How much does tire weight really affect performance/mpg?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crimson Flam3s, Mar 15, 2019.
  1. Mar 15, 2019 at 11:25 AM
    Crimson Flam3s
    Crimson Flam3s [OP] Well-Known Member
    Here is my dilemma, I got a great deal on a set of Falken Wildpeaks 265 70 17 @ 47 pounds
    I currently run BFG Rugged Terrains 265/65/17 which get great MPG and are about 4-5 pounds lighter, how noticeable would this be?
    I drive a lot of miles every year and I don't wanna bog down performance too much. I read about the Hankook Dynapro RF10 having decent rugged looks and being about 37-40 pounds depending If I get 65's or 70's so not sure if it would be worth looking into a set of those and selling these which could potentially be 7-9 pounds lighter. Any other suggestion for a set that's around the a similar pricepoint as the Falkens?
  2. Mar 15, 2019 at 11:30 AM
    dal3_gribble
    dal3_gribble Well-Known Member
    Crew Cab SB TRD Offroad
    Everything else being the same, you'll probably take around a 5% mileage hit going up in size and weight.
    When I went from 265/70R16s OEMs to 265/75/R16 Wildpeaks, I saw a very small mileage drop, definitely under 5% so you could probably expect the same. Make sure you look at the OD of each tire and calculate the conversion so you track mileage right. Your MPGs will be off by the % difference in tire change.
  3. Mar 15, 2019 at 11:43 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Here is a great source of tire info for you... in your situation, current tire is in position #1 and proposed change is position #2... the circumference will be 3.3% larger.
    CaptainBart45 likes this.
  4. Mar 15, 2019 at 11:43 AM
    Hans7
    Hans7 Well-Known Member
    2017 TRD OR 4X4, DCSB, MGM
    TRD Pro fogs, tint, OV Tuned 1.05, TRD Pro grille, Winjet Taillights, Meso Custom turn signals, Rhino lined rear bumper, dipped emblems, F5 3.5 BS wheels, Wrangler UltraTerrain 32s, Radflo 2.5 COs/All Pro leafs w/Fox rears, custom bedrack w/ Smittybilt RTT/ditch and bar lights/ pelican hardcase/shovel.
    Keeping unsprung weight as low as possible was a big consideration for me. I went with the Wrangler Ultra Terrains sold by @Discount Tire Direct over the Falken WPs due to them being lighter. No noticeable road noise, great wet/dry traction, deep tread/aggressive sidewall, lightweight (265/75/16 SL is 40lbs) and good looks!
    I was in the same boat as you for a looong time trying to decide on a AT tire, these fit the bill perfectly.
  5. Mar 15, 2019 at 11:50 AM
    ryager
    ryager Well-Known Member
    2017 Orange TRD OR
  6. Mar 15, 2019 at 11:54 AM
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    I'm at the age that I do not worry about the price of gas. I fill-up and don't even think about it....in fact i never bother looking at the total.
  7. Mar 15, 2019 at 12:00 PM
    Crimson Flam3s
    Thanks for the links guys and MPG wasn't my main concern, but the power loss/gain when I could get tires around 7 pounds lighter although I just did a quick calc on a website and losing 1-1.5mpg would mean around $400 more in gas during the lifetime of these tires so I thought why not pay for that upfront for lighter and potentially higher quality tires..
    Tacoma3rdGen likes this.
  8. Mar 15, 2019 at 12:03 PM
    DisneyFan91
    DisneyFan91 Well-Known Member
    Fla., Us
    2018 SR 2.7 DCSB
    The heavier it is the harder it is to spin up, and the harder it is to slow down. How much, idk. But once spinning, a heavier tire will have more momentum. So that energy isn't all lost.
    All of this is to say, it probably matters more if you do a lot of City driving / stop-and-go and less if it's mostly highway.
    TAC1, TACO TM, AKGSD and 3 others like this.
  9. Mar 15, 2019 at 12:08 PM
    FJRrider
    FJRrider Well-Known Member
    Pacific Northwest
    2012 DCSB
    Someday...
  10. Mar 15, 2019 at 12:11 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Cool story bro
    racer_kmk, AZDre, Burro09 and 14 others like this.
  11. Mar 15, 2019 at 12:11 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    https://www.cjponyparts.com/resources/what-is-unsprung-weight
    That article deals with shaving 200 lbs off of a race car's unsprung weight in order to make your car 1/10 of a car length faster in the 1/4 mile. Saving 4-5, even 10-15 lbs per wheel won't be noticeable at all on your truck, it is all theoretical. I'm on my 5th set of tires for my 07 Tacoma. I've had P series tires that weighed 38 lbs each, E rated tires that weighed 53 lbs as well as some in between. My fuel mileage and acceleration are the same today as it was 195,000 miles and 12 years ago.
    Going to a larger diameter tire robs power and may reduce fuel mileage. It also makes the brakes work harder. But generally if you go no more than 1 size up it isn't enough to notice. Tires with aggressive mud tread have a very high rolling resistance compared to All Terrain or street tires which will hurt fuel mileage. They don't make lightweight P series tires with aggressive mud tread.
    The problem is that most people who go up 1-2 sizes, AND to to an aggressive tread tire and see a reduction in fuel mileage. But the loss of performance is because of the larger size and tread pattern. The fact that the tire is heavier is not the reason. As long as you stay with a moderate All Terrain tire the difference is too small to notice.
    Vo0Do0, AKGSD, DerekV87 and 1 other person like this.
  12. Mar 15, 2019 at 12:13 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Don't forget they make an LT version of the tire. You can look at same exact sizes except one may be an LT version (higher ply rating) and that could affect the rolling resistance which would affect mpg.
  13. Mar 15, 2019 at 12:22 PM
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    I'm not sure about exact MPG difference but tire/wheel weight definitely affects the performance. I noticed a slight difference when I went from the stock 24lb wheels to SCS F5s (19lb.) It didn't make the truck a race car or anything but the acceleration is improved.
  14. Mar 15, 2019 at 12:25 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Just saying but I went from 265/70R16 (stock OR) to 285/75R16 E load tires (33s) and according to old school math I get slightly better MPG
    Regards to performance the bigger heavier tires make it sluggish off the line
  15. Mar 15, 2019 at 12:29 PM
    Crimson Flam3s
    Thanks, I was literally reading that article just now, and my fear was that I had read somewhere that each pound of unsprung weight was equivalent to 7-10 pounds of sprung weight, but 3 pounds sounds more reasonable if true. Thread pattern also has a huge effect in it.
  16. Mar 15, 2019 at 2:38 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    265/70/17 Toyo open country at2 SL tires are like 38 pounds. I have them on my TRD pro Sema wheels and the combo is lighter than my factory set. I didn't notice any hit on mileage.
  17. Mar 15, 2019 at 2:40 PM
    s.e.charles
    s.e.charles Well-Known Member
    beautiful wheel
    trilogymac and Canaduke like this.
  18. Mar 15, 2019 at 2:41 PM
    s.e.charles
  19. Mar 15, 2019 at 3:23 PM
    Hans7
    Thanks! I love em!
  20. Feb 10, 2020 at 10:29 AM
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    Just my own experience with my Mustang. I went to Enkei RPF1s and some lighter/summer tires for around an 8-10lb savings per corner and I definitely noticed the difference. My car could spin the tires without me even trying so I had to learn to be a little easier on the gas.
    Now that had a lot more torque/hp than our trucks though not sure how our trucks would react though.
    AKGSD likes this.
