How long before Water Pump Replacement 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wmgeorge, Dec 13, 2020.
  1. Dec 13, 2020 at 4:02 PM
    wmgeorge
    wmgeorge [OP] Well-Known Member
    Just purchased a 2015 V6 with 85,000 miles. What is the service life of those water pumps?
  2. Dec 13, 2020 at 4:13 PM
    Lthompson
    Lthompson Well-Known Member
    i honestly think my water pump is the source of my squeaky belts and always has been. i think it drags.. but you cant tell by listening to anything. Been dealing with it since around 65k. around 106k now
    Juice Weasel likes this.
  3. Dec 13, 2020 at 4:20 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Have 404,000 on my pump
  4. Dec 13, 2020 at 4:24 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    My wife's 2003 Corolla had 256K on same water pump. If I were to replace a 1st gen or 2gen water pump for preventive maintenance I would say 135K. If I had a turd gen then probably 3 thousand miles would be my goal. :crapstorm:
    crackils, PennSilverTaco and T-yoda like this.
  5. Dec 13, 2020 at 4:33 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
  6. Dec 13, 2020 at 4:36 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    114K on my 2010 and haven't touched it.
  7. Dec 13, 2020 at 4:42 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    The water pump will usually give you quite a bit of notice if there is an issue. It’s not a preventative maintenance item in my opinion.
    I would be more concerned about your idler pulleys, lower control arm bushings/ball joints, and steering rack. Oh, and your door lock actuators...
    whatstcp, Juice Weasel and Gen2Tacoma like this.
  8. Dec 13, 2020 at 4:49 PM
    TacoTuesday1
    FL
    You know man
    I don't know. These parts seem to have different life expectancies. For example, many 2nd gen owners, despite high miles and years age, have never looked at their rear brakes.
    But on a German car, rear brakes would already have worn out by now. But they're discs/pads.
    Same thing for water pumps. On German cars? 100k mile item. Their bearings can fail. The impeller can fail. The seal holding coolant in can fail.
    Coolant is slippery. Something has to be causing your belt squeal. And yes, if coolant gets on there, that's not good for the belt.
    If I were you, I'd figure out if the system has a leak.
    You can inspect visually. Maybe clean off the area. I don't know of other ways such as if there are UV dye additives.
    But a common way is pressure testing the system. I don't know the best safe PSI/pressure to test it at, or what the radiator cap opens at. Stock or TRD cap.
    As to avoid bursting anything.
    Maybe 10, 15, or 20 psi?
    That pressure test can help expose coolant from leak areas. Or a vacuum test that sucks it in and makes noise.
    Or you can just say fuck it, load up the parts cannon, and start throwing shit at the truck. Which in this case, would be just one part. The water pump. Which is not so bad. At least then you have piece of mind knowing it's replaced.
    It's not like a parts cannon with suspension, where a person might be unable to pinpoint a specific noise and then spend a lot replacing each and every many suspension component.
    A water pump is just one part. Not ten.
    Well I guess two if you add a thermostat or something else.
    On the plus side, if the vehicle is due for new coolant, this lets you do that.
    Also supposedly lack of coolant replacement (if that happened) can also lead to corrosion and debris that may not be good for water pumps
    In general though, Toyota parts seem to last longer than many cars, for whatever reason.
    I don't know if they're better designed. For example some of the parts look weird.
    So maybe the WP could have a longer lifespan.
    Plus WP getting changed on passenger cars is usually because it's done at the same time as routine timing belt service. Whereas 1GR-FE V6 has timing chain that lasts longer.
    There's not too many places to check for leaks. Water pump. Hoses. etc.
  9. Dec 13, 2020 at 4:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t know if there is a “Service” recommendation?
    I will probably replace mine when it starts leaking or I feel it isn’t cooling sufficiently.
    I would service the Coolant (Anti-freeze) by 100k or 10 years
    Then every 50k or 5 years.
    whatstcp likes this.
  10. Dec 13, 2020 at 5:04 PM
    wmgeorge
    Squeaky belt not me? But I have had serpentine belts get glazed that squeaked and replaced to solve.
    Water pump, I have replaced on a Chevy truck... when it leaked. I was just asking to find out how long they lasted.
  11. Dec 13, 2020 at 5:05 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Is this for 4.0Ls, 2.7Ls, or both? I’ve got a 2.7L with almost 122K...
  12. Dec 13, 2020 at 5:11 PM
    Gen2Tacoma
    North East Atlanta
    It's a water pump....it will give you signs that it's gong bad! But very detailed none the less!
    Accipiter13 and PennSilverTaco like this.
  13. Dec 13, 2020 at 7:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So you just use the same interval as any other vehicle. When the water pump fails or leaks excessively you replaced it.
    Lester Lugnut likes this.
  14. Dec 13, 2020 at 7:53 PM
    chetterthecat
    chetterthecat Well-Known Member
    OR
    13 sport
    I have 146k on my stock one... Waiting for signs...
  15. Dec 14, 2020 at 4:35 AM
    wmgeorge
    Ok guys thanks... just checking to see if I needed to R&R before long, and its winter here in Iowa.
  16. Dec 14, 2020 at 7:51 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    What I remember.....1st Gen 3.4L---when U replaced the T/belt
    Just replaced water pump same time....that was 90-100K IIRC
    Yes...we're talkin' 4.0L
    My '14 has 91K & original w/pump
  17. Dec 14, 2020 at 7:55 AM
    Bishop84
    Bishop84 Well-Known Member
    I've worked on Toyota since 2005 and have only replaced about 10 water pumps on 4.0s. They are not common and coolant replacements usually prevent failure.
    More common is idler bearings howling. Alternators as well.
    Accipiter13 and Juice Weasel like this.
  18. Dec 14, 2020 at 8:34 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Yes I had to replace alternator at 132k on a 2006 prerunner, it was the source of high pitched whine. Word to the wise don’t try to save a few dollars using a cheap replacement, use the OEM Denso. I’ve owned six gen 2 trucks never had to replace a water pump all over 100,000 miles. I do replace coolant every 3-4 years regardless of mileage.
  19. Dec 14, 2020 at 10:34 AM
    BertH2O
    BertH2O Well-Known Member
    Bert
    Bay Area, CA
    2015 Tacoma TRD Pro AC
    I just replaced my water pump. I have a 2015 with 75k miles. I am the second owner.
    When I bought the Tacoma last November 2019, it had just under 72k miles and the dealer said they swapped all fluids. No way for me to completely verify that, but when I swapped the water pump, my coolant was still nice and pink.
    Anyhoo, I had a chirping ticking noise. I had just driven about 200 miles back home, parked the truck, came back 4 hours later and the noise started. First time I ever heard it.
    I had recently (like 500 miles previous) replaced belt, pulley 1 and 2's, and the idler pulley. Thought it was a stretched belt so swapped that with an OEM belt and the noise was still there. Also thought it was my power steering pump after a recent steering rack upgrade (tundra rack!). Eventually I found the noise with a mechanic's stethoscope...and by slowly turning the fan clutch with no belt on.
    I have never changed a water pump on any vehicle, and with the awesome youtube video and numerous write ups on here, it was surprisingly easy and straight forward.
    wmgeorge[OP] likes this.
  20. Dec 14, 2020 at 10:41 AM
    wmgeorge
    I learned about cheap alternators, after 2 Pos AutoZone ones I went to the auto electric shop near me and got one professionally rebuilt.
