT DUMP IN 6. 5.2 IS THE SUGGESTED REFILL W FILTER CHANGE IN MY BOOK.
