How many wheels/tires can you fit in the bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DLillest, Oct 26, 2018.
  1. Oct 26, 2018 at 5:40 AM
    DLillest
    DLillest [OP] Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    For context I have a Double Cab Short Bed.
    So in short, I'm heading out tomorrow morning on an 5hr round trip to pick up a set of 265/75R16 duratracs. I also have the opportunity to buy a set of Pro Comp wheels with 265/75R16 BFG tires already mounted (but half worn) which are an additional 1.5hrs away (8hr round trip)
    My main concern is if I would have enough room in the bed + back seat of the cab to load two sets of tires. I will for sure be picking up the duratracs but I would hate drive the additional distance to not be able to fit the second set of wheels.
    Anyone know if we can fit two sets in the bed + back seat of a DCSB?
    Thanks!
    ChadsPride likes this.
  2. Oct 26, 2018 at 5:42 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Few ratchet straps and drop the tailgate for more surface area and can probably stuff em all in there.
  3. Oct 26, 2018 at 5:44 AM
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    If there's a will, there's way... You can most likely fit them all in the bed, but definitely if you use the back seat too.
    DLillest[OP] likes this.
  4. Oct 26, 2018 at 5:46 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Stuff them all in the bed if you stack them up vertically then like Chad said use some ratchet straps to tie them down you'll be good. For context now I've got a long be but you pack it right and you can stuff a lot in the bed. Full set of armor, HC rear bumper, my spare, tool box, skids, sliders, and front bumper and still had plenty of room for some more tetris in loading the bed.
    kYSaFFLCNE2-jFHaFAdc5NIAoLd4nVHTDZfhYQzq_58d61dad44dda9d06717dfa0c099c90339eafb04.jpg
  5. Oct 26, 2018 at 5:46 AM
    DLillest
    Quebec, Canada
    That's good to know. I don't mind strapping down or stuffing some in the back seat, as long as they can fit through the door lol.
    I figured if I couldn't fit them all in, I'd take my camry to pick up the tires as it's cheaper on gas.
  6. Oct 26, 2018 at 5:47 AM
    RIDER34
    RIDER34 Well-Known Member
    16 Inferno SR5, 18 magnectic gray SR5 4x4
    I fit a the full set on my bed (5') no issues at all.
  7. Oct 26, 2018 at 5:47 AM
    DLillest
    Quebec, Canada
    Amazing, with straps, anything seems possible! Lol
    BassAckwards likes this.
  8. Oct 26, 2018 at 5:51 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Tetris is a key to learning good stacking/packing skills!
  9. Oct 26, 2018 at 5:53 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    That should be easy! Post pics!
  10. Oct 26, 2018 at 5:53 AM
    DLillest
    Quebec, Canada
    Would you say you have more room leftover by stacking them flat or vertical?
  11. Oct 26, 2018 at 5:56 AM
    RustyTrumbone
    RustyTrumbone Well-Known Member
    Phil McCracken
    2018 Tacoma SR5 Short Bed
    I was able to fit 4 in the bed for my other car, they were all laid down. you can probably can put them on their side with straps holding them down and fit all of them
  12. Oct 26, 2018 at 6:10 AM
    RIDER34
    They will not fit completelly flat, yes you might get more room left over if they are vertical.
    DLillest[QUOTED][OP] likes this.
  13. Oct 26, 2018 at 6:22 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    8 hrs? You must be getting them for damn near free.
    As others said keep them vertical. I would avoid having the tailgate down just because thats the fastest way to ruin one and they cost more than a set of used wheels/tires.
    Get bags for the ones you’ll be putting in the back seat.
    #shortbedprobs
  14. Oct 26, 2018 at 6:25 AM
    obhuan
    obhuan Well-Known Member
    Tacoma, WA
    09 DCSB TRD OR
    Easily should be able to fit 6 wheels in the back and two in the rear seat if you have to, but if you're clever you can probably get all 8 in the bed. Here's four 285/75/16's in my short bed - you can see there's still plenty of room left:
    BassAckwards and DLillest[OP] like this.
  15. Oct 26, 2018 at 6:36 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Your tires are all 31.6 inches so end to end that's over 5ft so you will have to go tail gate down if you do 2 row upright unless one set is not mounted. Then you could put your wheel and tire set in first, the butt your second set against those and ratchet them tight toward the cab and maybe compress them enough to get the tailgate shut. That's a huge maybe but you only need a few inches. Good luck!
  16. Oct 26, 2018 at 6:44 AM
    DLillest
    Quebec, Canada
    Agreed on having the tailgate down, I don't trust it.
    I'm getting the duratracs with 8k on them for $240 and the Pro Comps 7089's are $240 as well.
    There isn't anything local to me and with the winter coming soon, I want to get a set of wheels mounted!
    PackCon[QUOTED] likes this.
  17. Oct 26, 2018 at 6:46 AM
    DLillest
    Quebec, Canada
    This gives me hope!
  18. Oct 26, 2018 at 6:46 AM
    DLillest
    Quebec, Canada
    Agreed, I think I'll mess around with some spares tonight and essentially do this. Worst case I throw one or two in the back seat with a blanket covering the bench.
  19. Oct 26, 2018 at 6:47 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    4 or 5 tires is easy. You could probably get 6-8 tires with the tailgate down and straps!
  20. Oct 26, 2018 at 6:49 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Even better get a buddy to ride with you and hold 1 out the window!
    MAG GRY TACO15 and DLillest[OP] like this.
