How do you take off the hood?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by k3v11n, Sep 10, 2015.
  1. Sep 10, 2015 at 12:22 AM
    k3v11n
    k3v11n [OP] Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    How difficult is it to take off the hood? I'm going to be doing a hood swap for a scooped hood and was wondering how difficult this task is. It seems pretty straight forward. Just a couple of bolts on the 2 brackets. How does the windshield washer nozzles come off? Thanks.
  2. Sep 10, 2015 at 2:39 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    To remove the hood you should have a couple of bolts on each of the two hinges. The hardest part will be getting the alignment done satisfactory.
    As for the washer nozzles, I haven't looked myself, but if you look on the bottom side of the hood the nozzle clip method should be obvious...
  3. Sep 10, 2015 at 3:58 AM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
    The hose just slides apart. When I changed mine I took one of the factory bolts out and went to the hardware store and got 2-1 1/2" long allens in that size. Then I put them in the the holes closet to the windshield to keep it from dropping down when re-installing. It will help if you can have a couple of saw horses ready so there is place to set the first hood off. Did the whole thing in less than 30 minutes with 2 people.
  4. Sep 10, 2015 at 7:14 AM
    omega supreme
    omega supreme Well-Known Member
    2011 TRD sport,lb
    None
    Hmm. I am looking to go the other way no my hood. Getting rid of the fake vent.
  5. Sep 10, 2015 at 7:17 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Leave it unlatched, hit the highway.
    k3v11n[OP] likes this.
  6. Sep 10, 2015 at 11:43 AM
    k3v11n
    Oahu, Hawaii
    PlastiDip
    I have Sport envy. ;)
    Thanks for the info guys!
