How Flat is Still "Normal" for Stock Leaf Springs? (Pics Inside)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bob K, Apr 8, 2022.
  1. Apr 8, 2022 at 9:51 PM
    Bob K
    Bob K [OP] Well-Known Member
    Bob
    2017 TRD Off Road
    2017 TRDOR, fully stock. How "flat" is still normal for stock leaf springs? In an unloaded bed, my springs look like this. I would appreciate a few data points from others.
  2. Apr 9, 2022 at 7:09 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Normal. Here is what Icon rxt leaf pack looks like. One of the quality leaf packs out there that can actually hold weight
  3. Apr 9, 2022 at 7:23 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Flat is normal, actually it's better than normal. Most are sagging more.
    Bob K[OP] and hiPSI like this.
  4. Apr 9, 2022 at 7:29 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    OP if your worried about when loading you could install a single aal that would regain some arch in leaf pack also. That’s an option as well. If you load bed frequently single leaf will get tired after time. IMO
    Bob K[OP] likes this.
  5. Apr 9, 2022 at 7:35 AM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I'm thinking of doing the u-bolt flip when I install my RTX pack. I can't quite tell in the pic, but does a bump stop still mount on top? In particular, I'm thinking of keeping my Sumo Springs but not sure how/if they can still be attached.
  6. Apr 9, 2022 at 7:38 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Yes mounts on the top of flip kit :thumbsup: Sumo springs are awesome :thumbsup:
  7. Apr 9, 2022 at 7:42 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. I'm not exactly seeing how though. Do you have drill holes in the sumo spring mount or what is holding it?
  8. Apr 9, 2022 at 7:46 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Not sure about the sumo springs this is what I have with the super bump stops
  9. Apr 9, 2022 at 7:49 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. Yeah, I've seen the single hole bumps, but the sumo spring has the flat edge for the normal u-bolt to lay across. I'm guessing I'll have to drill a couple holes or find a different mount for the sumo spring.
    Sorry for hijacking OP. Now back to your regular schedule programming.
    71tattooguy[QUOTED] likes this.
  10. Apr 9, 2022 at 7:51 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :thumbsup: Sounds good. Regular scheduling program :rofl::rofl:
  11. Apr 9, 2022 at 7:55 AM
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
  12. Apr 9, 2022 at 4:03 PM
    Bob K
    Bob
    2017 TRD Off Road
    I just put Sumo Springs on mine as well. That is the reason I was asking about the stock leaf springs. I was under the impression that the Sumo Springs were short enough (or the stock leaf springs bowed enough) that they only engaged after the leaf springs saw significant compression...you know, a backup suspension device rather than a primary one. However, with my truck, the Sumo Springs are already in contact a bit with the bed even before putting weight in the bed. So on my truck, the Sumo Springs will always be providing some suspension and aren't a "backup" or "secondary" device.
  13. Apr 9, 2022 at 4:09 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    I have the 4 donut ones and a shell. My frame is just sitting on top. I just put them on so only a few dozen miles so far but I can sort of feel them. In a good way I guess. Less bounce over speed bumps and maybe a bit firmer feel on the road. I got them mainly to help with sagging when loaded on an upcoming trip so we'll see. Getting 5100s and an Icon leaf pack this summer so that will probably get me sitting a bit higher.
  14. Feb 29, 2024 at 4:31 PM
    Bob K
    Bob
    2017 TRD Off Road
    I presume "aal" is "add-a-leaf"?
    I put SSR-612-40 Sumo Springs (https://a.co/d/fPMmKyh) on to see if that would help me, especially for towing my ~4,000lb RV (with weight distribution hitch). Because of the existing, err, flatness of my springs, the frame sits on the Sumo Springs all the time. They do help when towing, of course, but I'd prefer the Sumo Springs engage only when I have excess weight on the backend. That's not gonna happen with my existing flat OEM springs. As it is, the ride is a bit harsher with no weight on the backend since the Sumo Springs are always in contact.
    The Icon RXT spring packs are $371 each (o_O). I'll have to look into an add-a-leaf.
