How many o2 sensors are there?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mxer256, Oct 22, 2012.
  1. Oct 22, 2012 at 3:45 PM
    Mxer256
    Mxer256 [OP] Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
    I was just wondering how many o2 sensors are on our truck. I went to advanced auto(will never go back again). They finally came to the conclusion that it was the upstream o2 sensor. I bought it because i know for a fact it is(Ive gone to orielly and autozone and got the same code but they told me it was o2 sensor)
    There are two catalytic converters...I see one after the second one and another inbetween them but cant tell if there is one on the headers or inside the engine bay.
  2. Oct 22, 2012 at 4:00 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    There are 2. That's unfortunate you didn't like advance auto, they always have good prices and online coupons. I save tons through them.
  3. Oct 22, 2012 at 4:11 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    Yeah i guess since im a teenager i get treated different. My dad prefers them over autozone but i will never go back there!
    And thanks for the help! Going to replace it now!
  4. Nov 6, 2012 at 7:37 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I can second the motion on advance auto by isu2014, I just had to do both o2 sensors on my Tacoma to pass NYS inspection, and they had the parts at a discount on line. I picked up the parts at the local store and was on my way in no time. Too bad your experience was negative.
  5. Apr 19, 2014 at 12:10 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Advance recognizes the upstream o2 sensor as the air/ fuel ratio sensor and the downstream is recognized as an o2 sensor. When I was looking for the part the guy couldn't find the upstream because he was using O2 sensor as the "key word search".
  6. Apr 19, 2014 at 5:29 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    This is correct. Only have 1 02 sensor (after the cats) and 1 AFR sensor (before the cats).
  7. Oct 5, 2016 at 11:29 PM
    Allen510
    Allen510 New Member
    Where exactly the AFR sensor located at? I just change my 2 converter and the 02 sensor but my check engine light came on 2 day afterwards. I used the scanner it said Air Fuel Sensor. I notsure are there 2 different sensor? Or just the 02 sensor.
  8. Oct 6, 2016 at 6:19 AM
    ghs57
    Chops
    Catskill Mts. NY
    I don't see any info on your truck. If you have a 2.7l 4 cyl, the a/f sensor is between the exhaust manifold and the first cat, on the exhaust pipe as it heads down to the cat. The connection plug is along side the transmission on the passenger side.
