How does the locker work?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mwrohde, Mar 14, 2014.
  1. Mar 14, 2014 at 7:56 AM
    mwrohde
    mwrohde [OP] Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    2003 Tacoma 4x4 TRD.
    I've been reading the owners manual and it makes reference to turning the locker on and off. The Gray Wire Mod implies that it can be turned on and off, too.
    Coming from Ford, where the differential is a limited slip controlled by clutches, this on-or-off for the differential has me confused.
    Will someone explain to me how it works or direct me to a write-up somewhere that does?
    Thanks,
  2. Mar 14, 2014 at 8:05 AM
    Indy
    Indy Master of all I survey.
    There are 2 types of lockers, manual and automatic. What you're referring to is the E(electronic) locker. Flip a switch and it engages.
    just google 'differential locker' and you'll find videos and diagrams and posts enough to keep you busy until the day after the sun explodes.
  3. Mar 14, 2014 at 8:45 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    The gray wire mod makes it so you can turn the elocker on and off whenever you want. Otherwise it will only engage when you're in (might be slightly wrong here) 4lo for sure and I -think- 4hi
    I think that's right :anonymous: haha
  4. Mar 14, 2014 at 8:58 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
  5. Mar 14, 2014 at 9:01 AM
    Hawaiian05
    Hawaiian05 Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    There are a bunch of write ups on the operation and diagnosis (of a non-working unit) on this site, though I don't have the links. You can try the search function and see what it produces. Or, like Indy said, google will have a ton of info and links re the use.
    Be sure to engage/disengage the locker frequently (I do it at least 2 times a month) to ensure it doesn't seize up and become faulty. You'll be glad you did when the times comes that you actually need it.
  6. Mar 14, 2014 at 9:48 AM
    mwrohde
    Sugar Hill, GA
    So, the differential goes from being fully open, to fully locked? There's no limited slip aspect to it at all?
    What about the front diff? Is it open?
  7. Mar 14, 2014 at 9:52 AM
    tomtom
    The Desert SW
    2012 FJ
    Yes. It goes from fully open to fully locked. No in-between. And, yes, front diff is open.
  8. Mar 14, 2014 at 10:50 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Winner!
    Limited Slip:
    In 2005 (to 2008) the TRD SPORT models got a mechanical limited slip rear differential.
    In 2009 (and a few specialty order earlier models back to 2005) Tacomas all got an electronic/ ABS limited slip system called TRAC (traction control). In H4 it works on the front and rear tires. Two levels of traction control are available: TRAC and TRAC OFF (AUTO LSD). Trac has engine regulation and Trac Off doesn't, for a stronger limited slip. In H4 (2009-2011) Trac is the same as Trac off.
    The TRD OFF ROAD also got 'A-TRAC' which provided nearly no slip traction control on the front and rear tires (very close to the traction of lockers). The TRD OFF ROAD continues to have the locking rear differential.
  9. Mar 14, 2014 at 6:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Only in 4lo until you do the gray wire mod.
    Prior to 2005 (all 1st gen Tacomas) there was no factory limited slip diff offered.
  10. Mar 14, 2014 at 6:48 PM
    Ice Horse
    Lauren
    Colorado
    Thanks. I just wasnt sure about the 4hi haha
  11. Mar 14, 2014 at 7:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Just to be clear, TRD Prerunners don't have to be in 4lo to use their elocker. :rolleyes:
  12. Mar 14, 2014 at 9:39 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    I did the grey wire mod on my 02 taco trd 4x4 and now the rr dif lock works in 4hi 2hi &4lo hope that clears this up for you. Before the grey wire mod it only worked in 4lo. If any of you have a rr dif lock it is a good habit to engage it once a month to keep,actuator working.
  13. Mar 15, 2014 at 8:55 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    OP,
    you do realize that there is a button on the dash (labeled RR or something) that YOU have to push, don't you? It isn't an automatic locker, like a Lock-rite.
  14. Mar 15, 2014 at 4:24 PM
    blake9220
    blake9220 Well-Known Member
    Blake
    Orange County, CA
    01 TRD PreRunner DblCab
    Some of us had to install our own button.....
  15. Mar 15, 2014 at 5:32 PM
    David K
    They don't have a transfer case, so you don't have a '4lo' (or 4 High) to get into, at all! :rolleyes:
  16. Mar 16, 2014 at 5:38 AM
    mwrohde
    Sugar Hill, GA
    Yes, I knew that. Thanks
