How many miles past "empty" can these go?
Discussion in '4 Cylinder' started by Vrbas, Dec 6, 2010.
  1. Dec 6, 2010 at 9:31 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    From what i've been told, gauges are conservative meaning maybe a gallon or 2 is left in reserve after "E" is reached. I know it's bad to run engines down that low because of the "dirty gas" that lies at the bottom or whatever they say the reason you're not supposed to run it low.
    What has your experience been? Anyone ran out of gas? How many miles did you get past empty?
  2. Dec 6, 2010 at 9:33 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    my 09 dc 4x4 has 4 gallons when it just touches the E mark.
  3. Dec 7, 2010 at 12:54 AM
    Jefenator
    Jefenator Taco Truck Noob
    Oregon
    2010 2WD Reg Cab Stick Shift
  4. Dec 7, 2010 at 10:21 AM
    Vrbas
    ^^^ yeah i just discovered that thread, my bad fellas :eek:
  5. Dec 7, 2010 at 10:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Water floats on gas so if there is any in the tank and you run it down far you could run it through your engine. If it's cold that water can freeze in the injectors and cause problems also. Just giving you some other reasons not to run your tank down that far.
  6. Dec 7, 2010 at 7:27 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    ^^ water is denser than gas, so the water will be at the bottom of the tank.
  7. Dec 7, 2010 at 7:33 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    lolz, guess I shoulda filled 'er up 2nite, it's going down to 8F :sick:
  8. Dec 7, 2010 at 7:35 PM
    Snoyota
    Snoyota Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    ive gone 54 miles on empty
  9. Dec 7, 2010 at 7:39 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I could go 100+ if I really wanted to. But I usually fill up within 10 miles or so when the light comes on.
  10. Dec 8, 2010 at 9:01 PM
    81shark
    81shark Well-Known Member
    gas floats on water.
    wow
    anyways, i've gone 60 lots of times after the light comes on. i'd say 75 is about as far as i would want to go. the reason they say you should fill up, is the gas cools the fuel pump and potential for sediment. or so they say. i've never really worried about it.
  11. Dec 8, 2010 at 9:07 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    yea im not sure about toyota fuel pumps needing to be cooled but i had a z28 camaro and i burnt a fuel pump up runnin the fuel low.
  12. Dec 9, 2010 at 1:14 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    As long as fuel is flowing through the pump, it is being cooled.
  13. Dec 9, 2010 at 1:37 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    NOTE: the gallon figures below may be +/- 0.5 gallon from your truck. Do your on research to confirm my findings.
    The needle keeps moving below the E-Line... There is approx. 2.5 gallons in this 'reserve' area between the E line and an empty tank... We know this because if we fill up right when the gauge is on E, we can put 18.5 gallons in the tank. It is a 21 gallon tank, so 21-18.5 = 2.5.
    The miles you can drive before your truck dies depends on your mileage. My truck at 17 mpg can go 42 miles before running out, from the E Line. NEVER do this on purpose!
    The amount of gas at the other gauge points:
    The low gas warning light comes on with 4 gallons in the tank (down 17 from full).
    At the 1/4 tank line, there is 8 gallons in the tank (down 13 from full).
    At the 1/2 tank line, there is 12 gallons in the tank (down 9 from full).
    At the 3/4 tank line, there is 16 gallons in the tank (down 5 from full).
    Again, these figures may be as much as 1/2 gallon different in your truck, depending on temperature and how full it was filled. A half gallon at 16 mpg is = 8 miles, and at 22 mpg is = 11 miles...
  14. Dec 9, 2010 at 1:40 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i've gone 52 miles after the light came on
  15. Dec 9, 2010 at 2:39 PM
    Vrbas
    Thanks a bunch David K! Those are some hard numbers that reek of research and personal experience. I remember reading through most of your other thread and have come to the conclusion that most have. I get about 23 mpg so i'm going to sway to the conservative side and estimate 3 gallons when the light first comes on giving me about 70 miles before i absolutely must fill up.
  16. Jan 6, 2011 at 2:33 PM
    mikemataa
    mikemataa New Member
    I've gone upwards of 50+ and I just burnt the fuel pump up at 102000 miles.
  17. Jan 6, 2011 at 4:38 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I'm a creature of habbit...if you check my fuelly you'll see what I'm talking about. My last 10+ fill ups have been 17.25 gal +/- .5 gal....hahaha.
  18. Jan 6, 2011 at 6:05 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    this is not true...the pump is supposed to be submerged and is the leading cause of fuel pump failure...also besides overheating the pump by running it low as people have stated, you're more likely to suck up more sediment, etc...
    also another reason to not have your tank that low is in case there is an emergency and you need to evacuate your town or even hit the road to a hospital because someone got hurt you dont need to be pussyfooting around at a gas station getting gas while they could be sitting their bleeding or in shock etc. or something like 9/11 happens and you're in a big city like NY and need to get out imagine the lines and how quickly the tanks in the ground will empty. because most gas stations get a fuel truck 2-4 times a day
  19. Jan 6, 2011 at 9:15 PM
    David K
    And was this right when your E Light came on, each time you topped with 17 gallons?
  20. Jan 6, 2011 at 9:18 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Yup. My light comes on, and I'm usually at a gas station within 10-15 miles...So when the light comes on I'm pretty much spot on 17 gallons in the tank.
