How Long do 4 cyl. Tacoma Water Pumps Last?
Discussion in '1st Gen. Tacomas (1995-2004)' started by joshhemming, Apr 4, 2018.
  1. Apr 4, 2018 at 10:39 AM
    joshhemming
    joshhemming [OP] Active Member
    Josh
    El Paso
    03 Tacoma SR5 2.4L Extended Cab
    I thought I had lost the water pump on my 2003 2.4L at only 84,000 miles because coolant was dripping/dribbling onto the ground. Turned out to be the clamp on the new bottom radiator hose wasn't tight enough. I'd replaced the original spring tension clamp with worm gear type you tighten with a screwdriver. But it got me to wondering:
    If your water pump has had to be replaced, what was the approximate mile reading when it failed?
  2. Apr 4, 2018 at 10:41 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    don't worry, keep driving
    2002Tacoma4x4 likes this.
  3. Apr 4, 2018 at 11:09 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I replaced mine at about 125 on my 3.4L, but only because I was doing my timing belt too.
    I think the 2.4's having timing chains which iirc are lifetime. So I'd just keep an eye on the pulley (if it's loose or making noise, etc... replace it).
    Most people don't even think about their water pumps for at least 100k though...
  4. Apr 4, 2018 at 11:30 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    So far it has lasted 260k without leaking and I have no cooling issues.
    BillsSR5 and 2002Tacoma4x4 like this.
  5. Apr 4, 2018 at 12:22 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Replaced mine at 175k due to the gasket leaking. The pump was still perfectly fine. It has a metal impeller so the only thing that could go bad would be the bearing.
  6. Apr 5, 2018 at 9:54 AM
    joshhemming
    Josh
    El Paso
    Thanks for the reassurances. Sounds like I'm good for at least 80,000 more miles on this original pump. By that time I'll probably need to replace the belts again (just did them at 84,000) so I may do the pump at the same time as a pre-emptive measure.
  7. Apr 5, 2018 at 11:11 AM
    ggmanning
    ggmanning Well-Known Member
    07 FJC, 03 TRD Offroad, 11 TRDPro, 14 Landcruiser
    Replaced mine at 72,000 because I was in there doing the timing belt and it's 15 years old.....I will say it looked perfect but while I was there I also did the crank seals and a new crank bolt. Just made sense when I had the front off the engine. I'd say no issue whatsoever going a while on the pump but I will never get past about 90-100000 on one because I will always change it with the timing belt
  8. Apr 5, 2018 at 11:13 AM
    Speedytech7
    Tacoma 4cyls have timing chains, and you can change the WP without removing much else.
  9. Apr 5, 2018 at 11:25 AM
    ggmanning
    All hell I missed 4cyl. So anyway on a 3.4............o_O
  10. Apr 5, 2018 at 11:59 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    319k miles and 23 years on the original pump (2.7 engine). The only "pump related" parts I replaced was belt and coolant.
    BillsSR5 likes this.
  11. Apr 5, 2018 at 4:53 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Haven't done my 3rz Taco, but my 92 pick up with the 22re went at 196000. The mechanic said it was more the pulley making noise than the pump being bad though.
  12. Apr 5, 2018 at 5:08 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I'm not a fan of worm drive clamps. In my experience they ruin the hose
    awdvkd115 likes this.
  13. Apr 5, 2018 at 5:13 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    2.7L 2001 4door
    231k miles
    Original water pump
  14. Apr 5, 2018 at 5:34 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I've found the biggest longevity to a water pump is keeping the fluid changed and fresh, it acts as a lubricant. I had one back in the day where I neglected to change it. This was in my dumb years as a shade tree mechanic, truck started overheating just a little and I couldn't figure out why,,, full of coolant, no leaks, nothing.
    Finally tore it down and when I pulled the pump, the whole impellar was gone, ate up, just a few ribs left of what use to be the blades of the impellar, it was not circulating no coolant at all.
  15. Apr 7, 2018 at 10:06 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've wondered the same thing. Mine was replaced under warranty at 60,000 miles. It's got 171,000+ miles on it now. Have thought about buying one just to have on hand for when it does go but since so many have gone 250,000+ without replacing one I have to wonder. I'll probably get one this summer just so I have one. The same for a starter and alternator.
    You never know.
  16. Apr 7, 2018 at 10:09 PM
    Speedytech7
    Alternator is a good call, they typically need brushes anywhere from 200k - 300k. The starter is rebuildable though and will last a very long time.
  17. Apr 8, 2018 at 5:58 AM
    drock3
    drock3 Well-Known Member
    Derek
    California
    97 2.7L 5 Speed 4x4
    Stock as of now.
    97' with 165k miles on her. Original water pump, no issues.
  18. Apr 8, 2018 at 6:08 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    water pump/timing belt @ 210k 3.4L
  19. Apr 8, 2018 at 3:43 PM
    joshhemming
    Josh
    El Paso
    I see most of the replies to my question are from 2.7L owners. Mine is a 2.4L. Does the 2.4 and 2.7 use the same water pump?
  20. Apr 8, 2018 at 3:49 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    My 98 4cyl lasted till the frame rusted out about 2yrs ago
    Had sold it to my friend
    Almost 300k
