How Many Miles on Your 2.4 or 2.7L Four-Banger ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by White Monster, Jul 10, 2016.
  1. Jul 10, 2016 at 10:53 AM
    White Monster
    White Monster [OP] Well-Known Member
    Central Florida
    2001 PreRunner
    US Navy Veteran
    I've heard that the Inline Four engines are bullet-proof and will run forever, if properly maintained.
    My buddy had 299,000+ miles on his T100 when he sold it and it was still going strong. I've got only 140,000 on my 2.7L and am going 18,000 miles between oil changes without having to add a drop in between.
    How about you guys ?
  2. Jul 10, 2016 at 11:11 AM
    CharlesCity
    CharlesCity Self Preservation? What's that mean?
    VA
    2015 DC Off Road
    White Monster - I'm not sure that is the best oil change schedule. What kind do you use? With a good synthetic I have read/heard and practice 7500 miles between changes for my F-150. I go the recommended 5k for my Tacoma.
    Ihad a 96 ford ranger 2.3L with 200k that ran perfect. I changed the oil every 3k with conventional oil since 70k when I got it. Went through two clutches in 130k miles though.
    Have heard of some folks doing 20k between oil changes on some diesels.
  3. Jul 10, 2016 at 11:20 AM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    165,000 on mine. I change the oil twice a year, once in spring and once in fall. But I only put 5 or 6 thousand miles on it in a year.
    No way I would go 18,000 miles between oil changes. Good for you if it's working out, but in my opinion that wouldn't be conducive to long engine life.
  4. Jul 10, 2016 at 12:26 PM
    White Monster
    Central Florida
    2001 PreRunner
    US Navy Veteran
    I appreciate your views, which you of course are entitled to. I don't use perception, nor take other peoples advise. I do my own research and perform laboratory testing to determine what is best for me.
    I've already posted my findings, for all to read about and come to their own conclusions. Here is my thread for your convenience;
    https://www.tacomaworld.com/threads/oil-change-interval.271849/#post-6707369
    Once you have reviewed it, I'd be interested in your feedback.
  5. Jul 10, 2016 at 12:39 PM
    ajm
    Anthony
    AZ
    1996 4x4
    I checked out your oil test results. Looks good! I never really considered sending in my used oil for testing, maybe I should.
    But I think I would have a nervous breakdown waiting that long between changes...too many years changing it at 3000-4000.
  6. Jul 10, 2016 at 12:49 PM
    White Monster
    Central Florida
    2001 PreRunner
    US Navy Veteran
    I understand that the years of brain-washing by Stealerships, service centers and backyard mechanics advice is difficult to overcome, but scientific testing is also hard to refute .. especially when the same results are prevalent over and over again.
    The main reason that oil change intervals regarding time duration is that the old petroleum lubricants absorb moisture and degrade the oil over time. Synthetics to not absorb water, so time duration becomes irrelevant. I am waiting for my latest lab analysis of over four years. Stand by.
    ajm likes this.
  7. Jul 10, 2016 at 12:57 PM
    nickpasquale92
    nickpasquale92 Active Member
    Nicholas
    San Diego
    2000 Tacoma LX 4x4 Reg Cab
    5100/Toytec front Coilovers JBA High Caster Upper Control Arms Toytec Diff Drop Sway Bar Delete Moog 555 UBJ Moog 555 LBJ Moog 555 TRE's Bilstein HD rear w/stock leafs
    i have 178,000 on mine so far all original except suspension. going super strong. 2.7 4x4 2000 tacoma
  8. Jul 10, 2016 at 12:59 PM
    White Monster
    Central Florida
    2001 PreRunner
    US Navy Veteran
    What suspension upgrade did you install ?
  9. Jul 10, 2016 at 1:02 PM
    nickpasquale92
    Nicholas
    San Diego
    right now has HDs in the front and back with crappy spacers (spacers are from previous owner).
    looking into this toytec lift 3in lift.
    http://toyteclifts.3dcartstores.com/BOSS-Suspension-System-for-955-04-Tacoma_p_784.html#
    comes with the diff drop and going to add dakar leaf pack, gonna probably add the adjustable UCA while im at it
    also need ball joints and new cvs but oem is pretty expensive trying to figure out what to do there. i put oreilly axles on last year and my CV angle is bad so they are already bad lol...
