How much camber is too much?
Discussion in 'Suspension' started by Fabulous, Dec 13, 2010.
  1. Dec 13, 2010 at 11:47 AM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    So after getting my truck aligned 4 times they came up with 1.9/ 2.08 caster, 0.6 camber, and 0.02/ 0.03 toe, and it drives great. The thing I'm curious about is the 0.6 camber...the tech, and the service manager said not to worry about it as 0.5 is stock. I looked at an alignment I had 9 months ago pre lift, and sure enough it was 0.45. Question is will the change from 0.45 to 0.6 (which is the lowest they could get it without losing caster) going to wear out my summer tires quicker on the outer edge when I get them on? Anybody else end up arounf 0.6 camber? How are your tires wearing?
    Thanks.
  2. Dec 13, 2010 at 12:46 PM
    Fabulous
    Fabian
    Calgary, AB
    Anyone... Chris?
  3. Dec 13, 2010 at 12:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont like anything over .2* Camber myself, at the max. Closest to 0* is better.
  4. Dec 13, 2010 at 12:54 PM
    m0nster986
    m0nster986 ♥ Emergency Medicine
    SoCal
  5. Dec 13, 2010 at 12:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And that would be too much Negative Camber....^^^^
  6. Dec 13, 2010 at 1:03 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    Maybe they like to drive on two wheels...
  7. Dec 13, 2010 at 1:09 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    My driver side is set at .5 and passenger side is .2 and mine drives fine.
    I think i was told .5 is what toyota recommends but if it's set at zero that'll allow a little more caster wich these trucks need imo.
  8. Dec 13, 2010 at 1:27 PM
    Fabulous
    Fabian
    Calgary, AB
    My tech said that is he lowers the camber, then the caster started to suffer. I would like to have it at 0 or close to, but don't think that will happen without new UCA's. What I need to know is if the 0.6 will kill my summer tires? They will stick out farther as well as the new wheels are 9" wide with 4.5 backspacing.
  9. Dec 13, 2010 at 3:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Get a tire tread gauge, and measure the out side vs. the inside tread of the tire, and monitor wear. I have checked in the past, and found that anything over .3* Camber will wear the outside of the tire faster.
  10. Dec 13, 2010 at 3:43 PM
    Fabulous
    Fabian
    Calgary, AB
    Sweet, will do. I sent a PM to KPT as his truck looks like mine, and sure enough he is also at 0.6 camber, and has been for 17,000 miles and he said he doesn't notice any weird wear?!
  11. Dec 13, 2010 at 3:45 PM
    rcfreak201
    rcfreak201 Well-Known Member
    my truck looks just like that :D
    but seriously how much of a difference does it make, ive talked to a few people and they said my camber is at negative .5 and thats why my truck is squirly and has alot of steering wheel shake along with a very loose steering wheel, is this true?
  12. Dec 13, 2010 at 5:21 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Ain't no lie...
    I'm sure closer to zero is better, but so far so good over here at 0.6.
  13. Dec 13, 2010 at 6:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alot may have to do with the tire size too. Being Im running 285/60/18's, my tread width is 10.3", so that may affect the readings I got. My outside was only about 1/32" more wear than the inside when Camber was near .5*
  14. Dec 13, 2010 at 6:45 PM
    Fabulous
    Fabian
    Calgary, AB
    Wonder if the tires make a dif as well... like if they are a longer wearing one etc. I haven't bought the tires to go on my summer rims yet, but they will be Duratrac's, Nitto TG's, or Cooper Zeons in 265/70-17. So at any rate, the little bit of camber I have shouldn't destroy the tires super quick if I do 7-8000 kms a summer on them.
  15. Dec 13, 2010 at 7:36 PM
    TexasTacoma37
    True enough, I'm running 265's.
  16. Dec 13, 2010 at 7:47 PM
    TexasTacoma37
    Looks sweet Ryan. I ran -3.0 degrees of camber on my Subaru STi and I wore down to the cord on my tires in 18,000 miles, on the inner edge only. Sure handled great though. How are yours wearing?
