How much did it cost to fix your TPMS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaSport86, Jan 27, 2019.
  1. Jan 27, 2019 at 9:58 AM
    TacomaSport86
    TacomaSport86 [OP] 2010 Tacoma/2016 4Runner Pro
    I know how to check tire pressure so dont tell me to do that.
    Has anyone had their TPMS system fixed? What was the cost?
    Thanks
  2. Jan 27, 2019 at 10:02 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Are you asking how much per tire to replace the tpms and reprogram or to just reprogram new sensors?
  3. Jan 27, 2019 at 10:05 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    That's a hard question. May need 1 or more transmitters, may need programmed, may need reset. A local tire co. reprogrammed mine for $0.00, some, especially a dealer, will want $600 + for selling, installing, & programming new sensors. To answer your orig. question, somewhere between $0.00 & $1000.00.
  4. Jan 27, 2019 at 10:12 AM
    glk21c
    MD
    Prices from rockauto for tpms sensors on my truck were $31 each(denso). A shop or dealership will charge more for them.
    You then have to pay a tire shop or repair shop to pop the bead off the rim on each tire and replace the sensor. Might need to chk balance too. Guessing at $20/tire min. To do that. OR. Wait until you need new tires and do then.
    Then they have to reprogram each sensor to your truck, that will be free to $??
    spitdog likes this.
  5. Jan 27, 2019 at 12:15 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I haven't done so, but I plan on replacing mine.
    Autel MX 315mhz TPMS sensor $27 each
    Autel MaxiTPMS Programmer $68
    The programmer clones the new sensors with the OEM ID codes; it will either read the OEM ID via proximity, or enter the ID code that is printed on the OEM TPMS sensor at each wheel. There is a good utube video on the process.
  6. Jan 27, 2019 at 1:58 PM
    TacomaSport86
    To Replace the sensors they have run out of juice.
  7. Jan 27, 2019 at 2:25 PM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    $250 for all four plus the spare tire. 5 in all at Discount Tire . Must R&R, rebalance and rotate the 4 tires and wheels!
    TacomaSport86[OP] likes this.
  8. Jan 27, 2019 at 10:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    $285 for 5 new sensors and labor to install and program, if I remember right. I ordered the OEM sensors online and took them to Discount Tire. They charged me a mounting fee for each wheel and didn't charge to program. No re-balance either, and no problems.
  9. Jan 27, 2019 at 10:13 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    No and zero (that light can burn until Hell freezes over)
  10. Jan 27, 2019 at 11:07 PM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    Bought 4 sensors for 32$ each and Firestone programed them for free.128$ Plus 4 mounting at 20ea
  11. Jan 27, 2019 at 11:10 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    One of mine had a dead battery after 9 years... $60 to replace at Discount Tire. There is no TPMS in the spare of my 2010, fyi.
  12. Jan 27, 2019 at 11:13 PM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    I had all 4 of mine done at Costco for about $15-20 each if I recall correctly.
  13. Feb 2, 2019 at 12:01 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I was just quoted $250 each for the TPMS Sensor and programing - I need 2 = $500 at the dealer. I have a slow leak in 2 tires and took it in for a rotation and to check for leak. Service writer says there is a rubber seal that gets dried out and leaks - truck is 2008 - over time - says when they take it out to put a new seal in the TPMS Sensor often breaks and has to be replaced - said it might not break but more then likely will. Sounds like a lot of $$ compared to what I read here. Any reply appreciated.
  14. Feb 2, 2019 at 12:47 PM
    Muddinfun
    Muddinfun Well-Known Member
    They're definately trying to screw you big time.
  15. Feb 2, 2019 at 1:02 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Gosh, it's amazing how often that happens at a stealership. Almost always.
  16. Feb 2, 2019 at 1:49 PM
    Gritto
    Gritto Mrs Gritto's First Husband
    Nowhere Else, Pottsylvania
    2006 AC AT V6 PreRunner
    Stock. SR5 Package #2.
    Does anyone besides me think they can do fine without those damn things?
    Even the lower prices some of you quoted seem ridiculous for something I don't want or really need anyway.
    I'm not paying $250 per tire, that's out of the question.
    I found on the service history of my truck that all TPMS sensors have failed except the spare.
    I don't see anything there about them having been replaced, just a diagnostics fee.
    I guess they must have turned off the light and/or reprogrammed the computer.
    That suits me. My butt-o-meter will tell me when a tire gets seriously low.
    But I check them for proper inflation fairly often anyway.
    My wife is always bugging me about the sensors on her 2005 Highlander.
    So I check the tires and tell her they're fine, forget about it.
    Except she doesn't forget about it, the light bugs her.
    So she goes and pays to have them checked.
    Numerous times now. :annoyed:
    [EDIT] Related question:
    I'm getting an Ultragauge. Can I turn off that blasted light with the UG?
    The light on my wife's Highlander, that is. :p
  17. Feb 2, 2019 at 1:51 PM
    TacomaSport86
    Thank you
  18. Feb 2, 2019 at 1:52 PM
    TacomaSport86
    Thank you
  19. Feb 2, 2019 at 1:52 PM
    TacomaSport86
    Thanks
  20. Feb 2, 2019 at 1:53 PM
    TacomaSport86
    Thanks wish there was a discount tire near me
    Rambo54 likes this.
