How long have you gone one factory set of spark plugs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ddanjeong, Jan 11, 2022.
  1. Jan 12, 2022 at 8:43 AM
    slyguy47
    slyguy47 Nerd
    Jacksonville, FL
    15 AC TRD OR V6 4WD 5AT
    2nd gen here, but I'm currently at either 58.5k, or 88.5k depending on if the original owner did them at 30k or not. I meant to do them at 60k, but never got around to it. Plan on doing them at 90k for sure though!
  2. Jan 12, 2022 at 8:44 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I don't remember where I read about the plugs, but to keep your emissions warranty, you need to change the plugs at 60K. Modern iridium type plugs can probably go way longer in our trucks, but changing early ensures efficient operation (more complete burning of the fuel which can foul emissions equipment).
    I had a 2002 S10 that didn't get plugs changed until 100k. It ran fine the whole time. Don't use cheap plugs or wires as they will last 30k maybe.
    Edit: oh, I changed mine at 60k. They still looked good.
    Superdave1.0 and tonered like this.
  3. Jan 12, 2022 at 8:58 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I would surmise he's never changed plugs on a Subaru. Pulling the engine is probably easier lol. Made me miss changing plugs in my Jeep's 3.7L V6.
    Superdave1.0 likes this.
  4. Jan 12, 2022 at 9:28 AM
    Wapiti_chaser77
    Wapiti_chaser77 Well-Known Member
    IDAWHOE
    17 OR dcsb 6mt
    886’s, 90000’s, jba uca’s, ecgs, Fox 2.0 resi's and Icon rxt mediums in rear, wheelers super bumps, softopper, warrior products roof rack, smittybilt 10k, 255/85r16’s, coastal offroad front bumper, diff breather and a couple stickers
    Changed mine at 62k. Couldn’t really tell the difference in performance or throttle response, but I did see a small gain (.5) in mpg.
    Edit: Hey OP, third gen recommended is 60k.
    ddanjeong[OP], BOMBS and Tacospike like this.
  5. Jan 12, 2022 at 9:40 AM
    Tacospike
    Two Trucks
    Still on originals at 52K ~ 5 years, will change at 60K, which will probably be in a year or two. Maybe change them sooner if I'm bored.
    tcjacado, Skydvrr and shakerhood like this.
  6. Jan 12, 2022 at 9:48 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just changed the originals out of my 2007 at 32,500 miles... had been in there for 14 years.
  7. Jan 12, 2022 at 10:03 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    In my 60 years I have never ever noticed an improvement in starting/running/mileage after changing spark plugs as maintenance. I've had plugs that would fire when cold then, not when hot, some that had the porcelain cracked and some that were fouled and then, there was a difference after replacing. I've seen plugs with~120k miles that had the electrode severely worn and still ran fine.
    geo8866 likes this.
  8. Jan 12, 2022 at 10:04 AM
    BamaHound
    BamaHound Active Member
    Bama
    2019 OffRoad DCSB 6sp manual
    3" Old Man EMU front / 1.5" aal rear, Step Bars, No Chrome
    And the guy that lost compression on a cyclinder because the electrode burnt off (while it was running good past 60k) and fell between the rings and wall will never say, saving a few bucks and not changing his plugs was a good idea. IMO Toyota did not say 60k plug change to sell more plugs. These modern plugs dont look nothing like the 1st plug I changed in 1979 with a huge tip and melted down on 1 side like it touch the sun. These new plug tips are less than .5mm. Thats insane, and what the hell is irdium?
  9. Jan 12, 2022 at 10:11 AM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    For me it was a bit of if it ain't broke don't fix it plus procrastination saying I'd do it next oil change to tackle it all at once and never getting around to it. But I got to say the OEM ones were quality stuff to last that long.
  10. Jan 12, 2022 at 10:26 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I drove my 4cyl 2004 on original spark plugs for 165k miles. CEL came on, I changed them and kept going......
    I changed my 2017 3.5l iridium plugs at 70k, they could have gone to 100k, easy.
  11. Jan 12, 2022 at 10:30 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    My truck just turned 100k and I’m still on factory plugs. I’ll be changing them out soon, since my gas mileage is seeing a slight hit now. Getting 20-30 miles less mileage per tank of gas.
    ddanjeong[OP] likes this.
  12. Jan 12, 2022 at 10:32 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Wait. You can change the spark plugs?
    geo8866, capequahog, tcjacado and 3 others like this.
  13. Jan 12, 2022 at 10:40 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Back in my younger days, we would swap out plugs just to have something to do on a lazy summer day. :) After a year or two of use in those old carburetor engines with distributor cap timing, they could look pretty rough! But these days, with computer controlled electronic ignition, these plugs damn near last forever! I mean look at some of the pics being posted in this tread of plugs with 60K miles or more that look almost new!
    geo8866 and Montana_Actual like this.
  14. Jan 12, 2022 at 12:24 PM
    ddanjeong
    ddanjeong [OP] Well-Known Member
    Dan
    19 OffRoad Double Cab
    265/75r16 General Grabber AT/X Diode Dynamics SS3 Sport Fogs / Ditch Lights UpTop Overland Bravo Roof Rack
    Thank you for the photo
  15. Jan 12, 2022 at 1:45 PM
    #35
    Montana_Actual
    Montana_Actual ;)
    Wanna bet they never did them? lol. Time for some new plugs.
    I was also pretty amazed at how long people are stretching plugs in this thread. Not a smart move.
  16. Jan 12, 2022 at 1:54 PM
    #36
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    2.5 Gen, just bought this truck. I did a complete fluid change (aside from brake and power steering) and tune up at 37,000 miles. Changed the OEM plugs with Irridium.
  17. Jan 12, 2022 at 1:54 PM
    #37
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    80 k is the expected life unless you have a symptom of early failure. I’m prepared to defend my comments but my passion for the topic has already waned.
  18. Jan 12, 2022 at 2:14 PM
    #38
    slyguy47
    slyguy47 Nerd
    Jacksonville, FL
    Yeah it was always the one job that would take *just* the amount of work required to get passed over (not to say its hard though). It's also one of those things that doesn't warrant your daily attention like used up brakes or bare tires would (until the plug fails at least ;)). Having a garage now is also a huge blessing. Used to only have a parking spot to do all my maintenance in.
    Are there any indications the spark plugs are going bad that you can hear/feel, or is the only way taking one out and looking?
  19. Jan 12, 2022 at 2:19 PM
    #39
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    I changed mine at 150k. Still ran like new.
  20. Jan 12, 2022 at 2:24 PM
    #40
    Montana_Actual
    Montana_Actual ;)
    The plug chug. Lots of indicators. Drop in fuel economy. Hard starts. But usually beyond a certain time frame if you don't notice anything, you will notice the knock. Sometimes only under hard acceleration until it gets real bad then it's just gonna misfire all the time.
    slyguy47[QUOTED] likes this.
