How fast does Frame Rust occur on 1st gens?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kalb, Jan 23, 2019.
  1. Jan 23, 2019 at 1:23 PM
    kalb
    kalb [OP] Member
    2001 XtraCab 2.7 4cyl 5 speed 4x4
    Hi,
    Curious how fast it takes for rust to set in / start eating at frames. I have a truck that was mostly garaged and has minor surface rust & one small nickel sized, young piece of bubbling rust on the frame. Doesn't look too bad. No holes or weakness in the spot yet but clearly rust is present. My mechanic said to keep an eye on it every time I jack it up to change oil.
    This truck is from new england, but was undercoated in 2010 and has been washed every week during winter, plus driven very lightly / not in salt puddles / was garaged, etc.
    Two scenarios I need help with:
    1. I drive to southern california with this truck, where there is no rust / threat of rust. How long will it take for that surface rust / small nickel sized piece to grow once I'm there? How many years or miles?
    2. I stay in New England and drive it thru multiple winters, washing underbody and minimizing salt exposure. How long does rust take to become an issue?
  2. Jan 23, 2019 at 1:25 PM
    kalb
    kalb [OP] Member
    To clarify, the truck is a 2001 sr5 with 74k miles and drives like it's brand new.
    I can see myself driving this for 10 years in california - assuming the frame lasts that long.
    Best case scenario answer: you're good until 200k or whatever, 10 years no problem.
    Worst case: nothing you can do, will become a problem in 1 year.
  3. Jan 23, 2019 at 1:36 PM
    vtframer
    vtframer Well-Known Member
    Vermont
    2001 Tacoma SR5 Extended Cab, 4x4 Manual Trans.
    i have the same question! I brought an AZ '01 sr5 to VT and have kept it undercoated - wonder how long I would have?
  4. Jan 23, 2019 at 2:29 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    For What it is worth my Tacoma spent it`s Youth in Central Texas 2 winters it needed Tender Loving care.
    I just panted things and kept after when I could That Liquid Brine is Brutal
    If you can do the work or have a friend that will for expenses it is not bad
  5. Jan 23, 2019 at 2:36 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    climate is dry, so that rust is not going to worsen.... as long as you don't go driving into the ocean or park in a pond. Salty water is very bad (southern equivalent of winter salt)
    if you want to drive it through the salt, you have to rustproof it both inside and out, as it will make it last much longer, but the best is to not expose it to the salt. Unprotected car exposed to winter salt is only a matter of a few years before it starts getting eaten up by rust. Rustproofed car: a long time, as long as you keep rustproofing it every year
  6. Jan 23, 2019 at 2:53 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    WTF it means "keep an eye on it"? Doesn't matter how long you would stare at that thing, it will not help. Instead of "keeping eye" you should act. Get fluid film and treat the frame. Do it every year and it should keep the rust from growing.
    Dalandser likes this.
  7. Jan 23, 2019 at 3:04 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    I drive mine on the beach weekly... Wash it off maybe every other time, do have some undercoating on the frame and don't have any frame rust.
  8. Jan 23, 2019 at 3:37 PM
    kalb
    kalb [OP] Member
    Yeah obviously going to act quickly and get a fluid film treatment yearly - the idea behind keeping an eye on it is to check periodically if that area grows or gets worse even w fluid film / undercoating. He was more saying, "here's the area of concern on this frame, to pay attention to." Planning to do fluid film anyways for future winter use both in new england and western US.
  9. Jan 24, 2019 at 1:52 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Texas here. Very little to no rust at all. What surface rust I did have was wire wheeled and subsequently treated with rust inhibitor. There are some products that you can spray onto surface rust and it will bond with it and prevent spreading. I personally get under the truck and check every few years to see whats needed.
  10. Jan 27, 2019 at 9:53 PM
    7x57toy
    7x57toy New Member
    2002 V6 X-tra Cab TRD Black
    Front Brush Guard
    at the end of January 2008 I had 3 holes about 2-3" each
    on the side of the frame on my 1996 4 cyl extra cab. 6 weeks later it was one long hole about 2' long.
  11. Jan 27, 2019 at 9:56 PM
    Bishop84
    Bishop84 Well-Known Member
    The only way to tell is to take a ballpeen hammer and tap it along all the rust spots, the sound and sensation tells a lot. The nasty frames feel soft to the hammer blows and will flake off, possible holes.
  12. Jan 27, 2019 at 11:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    In some states it takes the time you took to write that first post!
    Jay-coma and Rburdeaux like this.
