How much drop on your hitch ball mount.
Discussion in 'Towing' started by JUJtacoma2010, Apr 11, 2013.
  1. Apr 11, 2013 at 1:07 PM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    I have a boat that I tow and recently bought a 4 inches drop reese hitch ball mount. is this the normall for a tacoma truck? does any one use a 2inch drop?
  2. Apr 11, 2013 at 1:20 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I used to 2" when I was at stock height and that was perfect for my boat trailer. Had to get a bigger drop when I lifted the truck. I don't remember if I went 3.5 or 4.
  3. Apr 11, 2013 at 1:23 PM
    medic2230
    Murph
    Bama! Roll Tide
    Mine has a 3" lift with 285's and I use a 5 1/4" drop.
  4. Apr 11, 2013 at 1:24 PM
    muddin
    muddin Well-Known Member
    PA
    2010 Tacoma DC TRD OR
    Bilstein 5100's on all four with some OME 885x's. Brute Force Fab front bumper. Warn winch. Koenig countersteers wrapped with duratracs.
    lifted 3inches on 33's and use a 4 inch drop
  5. Apr 11, 2013 at 1:24 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    Depends on the trailer really.
    Either measure or eyeball to get the trailer level
  6. Apr 11, 2013 at 1:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There is no 'normal' amount of drop for any truck. The amount of drop is determined by the trailer you are towing and can very greatly. You want the trailer to tow level or with an ever so slight rake so choose the correct drop to make it happen.
  7. Apr 11, 2013 at 7:07 PM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    On a boat you want the front up so it does not hold water.
    You could add several hundred lbs in a storm fast.
  8. Apr 12, 2013 at 7:25 AM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    Use 2" drop hitch on a boat, travel trailer, & motorcycle trailer.
    Found I get a "little" more power & "slightly" better fuel economy towing the 1500lb travel trailer with a 2" drop compared to a 3/4" rise. Must be less wind resistance with the CampLite 11RD TT front slightly lower than the rear.
    Using the 2" drop on the boat & motorcycle trailers has the front of the trailers slightly higher than the rear. The boat & motorcycle trailers have much less wind resistance compared to the tall TT.
  9. Aug 7, 2013 at 1:58 PM
    4bangeronabudget
    4bangeronabudget Well-Known Member
    Maine
    08 2.7l base
    Blacked out badges Tough country lift Scs stealth 6 wheels LEDs Warn transformer w/ light bar winch mount Volant ram air intake Reese hitch Timbrens 5100s Warn 9500 winch Skids
    Thos is true i always put the trailer on the truck and measure the front then measure the back i take the front measurement and subtract the back that number is the amount of drop to make the trailer level. A negative number means you need less drop, or a lift
  10. Aug 7, 2013 at 2:01 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
