how envolved is it to remove a body lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stout890, Jun 2, 2011.
  1. Jun 2, 2011 at 1:09 PM
    Stout890
    Stout890 [OP] Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    so i have a 99 pre runner and it has 31's on it with a 2 inch body lift approximately. now how hard would it be to undo this lift? i think it looks o.k but the car drives like a sail boat in the wind and the tires on it look small. so its either get 33's or remove the lift that i don't really like anyway. and i don't want to go to 33 inch tires because of gas mileage and power loss. the truck is already a dog. i imagine i need an overhead lift for the body or can it be blocked? how much would i be looking at to have a shop do this for me?
    also the truck is off on the speed by +20 mph...do you guys think it possibly had bigger tires and was adjusted for them, than they were removed before it was sold to me? it may be re-geared for larger tires as well because it shifts funny..it doesn't hold gears long enough.
  2. Jun 2, 2011 at 2:54 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I don't know the proper way of installing or removing body lifts because I have never been interested in them, but if I had to remove one I would use a block of wood on a jack and put it under the body. Then I would take my time and remove one spacer at a time slowly letting the body down to the original mounts. I wouldn't imagine it being to difficult because there isn't much to a body lift.
    The issue with your speedometer is probably from a regear. I don't think it is possible to correct the speedometer in these trucks. Most people just go buy a scan gauge or something like that and calibrate it to the correct speed.
  3. Jun 2, 2011 at 3:59 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Would be a good idea to buy a Body Mount Kit from Energy Suspension or Daystar before you begin.
  4. Jun 2, 2011 at 4:05 PM
    tacotrd647
    tacotrd647 Resident "dude"
    Caleb
    Ridgeway, Iowa
    02 Prerunner SR5 TRD
    KMC Enduro Wheels, 265/75/16 toyo open country at2
    Shouldnt be too difficult with the right tools and plenty of beer!
  5. Jun 2, 2011 at 10:18 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    does the body have some kind of stock mount or something than? i was imagining it just bolts right back to the frame.
  6. Jun 3, 2011 at 5:35 AM
    Southern01Taco
    Sean
    Holden, La
    It has rubber bushings that go between the body and the frame to give it a little cushion. The rubber tends to wear out after a while and when you are taking the body lift off, that will be the best time to change them.
  7. Jun 3, 2011 at 4:20 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I took a 3 inch body lift off my 98, it was tedious but not too bad. First I did the box with the only real issue being the gas filler hose, just shortened the rubber hoses and replaced the clamps. The cab and front clip were a different issue, once I got all the lift stuff out, a bit of a job with the rust from our heavily salted roads, I used pieces of wood to hold everything in place and slowly lowered the cab and clip a bit at a time stopping to check wires and squeezing the brakeline coils together. The radiator was a bit of a problem, you have to make sure it is just hanging by the hoses and once the clip is down at the proper height you can bolt it right back into the original locations. The steering connection may be an issue depending upon how it was extended but that will also have to be disconnected and carefully watched as you lower the cab so it doesn't jam, I had to go the scrapyard to get a replacement as there was no way I could use the extended one that came with the bodylift kit that had been installed. Truck is much better now, less of a sail in the wind and my 31's look just right with 5100's set at the middle position and the rear springs done to add about an inch of rake, rides better too with the proper body mounts but don't buy them from Toyota.
  8. Jun 3, 2011 at 4:32 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I also have a 3" body lift and planning on removing it. I heard the rear isnt bad to do but the front is a little trickier. Since the front bumper is mounted to the frame you would have to relocate it, but the rear bumper is mounted to the body i believe so it would be fine. Re-organizing the engine parts seems to be the hardest part.
  9. Jun 3, 2011 at 4:39 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The rear bumper is also mounted to the frame.
  10. Jul 27, 2011 at 8:52 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Good info thanks!
    So My bumper is flush with the body. And I have a 3 inch body lift. Im planning on removing mine, so how do I move my bumper down?
  11. Jul 27, 2011 at 9:54 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    yes, it does, but you'll also need to remove the steering (etc...) spacers. Not that big of a deal. As for your bumper, it more than likely has a set of brackets that moved the bumper up. Hopefully these aren't welded in place. If not, just take the brackets off. If they're welded, get an angle grinder or a torch and have some fun...
