How many mpg for my 03 Tacoma TRD 6 cyl
Discussion in '1st Gen. Tacomas (1995-2004)' started by seanmichaels, Jan 20, 2011.
  1. Jan 20, 2011 at 6:29 AM
    seanmichaels
    seanmichaels [OP] Member
    Florida
    03 Tacoma TRD V6
    Surprisingly I did not see this in my manual. Where would I find this?
  2. Jan 20, 2011 at 7:21 AM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    You'll see gas mileage between 17 and low 20's for miles per gallon
  3. Jan 20, 2011 at 7:36 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    IIRC the new car window stickers for the v6s said 16-19 mpg for the manual and 17-20 mpg for the auto. YMMV
  4. Jan 20, 2011 at 8:12 AM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    ^Really? This would be the first case that I have seen a manual being rated lower than an auto.
  5. Jan 20, 2011 at 8:20 AM
    Digiratus
    Roaming the PNW
    The RedHead
    At the time I remember being a little surprised by that too. But what I recall is my '98 xc v6 manual was rated at 16-19 and I think that held all the way through the '04 model for the 3.4L in xc 4x4 Tacomas.
    I'm betting that someone on here can produce documentation that clarifies this question.
  6. Jan 20, 2011 at 9:12 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    a little happier to see those numbers (see my fuelly below)
    but how are some guys getting 20+ in the V6?
  7. Jan 20, 2011 at 9:16 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I'm hovering around 16mpg gallon this winter. In the summer I was round 18.5mpg. The colder weather and heavier tires put a dent in my mileage.
  8. Jan 20, 2011 at 9:42 AM
    NegroTundra
    Land of Enchantment
    I'll pull out my sticker when I get home
  9. Jan 20, 2011 at 9:54 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    On the highway, you can average that. I get 18mpg combined.
  10. Jan 20, 2011 at 9:58 AM
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    Mileage varies based on a number of factors, For me my mileage hovered around 12 because of my lead foot... If you're carrying alot of extra weight it may make a difference as well. I've heard that lifting the truck kills it too, but I didn't notice a difference til I added the wheel spacers.
  11. Jan 20, 2011 at 11:07 AM
    tacomakid96
    Phil
    Out n' about
    I get 18 combined and 20 for highway and my truck has gotten that since I bought it.
  12. Jan 20, 2011 at 11:49 AM
    vantaco
    when i bought the truck the first drive was brining it home on the highway (although very hilly) and i got aroun 19.5mpg
    now (basically all city i only get around 16-16.5
  13. Jan 20, 2011 at 2:01 PM
    tacomakid96
    Phil
    Out n' about
    Tune up, there is a reason that it dropped gas mileage.
  14. Jan 20, 2011 at 2:05 PM
    vantaco
    no it was all highway, now i do 99% city or very hilly/steep highway
    i do have new plugs to swap in....what else should i do?
    fuel filter is done, air filter is good
  15. Jan 20, 2011 at 2:06 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    I was at 19-21mpg pretty regularly until I went with bigger tires... Now I'm at around 16-18 regularly. I'm running a 3.4 in Auto & 4x4 DBL...
  16. Jan 21, 2011 at 3:08 PM
    WhyNotFab
    WhyNotFab Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
    3.4L with K&N Intake, Flowmaster Muffler, Tires are 285/75-16
    Mostly highway daily, but a little stop & go for about 5 miles through town on my way home from work..
    I use an app called Gas Cubby on my phone.. type in the mileage/gallons/cost at each fill up, and it gives me a list of each fill up with my MPG and all.. then I can view charts like the one above, or graphs.. and it also lets you keep record of maintenance and it will remind you when an oil change or any other maintenance is due.. great app!
  17. Jan 22, 2011 at 5:10 PM
    tacomakid96
    Phil
    Out n' about
    ^ I like! nicely done
  18. Jan 22, 2011 at 7:37 PM
    coehorn1
    coehorn1 Well-Known Member
    '03 4x4 2.7I4 5sp "beast"
    Scanguage shows a massive change in mileage after warm up. Depending upon your situation, you may get very fast payback on some type of block heater.
  19. Jan 22, 2011 at 7:41 PM
    747
    747 function > form
    1st Gen.
    '03
  20. Jan 22, 2011 at 7:45 PM
    coehorn1
    No matter what "facts" they give you, you can change the equation. A lot of fuel consumption is operator habits. MPG can also be affected by hardware and the environment.
    You can educate yourself to help increase your mileage with sites like this:
    http://ecomodder.com/
    Great people.
