How many pumps of grease for the slip-yolk?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Glenn54, Sep 15, 2012.
  1. Sep 15, 2012 at 10:33 AM
    Glenn54
    Glenn54 [OP] Active Member
    Glenn
    Upper Marlboro, Maryland
    SR5 4X4
    (2001 2.7ltr 4x4) In the process of greasing my drive shaft and was wondering if there should be any grease oozing out for the slip-yolk? Thus far I hit it about 6 pumps and don't see anything coming out anywhere. Don't want to mess around and blow a seal if there's one in there :(
  2. Sep 15, 2012 at 10:43 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The seal should be just a piece of rubber that raps around the shaft. When you are pumping the slip yoke with grease, you will eventually see the shaft move due to the pressure of the grease. At this point, that should be enough grease. You can always take your truck for a ride and do some errands and when you get back home, pump some more grease in. No worries if you are pumping grease in and some starts to come out where the rubber seal is, you'd want to get old grease out anyway. Hope this helps. Good luck
  3. Sep 15, 2012 at 10:52 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    I learned the hard way, dont put to much in..it actually causes the drive line to bind, and the automatics dont want to shift out of park.. :rolleyes:
  4. Sep 15, 2012 at 11:00 AM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Dont ask me how..but when I had my 96, I pumped so much greese into the slip yolk one time, the truck didnt want to shift out of park..I had to take it on a ride to get it to loosen up...Weird, I know.
  5. Sep 15, 2012 at 11:01 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Could you explain how that works out?
  6. Sep 15, 2012 at 11:03 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Jezuz, I have been doing this stuff for decades and havent seen that one yet....didnt know it would get that bad, but I dont pump it that far either.
    I just pump it till I see the grease cap move, then I will stop, not trying to convert the thing into the jaws of life by turning it into a hydraulic bottle jack for christs sake, lol.
  7. Sep 15, 2012 at 11:18 AM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Funny part was the yolk kept moving..its not like it stopped and i kept pumping it..i eventually said wtf is going on here and stopped..i think i was doing an oil change also, so i went to start it up and move it back so i can clean up my tools and such, and it wouldnt shift out of park..i had to kinda force it to go, but it went..no problems afterward either
  8. Sep 15, 2012 at 4:30 PM
    Glenn54
    Glenn
    SR5 4X4
    OK, gave it about 4 to 6 more hits until I saw the shaft start moving. Thanks
