How many quarts for my 4.0 V6 oil change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ap53, Nov 12, 2008.
  1. Nov 12, 2008 at 3:53 PM
    ap53
    ap53 [OP] Well-Known Member
    Art
    NJ
    06 PreRunner
    I cant find my owners manual and I cant remember how much oil should I put in my 06 V6 pre runner with an oil filter change ?? Can some one tell me what is Toyota recommendations.
    Thanks.
  2. Nov 12, 2008 at 4:12 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    5.4 qts for the 4.0
  3. Nov 12, 2008 at 4:17 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    +1
    Here is link to the oil filter removal part of the service manual
    with oil spec's.
  4. Nov 12, 2008 at 4:20 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    rule of thumb for all v6/v8 engines.. put 4 quarts in, run the engine 10 seconds, shut it off, let the engine sit so the pan fills back up, check your dipstick, add accordingly.
    TRD4x4offroad likes this.
  5. Nov 12, 2008 at 4:30 PM
    ap53
    Art
    NJ
    06 PreRunner
    Thank you all, for the help.
    That’s what I did, 4 quarts in and I checked the dipstick and it looked ¾ full.
    I just thought double-checking is forth it?
  6. Nov 12, 2008 at 4:56 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Yah, because you'll never empty ALL the old oil out, so its good to not just add 5 quarts in and cross your fingers becuase you'll burn up some goodies in that engine real quick. (thats the technical term for engine parts - goodies) ;) Just 4 in and usually just need that last 1/4 to 1/2 quart.
    change your oil filter every other oil change to save money, and you'll be set. just remember to reset the computer otherwise you'll have that flashing yellow light on your dashboard for a bit. Check your owners manual for instructions.. i believe someone wrote up something about it a few posts back..
  7. Nov 12, 2008 at 6:20 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The amount listed in the owners manual will probably already compensate for whatever oil is left in the crankcase. Adding 5.4quarts immediately is just fine. I actually put 5.5+ since I run a larger oil filter and change it every time.
    The dipsticks on these trucks are VERY difficult to read.
    If you change the filter every other oil change - then the quanity required is even less. Read the owners manual.
    To Reset the maint light. Press and hold the trip button. Turn key to ON Position. Continue holding the trip button. On the dash readout - you'll see some dashes. Continue pressing the trip button - and I can't remember what the last thing it does ...maybe zero's or 3 dashes. CAn't remember.
    SouthCarolina likes this.
  8. Nov 13, 2008 at 3:40 AM
    ap53
    Art
    NJ
    06 PreRunner
    Thanks for the reset instructions I was going to ask for this next, I still can’t find owners manual.
  9. Nov 13, 2008 at 4:10 AM
    Joe B
    Joe B Well-Known Member
    I go with 5.5 qts.
    Even if it's 1/10 of a qt over,it sure won't do any harm.
  10. Nov 20, 2013 at 9:40 AM
    DannyH
    DannyH New Member
    Arizona
    08 tacoma pre runner
    Why would you not change your oil filter with every oil change??
    Would you wipe your ass with used toilet paper? Probably not so why would you expect a used filter to keep new oil clean??
    Filters are not that expensive.
  11. Nov 20, 2013 at 10:03 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Someone seems a little unhappy in their first post here at TW. Plus this is a 5 year old thread. The poster may not even be here anymore lol.
  12. Nov 21, 2013 at 5:31 AM
    DannyH
    DannyH New Member
    Arizona
    Yep new to forum also new to me tacoma and was looking for info when Google found this post for the info I was looking for. Did I check the date of the post? No! Was I unhappy we'll I didn't think so it was just a comment. But if making comments makes me look angry perhaps I should not have joined this forum?
  13. Nov 21, 2013 at 7:19 AM
    Janster
    Jandy
    Lancaster, PA
    Making comments (in first quote) will not make you any friends on this forum.
    For real...... think about it. How would you feel if someone responded to YOU in the same manner?
    Keep it clean. Keep it respectful. Keep it positive. Nobody likes negativity.
    BCTRD16 likes this.
  14. Nov 21, 2013 at 7:32 AM
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    Well said eta.
  15. Nov 21, 2013 at 7:32 AM
    GoHuskers
    Nebraska
    Well said ftw
  16. Nov 21, 2013 at 7:34 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    LOL agreed! Cheap insurance!
  17. Sep 9, 2015 at 3:40 PM
    Messytouch78
    Messytouch78 New Member
    Clint
    06 Tacoma
    I always put 5 Quarts of synthetic oil and a quart of slick 50 high mileage always a good thing!
  18. Sep 9, 2015 at 6:12 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Hey Messytouch78! Welcome to TW! I'm no mathematician, and certainly no Toyota Technician, but that looks like 6 quarts in your engine to me. Is your engine a 4cyl or 6cyl? Just wondering!
  19. Dec 12, 2015 at 12:38 PM
    Callipygous
    Callipygous Member
    08 prerunner
    While I agree that the response could have been more tactful, I have to say this seems like pretty silly place to save 4 dollars every 10k miles. Just change the filter!
  20. Dec 12, 2015 at 12:53 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    -5 qt jug of Mobil 1 synthetic Plus 1/2 qt
    -OEM filter
    Takes 15 mins and costs $30
