How much does the dealer charge to change the transmission fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Sep 8, 2010.
  1. Sep 8, 2010 at 8:20 AM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    Going to be hitting 100K around the end of the year, so I know it's going to be that time soon. I hear that the transmission is a sealed unit, which pretty much eliminates the desire from this driveway mechanic to change it myself. So, how much are the stealerships charging to change transmission fluid?
  2. Sep 8, 2010 at 8:24 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    if you are somewhat mech. inclined then you can do this yourself there is a write up on it in here somewhere
  3. Sep 8, 2010 at 8:27 AM
    Mxpatriot
    Thanks, I just took a look at it. Doesn't appear too difficult; I'll have to call the dealer and figure out how much I would save and if it's worth the hassle or not. I'm mechanically inclined, but things that are a pain in the ass I like to pass on to the mechanics.
  4. Sep 8, 2010 at 9:23 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Super easy to do man. Don't be scared off by jumping the OBD port. After that it is just a series of shifts and waiting to the right temp to check. But at 100K, you might want the flush. not just a drain/fill. Which has been done on here but I cannot comment on it.
  5. Sep 8, 2010 at 9:36 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you could do 3 drain and fills,that would clean it up as much as a flush.it would take 9.6 quarts,and cost less than 75.00 bucks.and i believe toyota changed the interval from 100k to 60k.i drain and fill mine every 15 k,fluid stays nice and clean that way.
    NmapFE, BlkDakDave and TruthSeeker74 like this.
  6. Sep 8, 2010 at 9:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, the dealer won't just drain and refill, they flush oil through the torque convertor.
    I've actually heard some mixed reviews about changing the transmission oil at higher mileage if it hasn't been done before. If you're high in mileage and the transmission oil hasn't been changed, the grit in the oil is actually what makes the plates in the torque convertor spin together. If you put clean fluid in, the torque convertor may not work anymore. This is more of a tip for POS trucks and transmissions on their last leg but just a word of caution, I wouldn't worry about it with yours.
    2015WhiteOR likes this.
  7. Sep 8, 2010 at 9:42 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    I called my dealer and they wanted $179.95 to change the fluid.
  8. Sep 8, 2010 at 9:48 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    that sounds about right,when we flush with the machine it takes 12 quarts of ATF.
  9. Sep 8, 2010 at 12:15 PM
    ec8
    ec8 Newby
    Stuart
    My local dealers don't flush anymore, they used to but not sure why the change. They used to have them but don't recommend that anymore. They quoted me $89 for a drain and refill, about 3 qts of fluid.
  10. Sep 8, 2010 at 1:31 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Not all dealers flush with a machine. When you price this service, it is important to know what service you are getting a price quote for. Many service advisors who don't know jack about cars will often refer to a drain and fill as a flush as well.
    Be sure to know what you are paying for.
  11. Sep 8, 2010 at 1:34 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    80 bucks for drain and refill from toyota.....fluid included toyota special shit
  12. Sep 8, 2010 at 2:05 PM
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    I have always done my own maintenence on all the trucks/cars I've had for the last 15 years....cause I like to know its done right and I'm cheap. Toyota has scared me away from this one with their sealed tranny though. I REALLY dont want to mess this one up, so I'm taking it in. They said around 200 to drain/fill, drain/fill, drain/fill...they do this three times I think is what they said, and dont do a flush with a machine.
    Does this sound about right? I know its kinda pricey but so is not doing perfectly and ruining a $4K tranny.
    Also, is everyone reading this thread feeling the 100K interval on changing the fluid? I plan on getting mine done at 75K. I saw that one of you does it every 15K:confused: That seems like a waste of time and oil to me....but definately, to each their own. The faster oil runs out, the faster I can start driving a hydrogen powered vehicle I guess....so use it up:)
  13. Sep 8, 2010 at 2:18 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    Around 200 bucks :thumbsup:
  14. Sep 9, 2010 at 7:44 AM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Mine was 194.06 including tax. Debated on doing this myself, but just did not have the time when it needed to be done.
    Laser likes this.
  15. Jul 8, 2023 at 12:57 AM
    TruthSeeker74
    TruthSeeker74 New Member
    Rachel
    2010 Toyota Tacoma
    It's 2023 now and my Toyota dealer wants to charge me $449.87 to do a trans fluid exchange. WTF? I KNOW IT'S BEEN LIKE 13 YEARS SINCE THEY CHARGED $179 BUT COME ON $450?
    HOW CAN THEY EXPECT ANYONE TO DO MAINTENANCE ON THEIR VEHICLES WITH THE DEALERSHIP WHEN THEY CHARGE THESE TYPES OF PRICES PRICES. WE JUST PAID $385 FOR ONE COIL AND THE LABOR. THEY ALSO WANTED TO DO A COOLING SERVICE ON THE SYSTEM FOR $247.38. SO WHAT DOES THAT INTEL I'M WONDERING... DOES ANYONE KNOW WHAT A FUEL OPTIMIZER SERVICES IS CUZ THEY WANT TO CHARGE $214 FOR THAT.
    NmapFE likes this.
  16. Jul 8, 2023 at 2:07 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Once you have done a drain and fill, you will never take it in again. It is an easy process to do. Just get a quart bottle hand pump that screws on to the bottle and you can pump most of the fluid out in a few minutes. Or get a long plastic hose and a funnel and do it from the top.
    The procedure for getting the transmission to the right temperature is described here with a search.
    Do it once every 25-30K and your good to go and keep going.
    jerrybear likes this.
  17. Jul 8, 2023 at 1:32 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    great way to change all the fluid out, is to disconnect the line that goes to the tranny from the cooler. so you turn on the truck, and it shoots the fluid out into your bucket with a hose. once it drains about 3-4 quarts, turn off the truck and add new fluid thru the access hole on the side of the trans. repeat 3 times and you are golden.
  18. Jul 8, 2023 at 1:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Forget the fuel treatment. That’s pure profit for the dealership.
    The cooling system is simple, a 22mm 6-point socket makes it super simple to break loose the drain plug on the radiator.
    The transmission can be tricky.
    You can drain the fluid and measure what comes out.
    Put that much back in.
    That’s not the best way, as you don’t really know for if it’s full.
    But it will be close enough. That is, if you weren’t low to begin with.
  19. Jul 8, 2023 at 2:31 PM
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    yep. I run funnel from the top. I run a scan tool for temp ck and drain, fill several times. Last fill is new washers and final level check. For me it is every 50,000. Just like previously mentioned, there is a ton of info and videos out there on it. Agree also on staying away flushes and getting detailed info on what the dealership is actually providing. I believe if you can change your veh’s other fluids you can do the transmission. If in doubt though maybe look around at other japanese car mechanics. Might be less expense.
  20. Jul 8, 2023 at 5:15 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I had the transmission flushed at a Toyota dealer and they did a terrible job. ATF fluid everywhere, thought one of the AT lines wasn't connected. Did they fill the AT with the proper amount of fluid? Who knows?
    If you can't do it yourself, go to a transmission shop.
    NmapFE likes this.
