How long should an alignment hold..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcubed, Aug 26, 2016.
  1. Aug 26, 2016 at 5:08 PM
    bcubed
    bcubed [OP] Well-Known Member
    Brent
    Calgary AB
    had my truck in for service today, apparently my right front wheel is out of alignment. This same one was out of alignment in February and they 'fixed' it. certainly haven't driven it hard (16000 kilometers between then). Alignment was also out after the first 8k (bought new, may 2014). Seems a little too often to me, and I don't wheel it at all..thoughts?
    Oh and the dealer wouldn't rotate tires cause of plastidip... guess they'll be explaining why they charged me in the past to do it if they 'cant'
    ManBeast likes this.
  2. Aug 26, 2016 at 5:09 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Should hold forever unless something is loose, broken, or you've hit a giant pothole
  3. Aug 26, 2016 at 5:09 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Hang them out to dry bro.
  4. Aug 26, 2016 at 5:10 PM
    ManBeast
    Zach
    Orange Park FL
    All 5 free services my plastidipped rims got rotated
  5. Aug 26, 2016 at 5:17 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    6 years, 175,000 miles, never needed an alignment, never changed any steering components, never wore tires, and averaged 45,000 miles per tire change after I got rid of the crappy OEMs.
    To answer your question, Toyota cars and trucks are great at holding an alignment. Same goes for my 2 Camrys.
  6. Aug 26, 2016 at 5:45 PM
    ManBeast
    Zach
    Orange Park FL
    Thats saying something pittsburge roads are shit
    jpmorrisvb likes this.
  7. Aug 26, 2016 at 5:47 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Once your alignment tabs are bent...
  8. Aug 26, 2016 at 5:52 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    Yep, I agree.
  9. Aug 26, 2016 at 5:58 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Wheel alignments are one of the most oversold services.
  10. Aug 26, 2016 at 7:28 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    It depends where you live. If your roads are shit and filled with potholes and such, alignments are a routine necessity.
  11. Aug 26, 2016 at 7:38 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    IMO, only need an alignment if you have a steering problem
    jpmorrisvb and danbow like this.
  12. Aug 26, 2016 at 8:01 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    No problem= no need to fix what ain't broke. I only get it done if I notice an issue such as pulling or uneven wear
  13. Aug 26, 2016 at 8:03 PM
    Bishop84
    Bishop84 Well-Known Member
    A lot of times shops get aggressive with the call for alignments, its possible they are seeing old wear from the alignment previously.
    I would do a diagonal rotation and see if the wear appears on the former opposite side tires.
    The eccentrics on the control arms do come loose, but usually its on lifted trucks that needed major adjustments and they are typically driven on service roads.
  14. Aug 27, 2016 at 8:38 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Your tires will tell when you need an alignment.
  15. Aug 27, 2016 at 8:51 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    yeah..NO! If the nuts are torqued properly, the eccentrics shouldn't be moving at all. I have a tab missing and alignment is fine, and it has been wheeled hard in Moab.
    Aussiek2000 likes this.
  16. Aug 28, 2016 at 7:21 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A properly aligned front end should last indefinitely as long as it isn't knocked out from and impact or from wear on various items such as bearings, ball joints, tie rods and so forth...
    Part of ( and very important ) is properly torquing the nuts and bolts holding everything in line. It sounds like somebody skipped this step.
    Other than getting an alignment check when getting new tires, the last time I needed an alignment was on my wife's 1988 Camry, from a huge pothole.
  17. Aug 28, 2016 at 4:00 PM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    try swapping your tires left to right. might be a tire problem if you have cheap or uneven wear on the fronts. alignment only goes straight if your tires are in good condition and has even wear.
  18. Sep 1, 2016 at 3:03 PM
    WheelInTheSky
    G
    Jackson Hole
    I'm glad that my joke went over your head, for your sake. In my personal experience, having bent tabs, any visible rust on eccentrics, or even blue sharpie on the eccentrics will cause 7 out of 10 alignment shops to feed you some bullshit spiel about why they can't align your vehicle, or why their "alignment" didn't last out of the parking lot. I have been through the ringer with alignment shops, the excuses are fucking endless. I have literally loosened all eccentrics and tie rods in a firestone parking lot, taken the truck in, told them it was all loosened before hand, then 90min later they give me the truck back having BOTH: made the alignment worse, AND claiming that all the eccentrics were seized. This part of the OP is what stood out to me as being shop-talk excuses and BS:
    "Alignment" is a bullshit industry. As previously stated, it is a vastly oversold pseudo-commodity.
    OldManTacoFeels and dtaco06 like this.