    As for getting new body mount bushings, it's probably not absolutely necessary, but if you're taking it apart anyway, ~$70 (urethane body mount kit) is a good investment and piece of mind. It's hard to inspect the body mounts until they're off the truck anyway. So if they're damaged, and you didn't buy new ones, your truck will sit for a few more days while you order new ones.
  12. Jul 27, 2011 at 9:59 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    now i see why everyone hates body lifts...they seem to be the biggest PITA thing you could to to your truck.
  13. Jul 27, 2011 at 10:27 AM
    jbrandt
    Justin
    for me, it's not that they are a PITA to install/remove, it's actually quite the opposite. Most people (IMO) get body lifts because they are cheap and relatively easy to install. You don't need to modify the suspension, extend brake lines, etc...
    The problem I have with them, is well, they are cheap, and make the truck higher, less stable, etc... for absolutely NO performance increase. I just can't see how spacing the body 3" away from the frame using 1" diameter spacers can be a good thing. Think of it like stepping on a soda can and balance on that. That's what a 3" body lift is like for your cab/body. The next worst option, IMO, is a block/spacer lift. Those also reak havock on your suspension. If you're going for minimum money spent and you want a city truck with huge tires and 15 hellas on a light bar that doesn't see dirt, fine...
  14. Jul 28, 2011 at 10:19 AM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    Crap, i am not looking forward to doing my body lift now.
    Shortended run-down:
    Remove/loosen front and rear bumper, relocate as necessary
    Remove and replace/shorten steering shaft
    Loosen radiator for relo
    Keep an eye on fuel/brake lines, relocate as necessary
    If your shifter (mani) arm was lengthened like mine, shorten as necessary so as to not interfere with instrument panel.
    THEN take off body lift
    FML
    For those of you that are thinking about putting it off and like to wheel...don't.
    Here's what my body lift looks like after the previous owner beat on it in the dirt with no consideration for the weakpoints of a body lift.
    Who in their right mind would install one of these is my question?
  15. Jul 28, 2011 at 11:21 AM
    mdub
    mdub Well-Known Member
    Missouri
    2016 Black DBLC TRD Off-Road
    ARE CX
    This might help... it's the instructions to put on a Body lift... search for your truck.... may help in getting it off
    http://www.performanceaccessories.com/instructions.php?Application1=Toyota
    This might help if you think you need new hardware to bring it back to stock.
    http://www.4crawler.com/4x4/ForSale/ToyotaTacoma.shtml#Tacoma
    And of course the most important reading material for any Tacoma owner to have.
    Have fun, I've subscribed, so if you get to it before I do, I'd love to see a full write up.
    Mdub.
  16. Aug 1, 2011 at 2:38 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    i think im gonna do it.....the more i look at my truck the more i hate that damn lift. all i need is a buddy and a cool day....i may take a few pics of the process and post em but doubt i will have the desire to do a full write up. who knows maybe i will.....
    seems tedious but not impossible. i read over the lift install instructions and it talks about some brackets being welded underneath the body so ill have to check that out. also my bumpers are bolted with lift brackets so im good there.
  17. Aug 1, 2011 at 11:29 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Lol, PURGE IT WITH FIRE!!!
  18. Aug 1, 2011 at 11:34 AM
    JLee
    Jerry
    Benicia, CA
    There has to be brackets moving your bumpers up that might of came with the kit hopefully it's not welded on.
  19. Aug 2, 2011 at 12:23 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    so the bed seems easy enough....once i have it blocked and the lift cylinders removed i can just jack it up (with jack on some sort of stand) remove blocks and lower...but what about the cab and clip? where would i even begin to put the jack so that the cab was balanced and would not tilt? where would be a safe place to load all that weight in a single area as well with out causing damage? im going to have to go slow and triple check everything before i lower it to the frame...any ideas? and can anyone direct me to a good brand to get some stock body mounts from?
  20. Aug 4, 2011 at 5:35 AM
    mdub
    Missouri
    ARE CX
