How long can I use the 110v outlet before battery dies?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CementKevin, Jul 17, 2018.
  1. Jul 17, 2018 at 9:31 PM
    CementKevin
    CementKevin [OP] Active Member
    Kevin
    2018 Cement Tacoma Offroad 4x4
    How long can I use the AC outlet in the back of my truck before I need to worry about the battery dying? I’m going camping a couple weeks I don’t want to leave myself stranded.
    Thanks,
    Kevin
  2. Jul 17, 2018 at 9:33 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It only works with the engine running......so never, until you run out of gas.
    Prairie Hawk, Lucifer1 and shakerhood like this.
  3. Jul 17, 2018 at 9:34 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Others will he able to say exactly on a stock battery.
    If you go camping a lot, I’d suggest a small solar array ($100) and/or a small gas generator (few hundred $). These will definitely keep you from being stranded.
  4. Jul 17, 2018 at 9:35 PM
    scocar
    scocar hypotenoper
    Until you run out of gas.
    Page 466 of your owner's manual
    https://www.toyota.com/t3Portal/document/om-s/OM04017U/pdf/OM04017U.pdf
    sadmrhappy, DubfromGA and shakerhood like this.
  5. Jul 17, 2018 at 9:39 PM
    CementKevin
    Kevin
    Thanks guys. Good to know.
  6. Jul 17, 2018 at 9:39 PM
    Grossomotto
    2017 4WDV6LB6MT
  7. Jul 17, 2018 at 9:42 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    What is the draw of the device in watts? Convert this to (milli)amps and find out the capacity of the battery. This is always a variable, as batteries degrade over time. Figure out what amperage is needed to start the truck and the remainder is the power you have to use for the device.
    This is probably not a sine wave converter, but a diode bridge, so not as efficient. ( correct me if i am wrong, tech class was a ways back.) Maybe 80%.
    Honestly, solar panels are a great purchase. At least in the summer, a battery holds a much better charge than in winter.
    What are you thinking of running?
  8. Jul 17, 2018 at 9:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    What are you planning on using it for?
  9. Jul 17, 2018 at 10:31 PM
    Philsummers21
    Philsummers21 Well-Known Member
    Phil
    20 OR LB
    Icon stage 4, 285/75-17 KO2, 5.29 gears
    I can use my 110 just fine without the truck running. Just turn that acc on and push the button. Whalla, use it for my traeger all the time
    CementKevin[OP] likes this.
  10. Jul 17, 2018 at 10:44 PM
    Grossomotto
    2017 4WDV6LB6MT
    Yeah I’ve used it for a Makita cut off tool for 15 minutes or more without the truck running. Not sure why the manual would say otherwise.
  11. Jul 17, 2018 at 10:46 PM
    Philsummers21
    Phil
    20 OR LB
    I’ve probably ran my smoker for an hour
  12. Jul 17, 2018 at 11:01 PM
    CementKevin
    Kevin
    Keurig coffeemaker as a joke and make coffee. Lol. And maybe connect some chargers, etc. not sure yet. I just wanted to know how long I could use it before it risked draining the battery. There will be others there that can jump start me if needed I guess.
    shakerhood[QUOTED] likes this.
  13. Jul 17, 2018 at 11:05 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You can also pull the relay under the hood and jump the pins. Then it really works all the time even with no key, and at 400W capacity
    @T.A.C.O.M.A likes this.
  14. Jul 17, 2018 at 11:07 PM
    Stocklocker
    17TRDORDCSBAT
    Lead acid starting batteries are permanently damaged by deep discharges. Do not just rely on your buds to jump-start you, as you may ruin you battery if you run it right down.
    s.e.charles likes this.
  15. Jul 18, 2018 at 6:20 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Good luck with that.
    "Keurig® home brewers use the most power during their initial startup. When heating for the first time after being off, peak usage is 1,500 watts. If the power is kept on, the brewer will keep the internal tank up to temperature using between 200 – 400 watts when heating."
  16. Jul 18, 2018 at 8:56 AM
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    Yeah, heating elements and compressors draw a bunch.
  17. Jul 18, 2018 at 9:07 AM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    if you are looking for something to run frequently and dont want to run your engine.......i would cobble together a basic solar power supply.
    a couple DEEP CYCLE lead acid batteries, a solar panel, a charge controller, and a small inverter...you could put together a decent setup for <$500 and wouldnt have to worry about draining your starter battery.
  18. Jul 18, 2018 at 9:21 AM
    CementKevin
    Kevin
    Darn! Wishful thinking. LOL
  19. Jul 18, 2018 at 9:32 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Can't chime in on how long your battery will last but....if it dies...
    I'd recommend getting a portable battery jumper - if your battery dies and you're alone, you can jump yourself. They're around $70 for a decent one that can jump large motors..I've used mine several times to help other people who are stranded, plus they double as a large cell phone charger and flash light if needed. Keep mine in my truck and charge it usually once every month or so (usually 95% battery remaining after 1-2months)
    CementKevin[OP] and Woofer2609 like this.
