How many "yards of composted manure in bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymoussy, Mar 7, 2014.
  1. Mar 7, 2014 at 3:25 PM
    jaymoussy
    jaymoussy [OP] Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    OK, this trucking thing is new to me and I need to establish small garden beds...!
    Someone near me has composted horse manure for cheap.
    How many yards (or fractions of) can I safely put in my truck (a 2.7 L, AC)?
  2. Mar 7, 2014 at 3:33 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It depends on a lot of things, specifically how wet the compost is. If it's dry, you could pack damn near a whole yard into the bed which would weigh around 800 lbs give or take. A wet yard of compost could weigh as much as 1,600 lbs. Just keep an eye on the springs when you load it and go with however amount the truck handles.
  3. Mar 7, 2014 at 3:53 PM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    Thanks.
    Yep, I can see how wet is the stuff being a big factor, so I would have to go by my untrained eyes, mostly!
  4. Mar 7, 2014 at 4:38 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    The ammonia from the manure will destroy your vehicle especially if it is wet at all. You can get 2 to 3 yards in a full size pick-up by volume, but the weight will kill you. Dry or slightly damp compost usually weighs between 1000 – 1600 lbs per yard. MUCH heavier if wet.
    An example that may help is this.
    A 40 lb bag is probably about 1 cubic feet of tightly packed top soil. So it would take 27 bags to make 1 Cubic Yard of tightly packed top soil. 27x40=1080 pounds.
    If you value your vehicle get a trailer. I destroyed a trailer from hauling mushroom compost so it will do the same to your truck because of the ammonia. The compost will compress while hauling and squeeze moisture out of the compost. That will run down the drain holes in the bed as well as out the back tailgate and rot your frame. The stuff I hauled was wet and weighed between 2500 and 4500 pounds per yard depending on how wet it was. I usually got 4 yards which weighed between 10,000 and 18,000 pounds. By the way, by wet I do not mean sloppy, just wet. Don't even consider sloppy. Reach deep into the pile, at least half way up to your elbow, and get a hand full. If you can squeeze any moisture out of it then it is wet and it will be heavy.
  5. Mar 8, 2014 at 5:12 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Wow, this guy knows his sh1t! Id load it watching the springs while the loader dumps it in, and hose it out as soon as you are done offloading it.
  6. Mar 9, 2014 at 4:40 AM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    I would also think a serious undercarriage wash following the offload should take care of the corrosive stuff.
    And maybe use a large painter's drip sheet in the bed for further insurance, so it is more a bathtub than a colander?
  7. Mar 9, 2014 at 5:17 AM
    cmoore289
    cmoore289 Member
    chris
    phila
    SR5
    anytime i go for mulch i just bring a large tarp and lay it in the bed (and over the sides) and then they backhoe the mulch on top of it. i shovel it out when i need it and when as there is only a little left you just pull the tarp and the last of the mulch out and near 100% clean.
  8. Mar 18, 2014 at 4:09 AM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    Bump for horse manure transport day!
    Still unsure how much I can safely put in the bed...
    - guesstimate how wet the stuff is?
    - visually see (or measure?) how much squatting occurs?
  9. Mar 18, 2014 at 4:17 AM
    The6pharaohs
    The6pharaohs WTF just happened?
    Wil
    Eagle Mountain Utah
    2017 DCSB Offroad with JBL premium tech package
    Upgraded from 2012 DCSB TRD Offroad Entune JBL w/nav
    Truck can handle a lot of shyat (someone had to say it)
    :crapstorm:
  10. Mar 18, 2014 at 5:34 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    I put a yard and a half of semi dry mulch in mine without any issues.
    but as others have stated, if the manure is damp, it's going to be heavier...
    I'd go with a yard and see how it goes.
    If you have to go back for more, still better than breaking something.
    and def. wash out after...
    PC
  11. Mar 18, 2014 at 5:37 AM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    What a BS question.
    Sorry, had to say it.
  12. Mar 18, 2014 at 5:51 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    Just go for 1/2 yard at a time if the guy isn't too far away. Better safe than sorry.
  13. Mar 18, 2014 at 6:06 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
  14. Mar 18, 2014 at 6:12 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Want weeds in your garden go with animal manure of any sort.
  15. Mar 18, 2014 at 8:46 AM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    Half yard was all I needed, and also as much as I felt comfortable taking on the truck. It was well-composted horse manure.
    It was fairly dry, so no liquid in bed or through drains. I had it tarped well, followed by a very good rinse x2.
    BTW, a lot of crud seems to accumulate in the inner part od bumper, worth a good spray once in a while... even in "normal" operation.
  16. Mar 18, 2014 at 8:50 AM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    I just absolutely soaked my undercarriage in Fluid Film. The comes-in-a-gallon, looks-like-gravy stuff, not the spray cans. Would that protect it from the ammonia in compost? I'm not hauling any in the near future but just want to know what my capabilities are and can't buy or borrow a trailer at the moment.
  17. Mar 18, 2014 at 8:53 AM
    Pugga
    Massachusetts
    If you're worried about anything dripping, just put a tarp in the bed first. Wrap it up the sides and load the compost. You can get a nice, large tarp for like $15 - $20 at a hardware store.
  18. Mar 18, 2014 at 2:16 PM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    I purposely picked up my stuff after a few dry days here.
    Stuff left on my tarp were just small dry-ish bits, the kind you can dust off with the back of your hand.
    The front drain hole is just about (+/- 2") by the spring mount point, so, spray there.
    For better or worse, my Taco is no longer a mall crawler, now...!
