How important is hub-centric? Hub bore is 106.1? Tolerance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rzgkane, Mar 11, 2019.
  1. Mar 11, 2019 at 12:24 PM
    rzgkane
    rzgkane [OP] Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I'm looking for wheels for my rig. How important do you guys feel it is to have hub-centric wheels?
    Some wheel manufacturer website don't even list the hub bore.
    I see our hub bore is 106.1 but I also see wheels out there with specs of 106.25. Is there wiggle room here? How dead on are these measurements from wheel mfg to wheel mfg?
  2. Mar 11, 2019 at 12:27 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Try to measure out .1 of a millimeter and tell me if you think it'll be a big difference. All I'm gonna say is I've seen tires a few millimeters out of round pass as road worthy. Also, consider 108mm rims and a 2mm hub ring spacer as a combo, it'll open up options for you.
  3. Mar 11, 2019 at 12:34 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    almost all aftermarket wheels are lug centric with oversized hub bores so they can fit on more vehicles. OE wheels are hub centric since the manufacturer has to only worry about fitting on one vehicle.
    BearWithMe and velogeek like this.
  4. Mar 11, 2019 at 12:59 PM
    rzgkane
    Oh, I hear you. Trust me. But .1mm is a huge effing deal in the wrong place. I was leaning not so much when it comes to wheels to hub fitment but thought I'd ask the collective brain (or lack thereof) trust.
    photogr4x4 and r1200gs4ok like this.
  5. Mar 11, 2019 at 1:00 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I was going to put Mickey Thompson wheels on my truck but they were not hub centric. I looked at allot of wheels online and didn't want spacers. Finally I decided to buy Toyota oem alloy wheels so I would sleep better at night. Cannot wait till the weather warms up so I can put some tire shine on the tires. :)
    photogr4x4, epa4wd, bulalo and 2 others like this.
  6. Mar 11, 2019 at 1:01 PM
    rzgkane
    Looks good. But I just feel I gotta do something different. Soooo many of those out there right now. I'm thinking Method 313's but they ain't cheap.
    photogr4x4 likes this.
  7. Mar 11, 2019 at 1:04 PM
    CusterFan
    Ha, Ha. I know what you mean. I looked at SCS Ray10's. Loved em but not for how much they cost.
  8. Mar 11, 2019 at 1:05 PM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    be wary of non hub size matching wheels. the toyota steering rack is very sensitive to out of balance / out of round wheels. I actually returned my methods via DTD due to them being unable to balance out and not shake. they refused hubcentric rings saying they weren't necessary. The issue is that just because the wheel may be lug centric, it may be slightly off center from the axle when torqued down causing vibration.
    my fj, my 4runner, and now the tacoma all had this issue. some folks don't have the issue or get lucky. others just don't care.
    08BajaBoy, CusterFan and na8rboy like this.
  9. Mar 11, 2019 at 1:10 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I have a laugh when fellas complain about driveline vibrations and curse Toyota, then in their pictures they are running Chinese knock-off lug-centric wheels. Like WTF? o_O
    :facepalm:
  10. Mar 11, 2019 at 1:13 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    This right here... Took more wheel and tire courses than I'd care to admit when I managed a Goodyear shop and basically, hub-centric wheels are capable of better tolerances and better balance if they are properly made for the application. This is why OEM wheels are frequently made hub-centric since they're only for one vehicle (thought they generally work on similar configurations like year-to-year and Taco-4Runner).
  11. Mar 11, 2019 at 1:17 PM
    rzgkane
    Nothing's ever easy or free. Half say no prob, the other half say hubcentric only. I can almost guarantee that if I buy non hubcentric wheels, THEY WILL shake rattle and roll. And nobody will take responsibility for it.
    What's DTD?
    oconnor likes this.
  12. Mar 11, 2019 at 2:24 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Toyota wheels studs are designed to provide clamping force they are not designed to hold the weight of the vehicle which is one of the reasons why the wheels are hub centric.
    71tattooguy, nsg44 and CusterFan like this.
  13. Mar 11, 2019 at 4:36 PM
    commbubba19
    '23 TRD PRO
    Discount tire direct.
    My hub centric wheels still needed road force balancing.
    The problem is more the steering rack design.
  14. Mar 11, 2019 at 4:39 PM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I wouldn't chance lug centric wheels on a truck designed for hub centric wheels. Nobody is gonna tell you what your risk tolerance is, though. I've sheared lugs at speed in this truck, and I am not interested in ever having that happen again.
  15. Mar 11, 2019 at 5:50 PM
    JimmySport
    JimmySport Well-Known Member
    I always, always, ALWAYS run hub centric wheels. If I can't find aftermarket wheels with the correct hub bore, I pass. That is one of the main reasons I have T4R Pro 17" wheels on mine. I knew they wouldn't give me any issues.
  16. Mar 11, 2019 at 6:17 PM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    I feel like I am dealing with the same issues. I recently started to investigate my shakes. I had the shakes on the factory rims with stock tires and larger tires. I had KM3's installed and the shop that installed them is not my usually shop. So I was surprised when I drove away and didn't feel the shakes. Couple months later I installed 4" lift spindles and AAL and the shakes came back immediately. I installed the hub centric rings (and removed center caps because I could not install both at the same time - method mesh 16x8) and it helped slightly. But when I was installing the rings I noticed one rim had the hub bore ground down (powder coat missing) and a second rim had the slightest elongation in each lug hole. It's perceptible by feel. Then it dawned on me, my original shop probably ground the hub diameter down because the elongation was enough where they couldn't get the rim on over the center cap. The crappiest part about the whole thing is method doesn't offer my size rim in that style any longer.
  17. Mar 11, 2019 at 6:20 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    i am kind of dumb on this subject....but what does "T4R Pro 17" " mean......is it toyota 4 runner Pro 17"wheels?
  18. Mar 11, 2019 at 6:53 PM
    JimmySport
    you got it Sir.
  19. Mar 12, 2019 at 9:03 AM
    rzgkane
  20. Mar 12, 2019 at 9:40 AM
    dspec
    dspec Well-Known Member
