How much does mounting & balancing tires usually cost?
Discussion in 'Wheels & Tires' started by Mit122, Nov 27, 2013.
  1. Nov 27, 2013 at 8:40 PM
    Mit122
    Mit122 [OP] Well-Known Member
    Plattsburgh, NY
    2012 DCSB TRD Sport
    I'm thinking about buying some new tires soon and I called a local shop to get some prices, they said if I purchase tires from them they charge $10 dollars per tire for mounting and balancing.
    I then asked if I brought in some tires I bought online how much would it cost for mounting and balancing them, they said $35 per tire. That's kinda sounds like a rip off to me. Am I wrong?? Or is the tire shop trying to stick it to me if I don't purchase tires from them?
  2. Nov 27, 2013 at 8:42 PM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    10$ is a good price per tire but I wouldn't pay more than 20$ a tire which should come with lifetime balancing and rotating, Discount tire is my go to tire shop
  3. Nov 27, 2013 at 8:45 PM
    acdronin
    acdronin Well-Known Member
    I have been using the same shop for the last ten years, they don't care if i bring the tires in, same fee, 20 bucks a pop, what i get for 20? My rims don't get scratched, tires are mounted with the balance dot in the right spot, balancing in spot on and lug nuts are torqued correctly. They have even rebalanced them after i have knocked weights off wheelin, for free. It's now 30 miles out of my way since i moved but i still go back there, it pays to find i good shop and stick with them.
  4. Nov 27, 2013 at 8:46 PM
    Mit122
    Plattsburgh, NY
    2012 DCSB TRD Sport
  5. Nov 27, 2013 at 8:49 PM
    Mit122
    Plattsburgh, NY
    2012 DCSB TRD Sport
    Yeah, I used this shop for years and usually they are very good to me; but sometimes it seems like they just pull prices out of thin air and I thought wow $35 per tire just to mount and balance was a little steep.
  6. Nov 27, 2013 at 8:51 PM
    acdronin
    bummer, yeah, that sounds like he doesn't want your business anymore
  7. Nov 27, 2013 at 8:51 PM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Well any shop can definatly have skilled tire men, but do you research on the shop. There are a lot of biased reviews out there so just learn to decipher bad reviews from truthful ones.
