How many miles before your first brake job?
Discussion in 'Technical Chat' started by Elkhound, Aug 9, 2013.
How many miles before your first break job?
Poll closed Sep 8, 2013.
  1. under 70k
    12 vote(s)
    44.4%
  2. over 70k
    15 vote(s)
    55.6%
  1. Aug 9, 2013 at 5:49 AM
    Elkhound
    Elkhound [OP] Member
    Kurt
    New Hampshire
    Tacoma 4x4
    Greetings Fellow Taco Heads, My 06 Tacoma just reached the 70k mile mark. I was starting to hear what I thought was the brake pad sensor rubbing against the rotors telling me to replace the pads. However, upon inspection I found both the inner and outer pads on both wheels had 8mm of thickness left on them (minimum thickness is 1.5mm per the Haynes manual). I can't believe there is that much brake pad material left after 70k miles! I understand that alot of my breaking is assisted by the engine when down shifting and this may be the reason there is so much pad material left. So I wanted to find out from our Toyota community how many miles before your first break job?:D
  2. Aug 9, 2013 at 5:51 AM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    sub'd
  3. Aug 9, 2013 at 5:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I replaced pads and rotors around 70k miles for the first time.
  4. Aug 9, 2013 at 5:54 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    I went 60k... Replaced with oem pads and rotors from the dealer.. Found it to be pretty neat you don't need tools to remove pads.
  5. Aug 9, 2013 at 6:01 AM
    travel_taco
    travel_taco Gentlemans Sausage
    CO
    09 Rust Bucket
    anti-fuel saving mods
    looked at mine last weekend and at 65k they still have plenty of life left in them. I wouldnt be surprised if I made it to 100k before replacing
  6. Aug 9, 2013 at 6:08 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    It all depends on highway or city miles.
  7. Aug 9, 2013 at 1:51 PM
    toyohtadude
    toyohtadude Well-Known Member
    Eric
    Austin, TX
    2017 4x4 Tundra SR5 CrewMax
    Bone stock
    I've got only 38k on my '07. Last inspection, they said the front is great but the rear needs replacement. I use the transmission a lot for slowing down. I always have on my Toyota vehicles.
    I have never heard of replacing the rear shoes before the front pads so I'm concerned. Regardless, I just had delivered yesterday new ceramic front pads and new rear shoes. I'm going to replace them all this weekend when I put on the wheel spacers.
    Anyone else have to replace rears first? Thoughts on why when the fronts are about 80% of your braking? Stumped.....
  8. Aug 9, 2013 at 6:17 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    110,000 miles on my '09. Haven't checked them lately but was at about 50% at 100K.
  9. Aug 9, 2013 at 7:32 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    127,xxx and still haven't changed them.
    Had a shop "clean & adjust" and flush new fluid in the spring but the pads still have some life left.
  10. Aug 9, 2013 at 7:42 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I replaced mine around 35,000. I still had life on them, but they where getting low, and I was taking a trip at the time, so I just changed em. A lot of hills around here so I think affects mine a lot. I got pads from Toyota, not just for life, but I like that they don't put out a ton of dust. When I got the new pads, the parts guy at the dealer was surprised I got that many miles with life left. I told him how I heard people where getting into a hundred thousand with original pads (read on here) and he didn't believe me. :laugh:
  11. Aug 10, 2013 at 6:53 AM
    OnTheTrail
    OnTheTrail Well-Known Member
    San Jose, CA
    2006 TRD Offroad
    Just replaced the front set at 141k miles. Lots of highway miles.
  12. Aug 10, 2013 at 8:05 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    My '94 T100 had 130k miles on it when I sold it. The original pads were nowhere near needing replacing. It has a lot to do with the kind of miles (highway vs city) and how you use engine braking.
  13. Aug 10, 2013 at 10:01 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not on my Toyota (20k), but my old Chevy Colorado needed rears at about 50k. Never replaced the fronts and traded it at 80k.
  14. Aug 10, 2013 at 10:23 PM
    NW4RUNNER
    NW4RUNNER Well-Known Member
    4 runner trail
    Im about 78K and I need them done soon. Clearly depends on how you drive ie- Lots of highway. My truck sat most of the time for about 8 years.
  15. Aug 11, 2013 at 6:07 AM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    Found out the GDMF shop that my wife took the truck to for inspection LIED! They said the rear brakes needed to be replaced. The shoes are within 1/16th inch of the new ones! This is obviously one of those shops that tries to take advantage of women. BASTARDS! Well, I have my next set of shoes and pads already bought and paid for.... Wagner PosiQuiet shoes and the same for the pads but in Ceramic.
  16. Aug 11, 2013 at 6:19 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    It really all depends on the driving conditions. I put 102k on my first 05 tacoma I bought new and never put brakes in it. According to the service records my current truck had them done around 100k, and the last 05 I had needed brakes at 60k. The last 2 trucks are autos and the first was a manual but truck # 2 was primarily city driven. The first and current trucks were mostly rural driving and highway miles. That said I've wasted a set of pads in a day at the track doing driver's schools. But obviously not in one of my trucks.
