how good is an LSD offroad
Discussion in 'Off-Roading & Trails' started by adamw, Jan 9, 2012.
  1. Jan 11, 2012 at 5:52 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    this regular cab so It did not have factory LSD. Did you installed by yourself?
  2. Jan 11, 2012 at 7:36 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    ALSD can do what you can't, which is brake one wheel independent of the other.
    In fact, TRAC does this on all four, but does not work in 4lo out of the box, but that's why there's the yellow wire mod.
    If you're going to go to the trouble of swapping a diff for off roading purposes, tho, go selectable locker.
  3. Jan 11, 2012 at 11:07 PM
    InactiveUser
    InactiveUser Untitled
    Unknown
    looking
    Invisible
    Locking differential is better off road.
  4. Jan 11, 2012 at 11:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Actually I'm pretty impressed with what the Limited Slip TRD Sport can do with the right driver behind the wheel, we have a couple members here that I trail with (RecklessTaco) & (Gregero) & i promise it'd blow you away to see where these guys can get their trucks, & the guys with locked prerunners did no better, no worse....
  5. Jan 12, 2012 at 4:04 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Errmmm...IDK if there is a thread. This is a technique I learned driving up north.
    You have a 4L V6 stick truck...so you have the pull handle e-brake. That is what I use but you can use the pedal as well.
    When you are on an obstacle and you start to lift a tire and your spotter tells you that you are spinning just that one. Pull the ebrake- SLOWLY and be ready to release it and/or put both hands back on the wheel-until that up wheel locks or slows down. You SHOULD feel the truck kick/buck as the low tire gets some drive. Your spotter may also see it spin.
    I was stuck with my right rear tire up, pumpkin on the ground, going over a ledge, downhill in 4LO. The front tires were pulling and you could see what the pumpkin plowed up a pie in front of it-Cleaned that out and a couple tugs on the ebrake and that was enuf grip to push the truck over the ledge.
    Anyone else feel free to add to this...I am by no means an expert and there may be better ways to explain this.
  6. Jan 12, 2012 at 5:57 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Gets me through stuff like this. I still want lockers front and rear. Mostly the front locker, to help the front wheels climb up vertical rock faces.
  7. Jan 12, 2012 at 7:38 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Without turning this into a traction control thread, I felt the need to clarify.
    2006-2008 4wd OR's equiped with the TRAC option have TRAC in 4lo. Stock, without modification.
  8. Jan 12, 2012 at 8:08 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Yep, I had it installed.
  9. Jan 12, 2012 at 4:22 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Agreed. I want the same, but I was reading something about ill effects having the front locked and a limited slip in the back. I'd have to look it up again myself, but from what I read, it wasn't advised.
  10. Jan 12, 2012 at 4:54 PM
    BlueT
    NorthEast
    Ok. Your sig says Detroit so I am assuming you have Truetrac. If thats true, what you see is exactly what truetrac will do. There is no preload there so it will simply not work with one wheel in the air.
  11. Jan 17, 2012 at 12:25 AM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Forget it all, just buy a spool for the rear diff....
  12. Jan 17, 2012 at 1:37 AM
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    I have a 2006 4X4 SR5 doublecab... I just crawled under it a minute ago and there is a sticker on the rear diff that says "only LSD oil"...
    I'm psyched!:D
    I have not had the truck for very long (new member,) but I have had it on some pretty rough trails and it performed well. I thought maybe it had a limited slip but I wasn't 100% sure till now...
  13. Jan 17, 2012 at 1:50 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    if your buddy was in 4lo without the yellow wire mod he was open/open
    My truck did some amazing shit with just the TRAC system. I walked around a lot of Mech. LSD trucks.
    Trac is E LSD on front and rear.
  14. Jan 17, 2012 at 12:15 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    so my alsd (trac) is actually better than a mechanical lsd? because if I have a wheel in the air, it will still drive the wheel on the ground.
  15. Jan 17, 2012 at 12:19 PM
    #35
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Yes, it also works on all 4 wheels. In normal situations where a mech. lsd is able to work though, it will transfer more power than a-lsd
  16. Jan 17, 2012 at 6:25 PM
    #36
    go8soccer
    go8soccer Memba
    Grovetown, GA
    '08 Super White DC LB Prerunner Sport
    Leaf TSB, front Billie 5100's (1.75"), 265x70x17 BFG Rugged Terrain
  17. Jan 17, 2012 at 10:56 PM
    #37
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Yeah but the e-LSD (autoLSD) doesn't work in 4lo. It's open diffs. But a mechanical LSD works in all settings .. 2, 4hi, and 4lo.
  18. Jan 17, 2012 at 10:59 PM
    #38
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    x2 gazillion billion.. the "poor mans locker" really does work well
    2 of my buddies (J4RR, and dtrujillo63)with the Sport model and while using the "poor mans locker" have made up some pretty intense trails and they made it look easy..even out performing a FJC that was always with us that was trying to get up the same stuff while having ATRAC engaged.. go figure. eventualy one of the Sport owners (dtrujillo63) wised up and upgraded to the ARB lockers front and rear, and our FJC buddy eventually learned that ATRAC doesnt live up to it's hype on the more extreme trails haha.
  19. Jan 18, 2012 at 6:27 AM
    #39
    Mi Vida Taco
    Mi Vida Taco Well-Known Member
    Texas
    2010 taco
    sport 4x4 with lsd. Ive done some pretty wicked stuff with this truck, I would like an arb locker but i do just fine and have gone off roading plenty and a little crawlin too.
  20. Jan 18, 2012 at 7:28 AM
    #40
    GP3
    California
    4X4 TRD Off Road
    Not 100% true. It depends what year and package you have on your truck.
    05-08 (Off Road; TRAC equipped) - TRAC works in 4Lo
    09-12 (Off Road) - ATRAC works in 4Lo
    So, with the right truck, e-lsd works in all modes just like the mechanical :)
