How hard is it to install side steps?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 19taco4x4, Nov 12, 2018.
  1. Nov 12, 2018 at 8:07 PM
    19taco4x4
    19taco4x4 [OP] Well-Known Member
    Jesse
    21 Silver SR
    Hey everyone,
    Complete noob when it comes to installs, but I’ve been looking at installs on YouTube and they don’t seem to be that hard. Am I missing something or should this be quick and easy? Thanks in advance. Also let me know what you guys are running.
    Tocamo likes this.
  2. Nov 12, 2018 at 8:12 PM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    If you can use a socket set and a jack, you should be fine.
    19taco4x4[OP] and Vbpiper like this.
  3. Nov 12, 2018 at 8:14 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    What he said^
    All you need is a socket and ratcheting wrench and an extra set of hands or jack stands. Very simple.
  4. Nov 12, 2018 at 8:16 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Don't even need a jack.
    DoubleB, 19taco4x4[OP] and tcjacado like this.
  5. Nov 12, 2018 at 8:17 PM
    SCJeffro
    SCJeffro @Voodoo_Blu_Taco
    2021 Voodoo Blue TRD Sport
    On a scale of 1-10 it is maybe a 1.5... not quite a 2... it is super easy, easier if you have 2 sets of hands cause they are kind of awkward to hold, maneuver, lift by yourself.
    https://youtu.be/aucOSIlh8-4 "how to"
  6. Nov 12, 2018 at 8:19 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    I removed the Predator steps and sold them, then installed some Lund 5” oval steps all by myself. Didn’t scratch either pair but both were pretty light. Easy peasy.
  7. Nov 12, 2018 at 8:21 PM
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    Took me 30 mins to install both Predator steps on my dad's 3rd Gen. There's only 6 bolts on each side. Didn't even need a jack. They were really light.
  8. Nov 12, 2018 at 8:24 PM
    ls7alex
    ls7alex Well-Known Member
    Newark
    Taco gang
    6 bolts each side. No jack needed. Superrrrrr easy. Post up pics when done
  9. Nov 12, 2018 at 8:34 PM
    phsycle
    phsycle Well-Known Member
    CA
    As others have said, if you can install a light bulb, you can do this. But pick up some anti-seize as well. I slathered on plenty when I bolted up my old one.
    19taco4x4[OP] likes this.
  10. Nov 12, 2018 at 8:55 PM
    awdj
    awdj Well-Known Member
    20' Tacoma TRD PRO
  11. Apr 6, 2025 at 5:10 PM
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
  12. Apr 6, 2025 at 5:30 PM
    MystiqueTaco
    MystiqueTaco On my 4th Tacoma since 2001!
    Kevin
    Phoenix, AZ
    2019 Tacoma 4x4 Off-Road - Blue
    Stock (for now) with some mild conveniences thanks to Amazon.
    Probably one of the easiest mods you can do on a Tacoma. Most running steps are super light. Its when you get into the rockers that becomes a little more advanced but even that is direct bolt-on but the weight definitely requires a jack or extra set of hands on those.
  13. Apr 6, 2025 at 7:16 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    On a scale of 1-10, the Predator steps are a 1.1
    Only slightly harder than changing your license plate.
  14. Apr 7, 2025 at 1:44 PM
    eaglehawaii
    eaglehawaii Active Member
    Hawaii
    22 Super White.. ... 18 Magnetic Gray ... 02 Gold RIP in 25
    Not mechanically inclined but installing one at least the one I got was straightforward.
    I got the IronBison Defender which is heavy duty ... emphasis on heavy ... LOL. I like that it extends farther out than most to help get into the cab easier and could also help prevent dings.
    I installed it myself. What helped me was that I used the box to hold it in place to carry the weight under the truck. That allowed me to line up the heavy duty bolts and secure the step to the truck.
