How good are S&B air intakes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pablo8, Oct 25, 2019.
  1. Oct 25, 2019 at 5:28 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
  2. Oct 25, 2019 at 5:56 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    How much money are you planning on putting into engine performance modifications. Are you shooting for 600HP. Ya get it. You just going to do OVTune - your purchase is just eye-candy.
    Pablo8[OP] and StillNoPickles like this.
  3. Oct 25, 2019 at 6:00 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    A product that claims better filtration with better airflow, over basically the same surface area is a sham. You can get more airflow or more filtration. Not both. No more effective than the stock air box.
  4. Oct 25, 2019 at 6:04 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Not tearing into the engine. I highly doubt stock is that restrictive.
    I ask because the business I own is an S&B dealer - unrelated to Tacoma - but we can get the full S&B line. I was considering one for the price, or heck I could sell them.
  5. Oct 25, 2019 at 6:07 PM
    Stoked
    Stoked Not So Well-Known Member
    Jeff
    Celina, Tx
    2016 DCSB TRD OR
    If you want one, get it...
  6. Oct 25, 2019 at 6:08 PM
    PhenixFord
    Randy
    Arkansas
    That's cool. Then you probably already know that an air cleaner upgrade alone is just eye-candy. You need to do a complete Stage One performance up-grade to see "any" benefits. And that leads to new problems in itself.
    Pablo8[QUOTED][OP] likes this.
  7. Oct 25, 2019 at 6:11 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I have one. Admittedly I can't tell a difference in the performance. But, I can definitely hear a difference when I goose the throttle. You can hear the air being sucked into the engine.
    After that, its just something I can say I did.
    The down side is, a person can not put a dual battery setup that puts the auxiliary battery on that side. I had to go with the Genesis set-up
  8. Oct 25, 2019 at 6:19 PM
    PhenixFord
    Randy
    Arkansas
    Typical of a CA system. A result of the direct, high airflow design also allows sound waves to egress easier.
  9. Oct 25, 2019 at 6:20 PM
    fatboyfirebass
    Pablo8[OP] likes this.
  10. Oct 25, 2019 at 6:30 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    THAT is one big boy! Largebox.
  11. Oct 25, 2019 at 6:37 PM
    fatboyfirebass
    For sure. I actually purchased it and had it ready before I took possession of the truck.
    Once I installed it, I stopped debating which dual battery system I wanted, (Off-grid vs. Genesis). The decision was made for me.
  12. Oct 25, 2019 at 6:39 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Simply won't work for me. Dual air compressor.
    fatboyfirebass likes this.
  13. Oct 25, 2019 at 7:40 PM
    Tbgreen89
    Tbgreen89 Well-Known Member
    2019 DCLB TRD-Off Road
    Love mine! I actually gained about a 1.5mpgs matched with a BakFlip tonneau cover. Also left down shifting as well. Sounds good too. Now just need to add a Borla exhaust!
  14. May 15, 2020 at 5:48 PM
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    I just purchased one but have not installed it yet. I see that the Air pump has to be relocated
    over next to the power steering pump. The kit seems to come with all the needed parts to
    make it work. Even an extension harness for the air pump. So I probably will work on getting
    the pump moved first and then do the filter box up upgrade. I got mine from /Extreme terrain
    and I had heard on another post of issues with this company. Well I can say they shipped
    fast included tracking data and the item arrived in good condition with all the required stuff.
    So I have to say they did a good job. I just wish more info was on the site about having to relocate
    the air pump. Had I known it was going to have to be moved for installation I most likely would not have purchased it.
    And gone with something else. But I will make due with what I have. Pics included on installation of assembly.
  15. May 15, 2020 at 6:29 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Thanks - didn't know that about the Gen 2 filters.
  16. May 16, 2020 at 5:18 AM
    Soylent Green2012
    jake
    Apopka, Florida
    Have you had any issues with CEL coming on after install ?
    I see in my paperwork that came with the kit it says do not use any other (brand) oil or cleaner on the filter. I have both K&N oil and cleaner I could use. But is this just
    to get you to purchase their product ?
    Also I have a cat back exhaust in my future too.
  17. May 16, 2020 at 6:23 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    All the ones I have sold are dry filters. Where are you guys buying these?
    Yes you can use K&N oil - but think about it - filter manufacturers don't want people to drift to every kind of oil known to man.
  18. May 16, 2020 at 6:40 AM
    Soylent Green2012
    jake
    Apopka, Florida
    I've been using these type filters and oil for years and most of the K&N products make similar claims.
    However the K&N stuff can be purchased in Auto parts stores. The S&B oil has to be purchased on line
    or from a local dealer. And no I would not just dump 30 weight oil on it and enjoy the ride. Smoke screen included for
    special effects.
  19. Jun 8, 2024 at 10:49 AM
    Vinchez78
    Vinchez78 Well-Known Member
    Alvin
    Black Taco TRD sport
    I've had one for two years I love it, mainly just for the looks and sound, ordering a paper filter as we speak today
  20. Jun 8, 2024 at 10:53 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Looks better than stock , that's about it.
