How does TPMS work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tusk, Nov 10, 2014.
  1. Nov 10, 2014 at 12:50 PM
    Tusk
    Tusk [OP] Active Member
    Does anyone know for sure how this works? I’d like to know if the sensors on the wheels “report” to the computer on board the truck or does the computer on board the truck “poll” the sensors. If the sensors “report” than I wonder if it would be possible to add a sensor to the spare by cloning a number already in use by one of the other wheels. If the computer just sits there waiting to hear from a tire sensor when something is wrong than it wouldn’t matter if the same ID number was used by multiple wheels, right? I do a five tire rotation and the goal here would be to add a sensor to my spare tire.
  2. Nov 10, 2014 at 12:59 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Sorry can't answer , but seems like a lot of work for not much return.
  3. Nov 10, 2014 at 1:43 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    No computer, it's Tire Pressure Magic System.
  4. Nov 10, 2014 at 1:45 PM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Serious note, your spare should already have a sensor. When I got new tires they had to reprogram all 4 plus the spare.
  5. Nov 10, 2014 at 1:45 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    There's a sensor on the valve stem that reads pressure and transmits it to the computer, each sensor has a unique code.
    I don't know if you can add one though.
  6. Nov 10, 2014 at 1:46 PM
    95 taco
    95 taco Battle Born
    The sensor in the spare was stopped in 2009 (2008 was the last model year to have it).
  7. Nov 10, 2014 at 1:48 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    X2. Depending on the year, all 5 tires should have sensors already.
    Edit: Of course; if you don't, I believe that the truck has room in its memory for 5 sensors, so programming in a fifth should be possible even if yours didn't have one from the factory.
  8. Nov 10, 2014 at 3:54 PM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Didn't know that, however both the 09's I have owned had the spare tire with a sensor. Maybe 2009 was the last year?
  9. Nov 10, 2014 at 5:18 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    And other Toyota models are different too. My '14 Tacoma doesn't have a sensor in the spare. My '12 RAV4 does.
  10. Nov 10, 2014 at 5:20 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    My '09 doesn't have TPMS in the spare
  11. Nov 10, 2014 at 5:25 PM
    SLOBRA
    SLOBRA LET IT EAT®
    Albuquerque, NM
    2012 DCSB 4x4 TRD O/R
    My 2012 has one in the spare. I couldn't figure out why my TPMS light was illuminated when all four tires were at the correct pressure, then it dawned on me...the spare was at 22psi.
  12. Nov 10, 2014 at 6:22 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Would this mean there is a battery in the sensor? If so, any idea how long they will last?
  13. Nov 10, 2014 at 6:46 PM
    95 taco
    95 taco Battle Born
    Yes, there is a battery.
    The battery last between 5 and 8 years.
  14. Nov 10, 2014 at 8:11 PM
    seafur
    seafur Well-Known Member
    Pacific Northwest
    2014 DCSB MT TRD OR
    Sprinter bed tiedowns, Aux fuse box, AIO key, 3-way canopy light switch, 12V bed outlet, Dual Battery AGM G35, Viair OBA, Uni-filter mod
    It's a government tracking device.
  15. Nov 10, 2014 at 8:11 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    just dont even rely on the TPMS.... you should check tire pressures regularly anyways.
  16. Nov 11, 2014 at 12:14 AM
    ShawnR
    ShawnR Roads?? We don't need no stinkin' roads...
    Shawn
    Denver
    10 Taco TRD OR access cab
    PIAA driving lights,Pioneer AVH-P3300BT stereo with HD radio and Axxess steering wheel control adapter,rearview mirror mod,ReTrax rolling cover,Demello front bumper,WeatherTech,10 inch woofer,500 watt amp,CB in armrest, heated Wet Okole seat covers,Spidertrax spacers, ARB twin compressor,Ikon 10,500lb wireless winch,A-pillar RAM mount,Pull-Pal,electric locking tailgate
    If you have a dealer check out the TPMS with their reader, you can see that each tire sends out info on tire pressure and tire temperature. Unfortunately, the Tacoma computer just reads the pressure, and if it is too high or too low from the set pressure, an idiot light comes on. The TPMS sender's serial number has to be entered into the Tacoma's system, so it doesn't read the tire pressure of the other Tacoma passing you on the freeway.
    The lith-ion battery is supposed to last 8-10 yrs in the sender unit. It is NON-replaceable.
  17. Nov 11, 2014 at 3:48 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I dummied the TPMS ECU.
    I soldered in a couple of resistors to fool the ECU into believing all sensors are reporting correct pressures. Non of my wheels have TPMS valve stem assemblies. No lights show up on the dash except during start up.
  18. Nov 11, 2014 at 7:29 AM
    cjoker
    cjoker Active Member
    brent
    Ontario, Canada
    2014 Tacoma TRD Sport
    Salex console & glove box organizer, front window tint, steelie phone mount, G-Tek Sill Protectors - carbide black & diamond plate, WeatherTek digital fit mats, LED Map and Dome lights
  19. Nov 11, 2014 at 8:29 AM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    What does that have to do with his question?
  20. Nov 11, 2014 at 8:52 AM
    koditten
    Kirk
    Central Michigan
    Just a helpful tip.
