How Does One Check Condition of Upper/Lower Control Arm Bushings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Apr 18, 2020.
  1. Apr 18, 2020 at 11:49 AM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    How can I check the condition of the upper and lower control arm bushings?
    During my last off-road trip I heard a sharp metal-to-metal knock when I was negotiating a rather tight left turn on some rough ground at about 2 mph. Sounded like it was coming from the steering column but inside the engine compartment.
    BTW I checked my LBJs and they are tight.
    GQ7227 likes this.
  2. Apr 19, 2020 at 6:46 AM
    skeezix
    Colorado
    1998 Limited
    Forgot to mention that the truck has 100,000 miles on it.
    GQ7227 likes this.
  3. Apr 19, 2020 at 7:14 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    subbd for curiosity if nothing else
    do you have any pics of the bushings?
    i am likely in the same boat as you at 143k and everything all original up front with mildish weathering, it probably needs some new parts one of these days! maybe on its 25th year as it will likely be a major expense needed to plan for
    my 'off-roading' is basically limited to pulling off the highway onto a soft shoulder, nothing too hardcore
    but everything sure gets a workout on the concrete trails that are in major disrepair around here
  4. Apr 19, 2020 at 10:29 AM
    Glamisman
    Glamisman Well-Known Member
    put a pry bar between the control arms bushing end and what ever there is to pry against and see if there is any play.