  10. Jul 10, 2016 at 1:15 PM
    White Monster
    Central Florida
    2001 PreRunner
    US Navy Veteran
    I've got serious "axle wrap" and just ordered Bilstein 5100's all around and Wheeler's Off-road 4- Leaf Spring pack replacements, in addition to all the various bushings and bumpstops.
  11. Jul 10, 2016 at 2:52 PM
    CharlesCity
    VA
    2015 DC Off Road
    Respectfully - do not need a lab test to see the oil is pitch black after several thousand miles. All that junk in the oil is slushing around through your motor for X amount of miles. For my trucks, I am convinced that it will last much longer and stay cleaner internally on a "regular" oil change interval.
    I do like the research aspect though and I'm glad you have found a way to reduce maintenance intervals. It is admirable that your willing to go outside the norm and report your findings. I had an 85 Tacoma with the 22R and it had a bagillion miles on it when I got it. I dont know if the fella ever changed the oil in it. I killed It on the power lines fourwheeling (blown head gasket/overheating).
    BarnBoy likes this.
  12. Jul 10, 2016 at 3:37 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    300k on my '97 2.7, I change the oil maybe once a year when I get around to it
  13. Jul 10, 2016 at 4:26 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    The oil in my 2.7 says good for 16000 miles/24000 km
    I am at close to 8k now, likely change it out soon, maybe around 10k.
    Oil has come a long way. I changed my old car at 5000 mile intervals and it had 350k on it when I sold it. All in conventional oil, whatever was on sale.
    Oil has a lot of myths out there.
  14. Jul 10, 2016 at 4:29 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    148,000 on the 2.7l
  15. Jul 10, 2016 at 4:30 PM
    Northern Taco
    111,000 now on my 2004 2.7L
  16. Jul 10, 2016 at 5:18 PM
    CharlesCity
    VA
    2015 DC Off Road
    No doubt the Toyota 4cyl will last a long time. Probably Contributes to the high resale values we see and the "most dependable brand" awards.
    I wonder.........bet the majority of the 200k+ mileage crowd used close to factory recommended oil change intervals. I suppose my warranty has me tied to the the 5k right now.
    The well written and posted data the Op collected from the oil analysis provides conclusive data right? Its hard to call things scientific without a baseline or control to contrast wear. I do believe there is validity to the extended intervals being ok for some depending on how the vehicle is used and what the environment is. Also, I just read the oil filter comparison writeup in the mod's and tutorial section. Good stuff too, just like this.
    I am curious as to how the oil was collected for the sample. It may have posted and I missed it. Wear metals settle to the bottom do they not?
    Thanks for your research.
  17. Jul 10, 2016 at 5:31 PM
    2ndtaco4me
    2ndtaco4me Well-Known Member
    MA
    13 Tacoma ltd & 02 Tacoma
    285,000 on the 2002 4x4 2.7. Really didn't have to do much to it. Regular oil changes. plugs and wires. Mufflers. Many sensors! AND the darn charcoal canister to get the engine light to go off. Wish I had a brand'y new 2002 again. A beautiful machine
  18. Jul 10, 2016 at 7:10 PM
    tacopablo
    tacopablo Well-Known Member
    Québec
    2002 tacoma 2.7l
    290 000 km on the 2.7L 4x4 2002. And it's getting a new frame tomorrow :bananadance:. Just switched to synthetic oil, I'm planning to change it every 8000km or so when it's on sale at canadian tire :canada:
  19. Jul 10, 2016 at 7:21 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    There's a lot of OTR trucks that go 50k-100k on oil changes. Many of them on regular conventional oil, but they hold right around 40 quarts of oil so there's a lot more room for contaminates to be suspended is the reason they can pull it off. Oil analysis are the way to go to find out how far you can safely push an OCI. But for me, regardless of what they claim, I could never go longer than 10k on my truck personally. Amsoil has an oil that's allegedly good for 25k-30k miles, but I'd never attempt to go that far on it.
  20. Jul 11, 2016 at 10:09 AM
    PyrettaBlaze
    PyrettaBlaze Well-Known Member
    Kristopher
    Salt Lake City, UT
    1996 Tacoma 2.4
    127k on my 2.4. Just did rear diff, Trans and engine oil change.
