How long did your starter last??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomagirl76, Nov 10, 2016.
  1. Nov 10, 2016 at 12:56 PM
    Tacomagirl76
    Tacomagirl76 [OP] REG. CABS RULE!
    Some where in New England!
    2014tacoma reg cab
    Duratra wrangler tires,tinted windows,kicker rear speakers,JL Audio front,fosgate amp. More to come
    In my 1st truck a 1999 taco I had to replace the starter at 50K. How about you? Just wondering what the norm is.
  2. Nov 10, 2016 at 12:58 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't think they wear out very often, I do recall seeing some rebuild kits that had new brushes in it though.
  3. Nov 10, 2016 at 1:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    Depends on a bit of luck of the draw, and how they are treated.
    Suspect ones regularly submerged and covered in salt slush to have a higher fail rate.
    I'd have to think hard for my last starter failure on any marquee. Probably back in the 70's on a 60's vehicle.......
    I've never had a failure on a Japanese vehicle. But I've usually sold them to family or friends around 150k or so. :thumbsup:
  4. Nov 10, 2016 at 1:06 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    +1 on the "never failure on Japanese vehicle" Original going strong at 123K miles so far. Which means today it will go out.
    Benzdriver81 and shakerhood like this.
  5. Nov 10, 2016 at 1:12 PM
    mizhop
    mizhop Well-Known Member
    central IL
    05 Prerunner, 2WD 6spd(mine) & '95 DLX 2WD (his)
    Starter failed in my '05 last year. Around....oh...78K, maybe. Thought it might be the battery first, but no. So now I have a new battery and a new starter.
    Once under there, I alarmingly found that one of the mounting bolts had backed itself out quite a bit, which maybe contributed to the failure...? I have no idea.
  6. Nov 10, 2016 at 3:30 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I have never had a starter fail on a vehicle. on a Ford Escorts I had it wouldn't work once, so we tapped on it with a hammer. never a issue again.
  7. Nov 10, 2016 at 3:32 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The question should be, what are you doing thats killing your starter?
  8. Nov 10, 2016 at 3:54 PM
    mizhop
    central IL
    Oh yes, the hammer. LOL. When it failed to start when I was at work the first time, I had completely forgotten about the hammer trick. So while I waited for a starter I had on order to come in (local prices were stupidly expensive), the hammer is what was used to help persuade the failing one to keep going a little longer.
  9. Nov 10, 2016 at 3:58 PM
    shakerhood
    Southern Ohio
    I think the only starter failure I've ever had was on my old VW Golf, it was right around 10 years and just under 200k miles.
  10. Nov 10, 2016 at 4:02 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    The starter on my 85 truck was the ONLY failure that I had with the truck. Went out at about 90k.
  11. Nov 10, 2016 at 4:03 PM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    Exactly what happends mounting bolts backed out and probably messed your starter up, I had a original last me 300k my first gen is at 150k with original hoping to last till 300k
  12. Nov 10, 2016 at 4:04 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Mine started going out at 175k
  13. Nov 10, 2016 at 4:57 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    No, tomorrow morning lol
  14. Nov 10, 2016 at 4:58 PM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    ^^^this. Easiest way to fix a sticky solenoid :thumbsup:
  15. Nov 10, 2016 at 6:22 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    All of my Honda's and Toyota's(except one) have gone 175K - 185K before the contact sets needed replacing. When that happened, I pulled the starter and took to a local electrical rebuilder. My '06 Avalon has 212K on it and is still running the original starter.
    No road salts, harsh winter or humid salt water air in my neck of the woods.
  16. Nov 10, 2016 at 6:43 PM
    Tacomagirl76
    2014tacoma reg cab
    Thanks for your input. I probably just had bad luck with my first truck. Right now I only have 33K on my 2014 reg cab.
  17. Nov 10, 2016 at 6:55 PM
    Lester Lugnut
    Yep. I ad to replace a water pump on a 2004 Tacoma 4 banger after just 65K miles. Things happen.
  18. Nov 10, 2016 at 8:12 PM
    shakerhood
    Southern Ohio
    The only issues I ever had on my old 2000 was the Power Steering Pump and my Windshield Washer Reservoir sprung a leak.
  19. Nov 11, 2016 at 7:11 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had to replace my starter in my 98 when it had about 75k miles. It was about 12 yrs old at the time.
  20. Nov 11, 2016 at 7:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    2005 Tundra with 68k miles on it when purchased. Now has over 250k and no starter issues. It has a feature that I've never seen on other vehicles. I don't have to hold the key to start it; just bump it to the start position and it starts by itself.
